Old Jan 19, 2014, 03:58 PM
Blackfw190's Avatar
United States, WA, Newcastle
Joined Aug 2011
Livingroom micro Flying Wing
Hi
Just finished building a pure tail-less swept back flying wing of my own design with dual 4mm motor differential steering. Constructed of 0.8mm carbon rods and 0.5mm rods for the wingtip section, covered with Mylar. The reflex is achieved by twisting and pulling on the wing tips with fine monofilament. Because the tips are made from smaller diameter rods it will flex more than the main spar giving it the necessary reflex in the aft section. There is no rudder.
Initial flights are encouraging, it is much much faster than my original LRF but it also can turn very tight as well. The yaw stability is surprisingly good. It's the pitch moment I need to tweak, I think it needs more reflex.
Haven't weigh it yet but guessing around 5gm... I have not clip the tail boom off yet because later on I might go with a single motor with rudder to make it a floater, but then it won't be a pure flyingwing anymore if I do that...we'll see
Here is a video:
Carbon FlyingWing (0 min 51 sec)
Blackfw190 is offline Find More Posts by Blackfw190
Old Jan 19, 2014, 04:04 PM
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
Neat model Black -- I would be interested in knowing where that model balances.
HerkS is online now Find More Posts by HerkS
Old Jan 19, 2014, 04:54 PM
Blackfw190's Avatar
Joined Aug 2011
Thanks HerkS, the CG is where those two X's are near the receiver. This was determined after glide tests of the bare airframe. The amount of reflex was guesstimated til it "looked good"
Old Jan 19, 2014, 07:57 PM
I love my ID.
Fairfax VA
Joined Aug 2004
Looks quite stable and slow enough to be a lrf. Great job. Is it IR or 2.4?
jingjingjing is offline Find More Posts by jingjingjing
Old Jan 19, 2014, 09:34 PM
Blackfw190's Avatar
Joined Aug 2011
Thanks. It's 2.4, Deltang rx31d receiver.
Old Jan 20, 2014, 10:04 AM
less is more
Knoll53's Avatar
United States, CA, Marina
Joined Sep 2006
Holy Moly Black ! I have lumps of glue that weight more than 5gm! Love the control system. Kinda like retro rockets.
With your high ceilings, I wonder if you could thermal it over a hot patch of ceramic tile ?!......Oh, never mind. I guess you'd need a tail for that.
Clever approach to wing twist. Maybe you could put the wing twist on a servo and have control without power.
I can't imagine how you can create reflex in the airfoil. With wing sweep and wing twist you can get pitch stability with any airfoil.
Considering it's simplicity, it's a fascinating project.
Kent
Knoll53 is online now Find More Posts by Knoll53
Latest blog entry: Nosey
Old Jan 20, 2014, 11:32 AM
Blackfw190's Avatar
Joined Aug 2011
Hi Knol53, 5gm is not impressive at all in the micro LRF world, there are guys that can get it below 3gm!
What kind of seed is that? Does it glide or autorotate like maple seeds? Maybe you can hollow out the center section and put rx and motor in it R/C seed!
Old Jan 20, 2014, 12:17 PM
less is more
Knoll53's Avatar
Joined Sep 2006
It glides....................
Alsomitra macrocarpa
咲くやこの花館 見たことある!?空飛ぶ種子 (0 min 50 sec)
Kent
Old Jan 20, 2014, 02:17 PM
Blackfw190's Avatar
Joined Aug 2011
That's amazing!
Old Jan 20, 2014, 09:20 PM
less is more
Knoll53's Avatar
Joined Sep 2006
I couldn't find the right video, but these seeds are grown in an open bowl, of sorts and at the right time the wind blows them out of the bowl and they are off ! The glide of the seed is part of the trees survival strategy inasmuch as the new seedlings will be far enough away from the mothership to not represent competition for sunlight and other resources.
Cool indeed!
Kent
Old Jan 21, 2014, 07:00 PM
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
If i am remembering correctly, the plant grows on an island that doesn't get much wind, so spinning seeds wouldn't work to get distance from the tree.
derk is offline Find More Posts by derk
Old Jan 24, 2014, 06:44 PM
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Not only do they glide but it appears that when trimmed well that they glide darn well!
Hey Black', I was waiting for you to thread the needle through the opening and come back in via the passageway..... Com'on, I KNOW it's been in the back of your mind....
How long will you be able to keep your flying site clear of furniture?
BMatthews is offline Find More Posts by BMatthews
Old Jan 25, 2014, 02:21 AM
InceCreations
vincent123's Avatar
Joined Jul 2009
Very nice !
Talking about drones ... You just build the ultimate invisible drone !
Vincent
vincent123 is online now Find More Posts by vincent123
Latest blog entry: FZ5: design phase
Old Jan 27, 2014, 10:23 AM
Blackfw190's Avatar
Joined Aug 2011
I have thread that needle several times! First time was accidental with the slow flyer and got lucky, several attempts after that didn't work out
The wife wants to put furnitures in the living room, typical right? But for now I convinced her to keep is as the kids play room, who uses the living room aka airspace anyway?
Old Jan 27, 2014, 10:47 AM
less is more
Knoll53's Avatar
Joined Sep 2006
When I added a 1000 s.f. 2nd floor addition to my house, I first balloon framed the outside walls and put the roof on with no interior walls. What a great indoor flying space it was! Very tempted to leave it that way............
Now I have 3 bedrooms and 2 baths up there and fly in Big Sur.
Kent
Discussion Flying wing from ordinary wing cores Chipped Rotor Flying Wings 26 Nov 29, 2013 07:12 AM
LivingRoom 3D - Micro Kestrel matchlessaero Scratchbuilt Indoor and Micro Models 18 Nov 19, 2005 01:33 PM
