Old Jul 13, 2014, 01:41 PM
United States, NJ, Frenchtown
Joined Mar 2003
Help!
Flight system for The 46 " W S GWS Slow Stick
Trans /rec / ESC / servos / motor brushless direct drive to fit GWS motor stick mounts / prop size /
Lipo or LIFE battery size.
cyclops2 is offline Find More Posts by cyclops2
Old Jul 13, 2014, 03:42 PM
1st to the scene of the crash
Laneritc's Avatar
United States, GA, Dalton
Joined Jul 2012
http://www.headsuphobby.com/GWS-SLOW...RED-GWS103.htm This should help you find a motor, esc and servos props and batteries. Lane
Laneritc is offline Find More Posts by Laneritc
Latest blog entry: Radian Sailplane, next project
Old Jul 13, 2014, 04:40 PM
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
Answered this exact question last week.
Simple search should bring it up
1320fastback is offline Find More Posts by 1320fastback
Old Jul 13, 2014, 06:07 PM
Joined Mar 2003
Thank you Laneritc.
I will talk to my friend about the 120 vac input & only 2 or 3 cells.
Very reasonable items. Many thanks to you.
Do you know if the STICK motor mount will slide on the stick ? We can epoxy or screw on with some right & down offsets ? Or is the plane stabile enough stock assembled ?
Old Jul 13, 2014, 09:06 PM
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
The wing is so big and it flies so slow, a bit of trim is all you need. Drill a hole and bolt it to the
stick.
Kimber is online now Find More Posts by Kimber
Old Jul 14, 2014, 05:49 AM
Taipei, Taiwan
Joined Oct 2005
I agree with Kimber, It's better to drill a hole and bolt it to the stick boom.
GWS CHEN is offline Find More Posts by GWS CHEN
Old Jul 14, 2014, 08:16 PM
Joined Jul 2014
Right,The wing is so big and it flies so slow, a bit of trim is all you need. Drill a hole and bolt it to the
thingcangoth is offline Find More Posts by thingcangoth
Old Jul 15, 2014, 05:36 AM
Joined Mar 2003
Waaahooo !!!
Thank you aircraft engineers.
As a result of helping my friend with his plane setup.
I will order a plane & the same parts..........
Hi Chen. I hope you are well & still flying. Thank you for helping me with all the GWS military planes.
For Sale GWS BNF, Brushelss Symmetrical Slow Stick & Flat Wing Slow Stick DSW Aircraft - Electric - Airplanes (FS/W) 5 Dec 23, 2013 04:09 PM
Build Log 1/7 Sopwith Camel (Two GWS Slow Sticks for wings) scallan76 Foamies (Scratchbuilt) 60 Dec 10, 2013 05:57 PM
Wanted Gws slow stick brushless power system donho1 Aircraft - Electric - Power Systems (FS/W) 1 Nov 03, 2013 11:56 AM
Wanted Need a 380 esc for gws slow stick Maiden88 Aircraft - General - Radio Equipment (FS/W) 0 Oct 24, 2013 08:41 AM
Question Mount for GWS Mini Slow Stick long flyer Parkflyers 1 Oct 05, 2013 02:43 PM
