Old Yesterday, 06:56 AM
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Originally Posted by Gharddog03 View Post
Finishing up my GRXL. Need to find another prop adapter or buy different props. My master airscrews don't fit on my rc timer 1760kv!!
Good looking plane, it should be really visible against the sky or clouds.
Lee
Lee is offline Find More Posts by Lee
Old Yesterday, 06:59 AM
Ground Pounder
Gharddog03's Avatar
United States, CA, Fresno
Joined Nov 2012
Lee
Thanks Lee. Killer design!!
Gharddog03 is online now Find More Posts by Gharddog03
Old Yesterday, 09:22 AM
United States, CA, Elk Grove
Joined Jun 2013
Nice job Dog, yes tough to get Master over 5 mm adaoter, had to drill out Scimitar to fit
Rdimand is online now Find More Posts by Rdimand
Old Yesterday, 10:29 AM
Ground Pounder
Gharddog03's Avatar
Joined Nov 2012
Thank you. I had to drill out the prop. I'll instill the batter bay and hopefully maiden soon!
Old Yesterday, 10:14 PM
United States, UT, Herriman
Joined Jan 2012
I have a GRXL here ready to start building on. I want to set it up for FPV and would like to aim for 20min flight times with minimal weight. So I want to avoid just strapping more batteries on for endurance.
The obvious thing to do is minimize drag, so trying to keep all the bits inside will be a goal. Nice smooth surface for the airflow.
The part I'm less sure about is the power system. In general, am I better off with a longer prop and lower KV motor to match? I was considering the NTM3536 1400KV with a 10 or 11 inch prop. I would probably get a few pitches to put on the wattmeter to check before flight and use a current sensor durring flight to verify performance vs consumption. I'm willing to spend a bit more on the motor if it helps noticeably with efficiency. I'm just familiar with that one.
As it's for FPV, I don't need to have a speed demon. I want enough thrust to make launching reasonably easy and have an OK climb rate, say, 30 degrees. No unlimited vertical etc. needed. But still able to cruise around without killing batteries.
Keeping the weight down is a bit of a challenge to myself. I keep building heavy, so I want to try the other side this time.
ttabbal is offline Find More Posts by ttabbal
Old Yesterday, 10:50 PM
foobly's Avatar
United States, TX
Joined May 2014
Gharddog03
Nice looking plane you have there!
foobly is offline Find More Posts by foobly
Old Yesterday, 10:58 PM
Ground Pounder
Gharddog03's Avatar
Joined Nov 2012
Originally Posted by foobly View Post
Gharddog03
Thank you.
Drilled out the prop and batteries installed. Ready for maiden!!
Sold Reaper GR60 Stagger_Wing Aircraft - Electric - Power Systems (FS/W) 0 Jan 13, 2010 01:43 AM
Sold Reaper GR 60 wrpsr1911 Aircraft - Electric - Power Systems (FS/W) 0 Jan 06, 2010 09:28 PM
Build Log House of Balsa "Grim Reaper" P51 Mustang Gun Jam Electric Warbirds 28 Dec 20, 2009 03:25 PM
Discussion Body count... Grim but it's really gotta be done. Bilbobaker Life, The Universe, and Politics 15 Nov 15, 2009 01:09 PM
Gallery Grim reaper Wickett R/C Pumpkin Contest 1 Oct 31, 2005 04:37 PM
