Old Jan 16, 2012, 01:04 AM
exspluu is offline
Find More Posts by exspluu
United States, TX, Houston
Joined Nov 2006
Super Deformed Macross
For all of thoes that are fans of Macross, AKA Robotech, I've been scouring the Interweb to find plans for anything that I could build that was simple and quick.
I've been lurking around here, conducted search upon search and found suprisingly very little information or scratch builds.
So hence my journey began.
There were some rules to be followed.
1) Had to be a quick build..(I have very little patience)
2) Had to be cheap..(Dollar or less, foam that is)
3) Had to be FUN!
I thought about this and put it in the blender I call my head..and Spit this idea out.
SUPER DEFORMED MACROSS!
If you don't know what that is check out this link:
Macross HD Super Deformed (1 min 2 sec)
Why not? we've got cartoon planes..Plenty of Quick Builds..and an abundance of Dollar Tree foam knowledge..
As with ROY FOKKER..I played around with the PROTO-VERITECH..
and testing shows promise...
Glide tests, Location of CG..all done.
It's all a matter of adding in the rest of the guts and of course the Maiden flight.
Curious Yet?!
Well here ya go, a first look.
Sorry folks, I have yet to decide if it's a VF1-A,D,J, or S, so no turret head yet, maybe even an E-lint seeker?.
I plan on conducting inital flights with a couple control options.
1) V-Tail setup only
2) V-Tail w/Ailerons
3) Elevons w/Thrust Vector (suggestion made by my crazy test pilot)
I'll be modifying the look and style of the SD Valk..once I get it up in the air..
Power will be supplied by a Prop in Slot 2600KV BL.
More to come!
exspluu is offline Find More Posts by exspluu
Old Jan 16, 2012, 04:22 AM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
"I've been scouring the Interweb to find plans for anything that I could build that was simple and quick. "
If your looking for plans, the best place to start is the top of this forum, there is a 'Sticky' thread that lists loads of free plans, plus links to the build threads.
eflightray is online now Find More Posts by eflightray
Old Jan 17, 2012, 07:07 PM
Tsavah is offline
Find More Posts by Tsavah
Watt Waster
Tsavah's Avatar
Joined Oct 2010
Cute Macross Jet Build
Originally Posted by exspluu View Post
For all of those that are fans of M across, AKA Robotech, I've been scouring the Inter-web to find plans for anything that I could build that was simple and quick. I've been lurking around here, conducted search upon search and found surprisingly very little information or scratch builds. So hence my journey began.
3) Had to be FUN!
I thought about this and put it in the blender I call my head ... and Spit this idea out.
SUPER DEFORMED MACROSS! If you don't know what that is check out this link:http://www.youtube.com/watch?v=dIp5knRNzG0
Why not? we've got cartoon planes..Plenty of Quick Builds..and an abundance of Dollar Tree foam knowledge ...
I have been a fan of the Macross Saga since the first day I saw one of the cartoons. You are correct to say there is little in RCG, as far as I have found to date. No doubt there is more to find, but finding it has been an issue. Not long ago I was doing an "image" search using "Bing" by MSN and did find a number of imagines. Some suggested a possible RC build, so may have to look again. I will watch for further additions to this thread.
Tsavah is offline Find More Posts by Tsavah
Latest blog entry: Center of Gravity - Airplanes
Old Apr 30, 2014, 09:15 PM
Tsavah is offline
Watt Waster
Tsavah's Avatar
Joined Oct 2010
Not much action since my last post. I did find other examples of the SD models, but mostly of WW2 Aircraft, and Japanese super hero robots. All I have found to date are made from thick paper, or what is called card stock and is part of the papercraft hobby.
Old Jun 01, 2016, 10:18 PM
exspluu is offline
Joined Nov 2006
Sorry to everyone that has looked at this thread and wondered what happened..
Long story short...LIFE...but..I can now take a breather and relax until the next wave hits..
until then..back to the bench..I'll be revitalizing this effort and hopefully have more up next..
Next Milestones:
1) dust off the plans, and conduct a build,
2) Test and conduct a proof of concept (see if it glides worth a darn)
3) Oufit with electronics and cross fingers..
4) If it flies...I'm happy..., if it flies well, I'm in heaven...If all else fails...I hope it crashes Exceptionally.
Old Jun 02, 2016, 09:08 AM
OutcastZeroOne is offline
Find More Posts by OutcastZeroOne
"Fly, yes... Land, No"
OutcastZeroOne's Avatar
United States, CA, Santa Cruz
Joined May 2005
pfft, about time. and with the new Macross Delta having started up you got some catching up to do
Best of luck man!
OutcastZeroOne is offline Find More Posts by OutcastZeroOne
Old Jun 08, 2016, 01:24 PM
Tsavah is offline
Watt Waster
Tsavah's Avatar
Joined Oct 2010
Super Deformed vs Fattie, or Caricature
I probably need to mention this build isn't that different from the threads with the fattie, or caricature RC models.
Old Jun 08, 2016, 01:33 PM
rdeis is offline
Find More Posts by rdeis
AMA 353531
rdeis's Avatar
United States, CO, Colorado Springs
Joined Aug 2003
Shape looks very much like Alpha and Bravo (Cartoon Tomcats with helmets) from the first "Planes" movie.
rdeis is offline Find More Posts by rdeis
Old Jun 17, 2016, 07:06 PM
exspluu is offline
Joined Nov 2006
Thanks guys..I'll keep you posted. Had to dig up my old drawings and finally ready to cut out the parts.
Old Jun 17, 2016, 07:51 PM
wwmoggy is online now
Find More Posts by wwmoggy
Canada, ON, Peterborough
Joined Dec 2014
Loved that show
found this R/C VF-1 Valkyrie from Macross / Robotech
http://www.rcgroups.com/forums/showt...h#post33057208
wwmoggy is online now Find More Posts by wwmoggy
Yippee! LIPO survives a HUGE crash, Deformed and Punctured, But Still Works !!! Amazing... JettPilot Batteries and Chargers 24 Sep 23, 2009 04:23 PM
Discussion deformed lipo in crash TyFlies Batteries and Chargers 8 Apr 06, 2009 09:03 PM
Discussion deformed lead casy Sailboats 1 Feb 17, 2008 02:38 PM
Deformed LiPo from hard crash = trash? mattchase Parkflyers 18 Jun 02, 2005 10:31 AM
Schulze 12.46e - deformed capacitors.. simingx Electric Ducted Fan Jet Talk 4 Oct 03, 2002 12:35 PM
