Old Sep 15, 2013, 11:50 AM
VinceHaworth's Avatar
United Kingdom, England, Lancs
Joined Apr 2005
Build Log
Sure Flite Super EyeSoar
I managed to pickup a kit for the Super EyeSoar on ebay a while back.
It will be modified with a brushless motor, landing wheel and spoilers.
Basic specs
108 inch span wing, 957 sq inch, 54 inch long
Equipment list
75mm foam wheel
50mm headless folding spinner
gold-n-rod snakes
servos;
TGY-390V HV Metal gear Coreless Digital Servo w/ Heat Sink 5.4kg / .11sec / 22.5g
http://www.hobbyking.com/hobbyking/s...dProduct=29348
Tunigy Glider Drive
http://www.hobbyking.com/hobbyking/s...dProduct=42046
Specs:
Turns: 14T
Voltage: 3~4S Lipoly
RPM/V: 960kv
Motor Poles: 14
Internal resistance: 0.045 Ohm
Max Loading: 35A
Max Power: 510W
Shaft Diameter: 5mm
Shaft Length: 20mm
Mounting screw Spacing: 25mm (M3x4)
Connector: 3.5mm bullet
Weight: 142g
Turnigy 40 amp ESC
http://www.hobbyking.com/hobbyking/s...dProduct=32432
covering film, transparent purple (modena 205)
http://www.hobbyking.com/hobbyking/s...idProduct=6742
VinceHaworth is offline Find More Posts by VinceHaworth
Old Sep 15, 2013, 11:54 AM
Joined Apr 2005
The wing was originally polyhedral but I am changing mine to tip dihedral. Joiners for the wing will be a carbon rod and a carbon tube. Hence the wing centre section will straight.
Not seen any pictures of this model before so there cannot be many about.
Old Sep 26, 2013, 08:50 AM
Joined Apr 2005
more photo's
Old Nov 10, 2013, 04:38 PM
Joined Apr 2005
The covering is done and the electrics are in. Test flight soon.
Old Nov 23, 2013, 11:38 AM
Joined Apr 2005
First flight today, flew great. Just need throw on rudder and elevator reducing slightly.
For Sale Sure Flite Spitfire Tahoed Aircraft - Electric - Airplanes (FS/W) 0 May 16, 2013 11:52 AM
For Sale P 39 Airacobra by Sure Flite Vintage Kit Frank Klenk Aircraft - Fuel - Airplanes (FS/W) 1 Feb 22, 2013 09:18 AM
Discussion Sure Flite Baby Birdie Fatherof4 Glow to Electric Conversions 11 Jan 10, 2013 08:12 AM
Discussion Sure Flite Baby Birdie Fatherof4 Power Systems 3 Jan 04, 2013 12:45 PM
Sold Sure Flite Products - Super Eye Soar kzimmerm Aircraft - Sailplanes (FS/W) 7 Nov 01, 2007 02:52 PM
