Old May 21, 2015, 11:13 AM
jrobinsonusaf is offline
Find More Posts by jrobinsonusaf
United States, NC, Matthews
Joined Jun 2006
Rotor Head Question
Is there any advantage (or disadvantage) to having a one axis head with elevator and rudder versus a two axis head? With a two axis head, do you need elevators? Can the head be coupled to other controls ala the Ercoupe (linked ailerons and rudders)? I'm new to this and trying to learn as much as I can before investing in anything.
JR
jrobinsonusaf is offline Find More Posts by jrobinsonusaf
Old May 21, 2015, 06:24 PM
britinoz is offline
Find More Posts by britinoz
britinoz's Avatar
Elizabeth South Australia 5113
Joined Nov 2005
Greetings JR
Well there a couple of ways to go about it...and they both work OK
You can have aileron and elevator on the head with the servos coupled using the delta set up on your TX. So this gives you a full moving head plus a rudder.....or......you can have roll only on the head with a conventional rudder and elevator on the tail.
Both these methods are suitable for a beginner.
Happy Landings
Chris...
britinoz is offline Find More Posts by britinoz
Old May 24, 2015, 05:35 PM
roidspop is offline
Find More Posts by roidspop
roidspop's Avatar
Joined Apr 2005
The single axis rotor with rudder and elevator let you take some risks you might not otherwise, like doing aerobatics. If the rotor should stop inverted or in a vertical dive, as an example, you've still got yaw and pitch control and a shot of power can let you recover quickly. With roll and pitch on the rotor, it seems like it's possible to get into situations that you might not be able to get out of unless you have plenty of altitude. I haven't been willing to fly my direct control gyro into weird orientations, but I don't worry at all about the 1 + 2 I've got now...someone else would have a different view, I'm sure.
roidspop is offline Find More Posts by roidspop
Sold NEW - 4 BLADE ROTOR HEAD 600 / 700 SIZE and Tail Rotor Jaguar22 Aircraft - Electric - Helis (FS/W) 3 Jul 04, 2014 10:41 PM
Discussion Apache 600 scale rotor head and tail rotor head and main blades kin Scale Helicopters 4 Jan 10, 2010 03:07 PM
Are real heli rotor heads similar to model heli rotor heads? smste2 Micro Helis 6 Jul 11, 2004 01:15 PM
Eolo Rotor head question Orion_V Electric Heli Talk 4 Dec 15, 2003 08:35 AM
Corona rotor head setup questions bigryan Electric Heli Talk 3 Jan 19, 2003 02:53 PM
