Old Jan 03, 2015, 08:44 PM
wow- I feel like a rookie! The problem was the screws on the bottom gear that control the inner shaft (top rotors) were loose. Im flying again!
AttilaTheHun is offline Find More Posts by AttilaTheHun
Old Jan 03, 2015, 08:52 PM
To Soar Like An Eagle!
frieslander's Avatar
Canada, ON, Woodstock
Joined Dec 2007
Lol good. I was going to ask you about them but figured you would know yourself as you are not a rookie. Been there done that, the little grey cells between the ears are a little slow waking up at times.
Have fun.
frieslander is online now Find More Posts by frieslander
Fly em if ya got em.
leethetreeguy's Avatar
Winder Ga
Joined Sep 2008
Kewl. Glad that got worked out. hahaha
Happy Flyin
leethetreeguy is online now Find More Posts by leethetreeguy
Old Jan 03, 2015, 09:04 PM
ha - true that. thanks guys. I think this old bird is still fun to fly. And still looks kind of cool (old style)
Old Jan 03, 2015, 09:47 PM
Winder Ga
Joined Sep 2008
the v3 was always one of my fav's.
Old Jan 03, 2015, 10:08 PM
erdnuckel2's Avatar
Joined Mar 2009
well, well ... (*BIG sigh* ...) - the "good old times" ...
First flight of the FreeSpirit-LamaV3 Hybrid.wmv (4 min 20 sec)
Latest blog entry: and again ...
Old Jan 04, 2015, 12:20 AM
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
http://youtu.be/IxUr5UEfFwE
No fair E2. That was not the V3 "coax." Nice flying BTW
Mike.
Chap1012 is online now Find More Posts by Chap1012
Old Jan 04, 2015, 08:03 AM
kodak_jack's Avatar
Hilton (Rochester), NY
Joined Mar 2008
Sounds brushless with a lot of head speed.
kodak_jack is offline Find More Posts by kodak_jack
Old Jan 06, 2015, 01:05 AM
So where do you all get replacement or upgrade parts for the Lama v4 and v3 these days?
Ive seen X Heli has some things still available.
Later
Old Jan 06, 2015, 07:21 AM
erdnuckel2's Avatar
Joined Mar 2009
Later
personally, I have enough parts to last into eternity (well, until I fall backwards for the last time anyway ...)
If you are not stocked "up to the teeth", thinkrc is a good place to look I would say, probably helipal ...
I am pretty sure, Microheli still has apmle supply on V4 parts, but you will pay through the nose for it ...
I would also check whats left at Miracle-Mart ....
Those are a few options, I am sure there are still more ... but yes, parts will get/are getting harder to find ....
Old Jan 07, 2015, 11:09 PM
thanks erdnuckel. Im gonna have to load up on some parts myself soon.
Im wondering now what the position of the Gain and Proportional dials should be, since I've messed with the original settings. Heli seems to want to spin to the right after I tinkered with them dials!
Can't find the original manual unfortunately.
Old Jan 07, 2015, 11:45 PM
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
Dialing in is very simple. Turn the pot screw on "both" prop and gain to the highest point. Mark them both. Now turn them to the lowest point. Mark it again. Now turn both pots to "center",,..yup, mark it here too.
Now, fire her up. The first thing you want to do is put the heli in "tail wag". This is done by increasing the gain every so slightly. Once you've reached "tail wag" tone it down by decreasing it. Now, see if your heli will hover "without" turning/spinning " on it's axis. This is where the Prop adjustment comes in. Depending on your brick and age of heli.....if your heli turns CW counter it with CCW with the prop adjustment (again) ever so slightly. You will need to power down and power back up in between every adjust you make on the prop adjustment (very important). *Not so with the gain adjust....No need to power down*
If the turning/spinning gets worst, just dial the prop screw in the same direction the heli is spinning. CW spin=CW adjustment.
The main thing is to obtain "tail wag" first then tame that until it's smooth.
Always make your adjustments in small increments.
Mike.
Old Jan 10, 2015, 01:12 AM
Chap thanks!
Ill try that tomorrow .
later
Old Jan 10, 2015, 04:00 PM
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
Chap thanks!
later
Any questions at all, give us a yell
Mike.
Sold Lama parts. Xtreme tial/blades/etc. GFBurke Aircraft - Electric - Helis (FS/W) 3 Feb 14, 2007 05:58 PM
Found WANTED: CORONA PARTS , NEW, USED, UPGRADES, etc... setting up for Nephew kookboy Aircraft - Electric - Helis (FS/W) 5 Jan 07, 2007 02:26 AM
