Old Sep 21, 2009, 02:27 PM
PH.D in Scratchbuilding
Denmark, Region Zealand, Holbaek
Joined Sep 2005
Build Log
Clausxpf, F-8 Crusader, Alpha-build
Yesterday clausxpf presented his new design/CAD of the F-8 Crusader and asked if anyone would do the alpha-build. I couldn't resist.... so here goes.
Claus printed the templates for me last Tuesday and on Wednesday I started to cut the parts. I'm making it from a laminate of a 8 mm shell xps-foam with glass on both sides. Lenght: 140 cm, wingspan: 90 cm, weight: still unknown. Powered by a WM400 MRK 2 using a Velocity B29-56 on 6s lipo.
Pics will tell the story better than words.
jweber009 is offline Find More Posts by jweber009
Old Sep 21, 2009, 03:52 PM
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
building and develloping the F-8
Jonas almost ripped the drawings out of my hand ..
but the speed he have cut with .. some development is still on the table.
To have the wing tilt for landing for one...
I had to cut a model myself to make sure i had enough space for that action.
clausxpf is offline Find More Posts by clausxpf
Old Sep 21, 2009, 06:14 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
nice guys i'll be watching .while im sanding the Draken and getting it ready to paint
AIR SALLY is offline Find More Posts by AIR SALLY
Old Sep 27, 2009, 01:11 PM
Joined Sep 2005
The first half is now ready for sanding. I will glass it on the inside first. One half at a time. Then join the two half's and glass the outside.
Old Sep 27, 2009, 09:15 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
that is some nice hot wire cutting very well done
Old Oct 05, 2009, 05:10 AM
Joined Sep 2005
More progress
Last night I got the other half glued.....
Next step is to sand and glass the inside.
Old Oct 05, 2009, 02:45 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
what are you using for glue to bond the sections together?
Old Oct 05, 2009, 04:39 PM
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
rodger...
that is PU glue ( gorilla glue ) mixed with light spartle..
it is like the foam to sand then . normal it is mixed 1/3 glue to 2/3 light spartle.
it is the orange bottle and yellow can with blue top. the mix is by volume.
Claus .
Old Oct 05, 2009, 05:50 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
thanks i'll have to try that.should sand nicely
Old Oct 06, 2009, 03:17 AM
michaelghammer's Avatar
Denmark
Joined Dec 2004
Looking great so far.
May I ask where you buy the XPS foam in Denmark?
- Michael Hammer
michaelghammer is offline Find More Posts by michaelghammer
Old Oct 07, 2009, 03:33 PM
Joined Sep 2005
Hi Michael
This xps foam is made by Sundolitt. They have a dealer list on their homepage: http://www.sundolitt.dk/default.asp?menu=467&view=
Old Oct 12, 2009, 06:10 AM
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Originally Posted by clausxpf
rodger...
Claus .
Spartle? Is that anything like spackle?
TIA Claus
GregG is online now Find More Posts by GregG
Old Oct 12, 2009, 06:49 AM
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
might be me spelling it wrong...
it is Polyfilla superlight based on microballons, and white waterbased glue.
Claus
Old Oct 12, 2009, 10:39 AM
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Your spelling was close enough to spackle, that is why I asked. Many modelors use it to fill areas before finishing thier creations.
Spackle is a product made to fill holes in walls before painting. Is that what Polyfilla is used for?
Now knowing that I'll bet that one could mix up a batch of microballons, white water based glue, and Gorilla glue that would do just about the same thing. Anyway, thanks for the tip Claus!
Old Oct 12, 2009, 02:16 PM
Joined Sep 2005
GregG: You are right about the spackle. Didn't notice it myself because the danish word for spackle is "spartel". Mix this with the english word you get "spartle".
Discussion F-8 Crusader jetset44 style build with Video agriebel Pusher Prop Jet Models 284 Aug 12, 2009 07:32 AM
"Last of the Gunfighters" F-8 Crusader Fanfold Pusher J Morgan Pusher Prop Jet Models 188 Sep 04, 2008 06:39 AM
For Sale Enlarged Berkeley F-8 Crusader St. Martin Aircraft - Electric - Jets (FS/W) 4 Aug 15, 2006 05:00 AM
F-8 Crusader jets Electric Ducted Fan Jet Talk 1 Sep 27, 2005 06:11 PM
F-8 Crusader For MF-480 R&D... DirtNap Electric Ducted Fan Jet Talk 8 Jul 24, 2004 08:51 AM
