Old Jul 11, 2015, 12:31 PM
blackcamo is offline
Find More Posts by blackcamo
blackcamo's Avatar
Joined Sep 2014
Strange issue
Hi all.
I'm having a rather strange issue.
All was working fine on my 250 quad (well I have a rc range issue but it seems unrelated) but yesterday I suddenly experienced picture blackout. (mid flight, but as I was heading toward myself I've managed to recover)
What is strange: the screen went black but osd was still on so vtx did transmit. Then it all went away. After a while I plugged batt again and all was fine until first throttle punch, same thing happened - camera(I think) went off. Third time I didn't even managed to take off, a bit of throttle and the screen goes black. Camera is powered through vtx and this is cheap 200mW eachine vtx (ts200?). I'm running everything off 1500mah 45-90C nano-tech. Batteries are in very good condition and also I would see some voltage sag through osd. Any ideas guys?
blackcamo is offline Find More Posts by blackcamo
Old Jul 11, 2015, 09:33 PM
waltr is offline
Find More Posts by waltr
Team WarpSquad
United States, PA, Doylestown
Joined Jan 2014
Bad solder joint
Bad connector, crimp, etc.
Bad or damaged wire.
Start with close inspection and then replace piece by piece.
waltr is offline Find More Posts by waltr
Old Jul 12, 2015, 04:07 AM
blackcamo's Avatar
Joined Sep 2014
Thanks waltr, that is what I was thinking, but it doesn't happen when I shake the quad, but only on throttle up, so when amps go up it shuts down. It also seems strange that it happened mid flight, after many faultless sessions. I just can't find the logic behind it. I will strip it down anyway as that seems to be the only way to find out what's going on here
Old Jul 12, 2015, 10:09 AM
waltr is offline
Team WarpSquad
Joined Jan 2014
The Motors Draw a lot of current and a poor solder joint has a bit more resistance than it should. The high current draw then creates a Voltage drop (Ohm's Law). This may then drop the Voltage to below what the camera, vTX, etc needs.
Try without props so the motors do not draw as much current and therefore lower Voltage drops.
Could also be a Bad motor or ESC then is injecting huge amounts of noise into the power system or drawing much greater current than it should.
Oil the motor bearings in case it is bearing vibration or drag causing increased current draw.
These problems are tough to find. Divide and conquer is the best method to troubleshoot.
Old Jul 15, 2015, 06:37 PM
blackcamo's Avatar
Joined Sep 2014
Found it! Poor solder joint on camera's crystal. Magnifying glass was the tool! Resoldered and problem is gone. Happy flier again.
Discussion Strange issue with Futaba FF9 (9C) Matt Halton Radios 2 Jul 05, 2015 06:18 AM
Discussion Strange issue with 450/Naze V1 Matt Halton Multirotor Electronics 1 Jul 01, 2015 04:22 PM
Discussion Strange issue with GoPro battery charging dragonblade Aerial Photography 0 Jun 22, 2015 09:35 AM
Discussion KK2 Strange Issue - one motor does not respond Tony89 Scratchbuilt Multirotors 3 May 18, 2015 06:30 PM
Discussion DJI iOSD strange issue Narj FPV Talk 3 Jan 17, 2014 01:55 PM
