Old Feb 11, 2014, 06:56 PM
AlouetteII's Avatar
United States, KY
Joined Aug 2013
Find your aircraft with Tile?
There is a new (key) locator out there, It's name is Tile.
http://www.thetileapp.com/?utm_sourc...pp&pmt=e&pdv=c
If you are between 50ft and 150ft, with your smartphone, you can find it.
Can we us it to locate a downed aircraft?
http://motherboard.vice.com/blog/sho...cation-tracker
AlouetteII is offline Find More Posts by AlouetteII
Old Feb 11, 2014, 07:09 PM
Unemployed mattress tester
Qwin's Avatar
United States, GA, Kennesaw
Joined May 2011
Depends.
Will you still be lost if 150ft from it?
In many areas, if you are that close, it is no longer lost.
...however, if you came down in a flourishing crop field, you can be two rows over and never find it.
Qwin is online now Find More Posts by Qwin
Old Feb 11, 2014, 10:27 PM
United States, SC, Greenville
Joined May 2012
A lost plane beeper will work farther than that. If its not windy.
chrisdafer is offline Find More Posts by chrisdafer
Old Feb 12, 2014, 01:18 AM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
If my FPV plane is only 150ft away, it's not lost.
For whatever it's worth, I can build a lost model locator out of off the shelf 2.4Ghz FrSky
telemetry components that'll reach out about a mile on stock antennas,
for about $25 on the plane (FrSky 4ch telemetry Rx + 1S lipo), and $55 in hand
(FrSky Tx hack module + telemetry display). Power up only the Rx
with the 1S lipo and it'll sit listening quietly for hours using very little power.
If the plane is lost, power up the Tx module and telemetry display, and simply
following the strongest RSSI signal (or more often the weakest RSSI when using
body blocking). Can put a standard Wifi 12dB Yagi on the Tx for more range and directionality.
I've used this technique for years to find my slope planes in
very rough terrain. Only recently discovered that the Tx module will
still establish a telemetry link with nothing but power (doesn't need PPM input).
Daemon is online now Find More Posts by Daemon
Discussion How to Tile Print with an Apple D W The Builders Workshop 5 Jan 25, 2014 11:22 PM
Discussion Have you 3D printed a part for your aircraft? 3dideaforum Other Websites 0 Dec 23, 2013 09:15 AM
Discussion Tagg Pet tracker in action - always find your plane traderdmb FPV Equipment 2 Dec 18, 2013 05:32 PM
Help! Tile printing with Windows 8 Daz393 Electric Plane Talk 14 Sep 27, 2013 01:20 PM
