Old Mar 31, 2014, 12:40 PM
eletricplanes.com
raphael150's Avatar
Joined Aug 2005
Build Log
Scale build-off 3 - 32" Pitts S1-S
This another addition to this build contest: a 32" Pitts S1-S
Plans were draw in the Dassalt Draftsight software using a 3 view picture and another information that I got from the WEB.
raphael150 is offline Find More Posts by raphael150
Old Mar 31, 2014, 12:47 PM
eletricplanes.com
raphael150's Avatar
Joined Aug 2005
Pitts S1-S
This beautifull biplane will be built in balsa and ply cut in my lasercut machine, and will be covered with 21st Microlite.
The hardware:
Motor: 2826 turning a 10x4 prop
ESC: reprogramed 18-20amp 400hz
Servos: 2x 4.3g (wings) and 2x 9.0g (rudder and elevator)
Batery: 2S 1.500 to 1.800mAh
Old Mar 31, 2014, 01:15 PM
eletricplanes.com
raphael150's Avatar
Joined Aug 2005
Pitts S1-S
I built one smaller version of this model, 21.5" wingspan and, althought it is very tiny and "nervous", it flies very well.
I guess a bigger version would fly better.
Lets find out in the end of this building thread.
Mini pitts flying
Pitts S1S elétrico na praia! (1 min 25 sec)
Enjoy!!
Raphael
Old Mar 31, 2014, 01:54 PM
eletricplanes.com
raphael150's Avatar
Joined Aug 2005
The fuselage is built in two halves direct over the plans. With all these lasercut parts this building becomes easier.
Old Mar 31, 2014, 02:22 PM
Übung macht den Meister..
Deuce's Avatar
United States, OR, Fairview
Joined Jul 2006
James
Deuce is offline Find More Posts by Deuce
Old Mar 31, 2014, 04:53 PM
Samson Brother
rc capo's Avatar
West Palm Beach, FL
Joined Jun 2000
Subbed! Fond of the single cockpit Pitts. Some crop duster pilots flew one nearby when I was a kid. Great plane to watch at airshows in the '70's.
rc
rc capo is online now Find More Posts by rc capo
Old Mar 31, 2014, 09:36 PM
Joined Oct 2003
Subscribed! Looks like an awesome project! I'm a huge fan of the single seat Pitts and Christen Eagle.
redwingsfan71 is offline Find More Posts by redwingsfan71
Old Apr 01, 2014, 09:30 AM
The "pro" in procrastination
Steve85's Avatar
Canada, ON, Kingston
Joined Mar 2004
Looks great, Raphael! I'll add your entry to the Build-Off thread as soon as I get to real computer (I'm using a tiny tablet at the moment).
Steve
Steve85 is online now Find More Posts by Steve85
Old Apr 01, 2014, 06:29 PM
eletricplanes.com
raphael150's Avatar
Joined Aug 2005
Pėtts S1-S
Keep going with the fuselage building...
Old Apr 01, 2014, 06:42 PM
eletricplanes.com
raphael150's Avatar
Joined Aug 2005
Pitts S1-S
Put all the strips in the stabilizer. Cut the fin off and added all the hinges.
This part is done!
Old Apr 01, 2014, 07:44 PM
Joined Oct 2003
Lovin' it...
Old Apr 01, 2014, 08:10 PM
eletricplanes.com
raphael150's Avatar
Joined Aug 2005
Landing Gear
The landing gear is made of 2.38mm and the shock absorber is 1.0mm steel.
It is attached to the ply former by a kite tread and white glue.
Old Apr 01, 2014, 08:15 PM
eletricplanes.com
raphael150's Avatar
Joined Aug 2005
Fuselage is almost ready
Now the fuselage is almost finished, just in need of the 1/32" balsa sheet covering in the front part.
Old Apr 01, 2014, 08:29 PM
eletricplanes.com
raphael150's Avatar
Joined Aug 2005
Cowl
Cowl is made of 3 formers and lots of balsa strips covered with 1/32" balsa sheet.
Nose block is made of 8 round pieces of balsa glued together. Very light and strong!
Old Apr 06, 2014, 11:37 AM
eletricplanes.com
raphael150's Avatar
Joined Aug 2005
Continue building...
Now is time to make the upper wing support. It must be exactly the same size as showed in thes plans, this way I can be sure that the wing will be with the right angle.
Contest Scale Build-off 3 Hamburger Flugzebau HFB 320 "Hansa Jet" build Keenan smith RC Airliners (Commercial, Cargo, Troop Carrier) 459 Jul 08, 2014 02:32 AM
Contest Scale Build-Off 3: 1/8 Scale Bellanca Cruisemaster Dennis Sumner Scale Kit/Scratch Built 201 Jun 16, 2014 03:21 PM
Build Log Scale Build-Off 3 Aero A.35 1/12 scale 47-5/8" Otakar Scale Kit/Scratch Built 43 May 18, 2014 07:16 PM
Contest Scale build-off 3 - 66" T-6 Texan II reaper31 Scale Kit/Scratch Built 11 May 09, 2014 02:54 AM
For Sale 1/3 scale Rowi Modellbau Pitts S1 mmclaug858 Aircraft - Fuel - Airplanes (FS/W) 1 Apr 16, 2012 03:18 PM
