Old Jul 10, 2015, 11:51 PM
golf_lake is online now
Find More Posts by golf_lake
Australia, SA, Munno Para
Joined Sep 2011
Help with HK Stick wing
As the title states I need Help with HK Stick wing, more precisely the front wing locator.
For those that dont know this wing it has a balsa rib that has a ply rib glued to it and then the two halves are glued together.
My issue is that the bit that locates and holds the front of the wing into location has broken.
It was suggested to run a saw down the middle and then glue in a new bit of ply at the front.
I can see this going bad real fast due to the ply being much harder than the balsa ribs each side.
My thought was to remove a bit of the sheeting on the underside and glue a black on each side of the balsa ribs and then drill and glue a dowel in.
looking for ideas on a fix thats up to the job.
golf_lake is online now Find More Posts by golf_lake
Old Jul 11, 2015, 02:51 AM
Swoopdown is online now
Find More Posts by Swoopdown
C'mon more Energy
Swoopdown's Avatar
Melbourne, Australia
Joined Mar 2005
Any photos would help. Especially of the "bit" that's broken.
I'm a big fan of plenty of 30 minute epoxy to fix most things. Rough but effective.
Swoopdown is online now Find More Posts by Swoopdown
Old Jul 11, 2015, 08:32 PM
Joined Sep 2011
There is nothing left of the bit that has broken off, HK quality ply vaporized after a prop strike broke a prop and the front shook itself to pieces in a second.
Old Jul 12, 2015, 08:24 PM
Free2air is offline
Find More Posts by Free2air
Joined Dec 2014
This is 1 way I might try without seeing it up close
even up the broken edge a bit make a piece that fits against it nice and is as close to the original shape and size of missing piece as possible remember to make it bigger if cant get original shape right so you can trim to suit later
then make 2 pieces the shape of the remaining piece on the wing and newly made bit together out of thin ply ,for strength have the grains running different ways
then glue ( screw if you want) and clamp them all together to the remaining wing tabs
the slot on the fuse will have to be widened a bit but a some reinforcing behind it will help keep its integrity if needed
this fix will add a bit of weight but if done right should add strength to the tab somewhat so if theres a next time shaking tantrum it should hold
hope this helps but as I said its only one possible way
Free2air is offline Find More Posts by Free2air
Old Jul 13, 2015, 12:00 AM
skyfox is offline
Find More Posts by skyfox
skyfox's Avatar
Mandurah, WA, Australia
Joined Jun 2002
Change to rubber band mounted wing? No need to cut the wing that way!
skyfox is offline Find More Posts by skyfox
Old Jul 13, 2015, 04:51 AM
Joined Sep 2011
Thanks Free2air I just had a look at it and I believe there is enough of the old ribs left to glue to the sides so your ides seems sound.
A little extra weight wont bother it or me as it has unlimited vertical and I had to rebuild the front of the fuse as that shook to pieces as well, tore the whole front fire wall out of it.
Skyfox rubber bands may work but I am over them after having a Boomerang, need so many to hold the wings in place while flying hard.
Old Jul 13, 2015, 09:06 PM
Free2air is offline
Joined Dec 2014
If you have to you could slice into the film a bit to give you more tab to stick to and stick the cut film back after as it's hidden in the fuse once done who'll know.
Discussion Eureka Classic Ugly Stick 60 with Foam Wing Short Kit focae Balsa Builders 3 Jun 06, 2015 11:05 PM
Discussion DIY Paramotor Trike (at first with HK 215cm wing) Stef stuntpiloot RC Kites 3 May 23, 2015 04:29 PM
Discussion Need help with HK 650X6 build incognito53 Multirotor Talk 1 May 12, 2015 07:38 PM
Help! Need help with flashing hk 12 amp esc (Error during writing flash) Zartan Multirotor Electronics 4 May 11, 2015 09:49 PM
Discussion What to do with a HK Micro Stick fiery 1/2A Planes 8 Sep 28, 2014 07:42 PM
