Old Jan 29, 2016, 01:51 AM
mopetista is offline
Find More Posts by mopetista
Vienna, Austria
Joined Apr 2007
new Freewing 70mm 12-blade PLASTIC fan
looks like the smaller 64mm version: lower pitch than your typical Change Sun type fans, and good value, too
http://www.rc-castle.com/index.php?r...roduct_id=5722
single rotor also available
http://www.rc-castle.com/index.php?r...roduct_id=5723
might be a lower load than the CS fans, have not tried it yet
EDIT: combos available
4s: 56A, 180g total weight, motor integrated in housing, this one is used in the 4s version of the Yak-130
http://www.rc-castle.com/index.php?r...roduct_id=5811
6s: 59A, 210g total weight, big heavy motor with standoff, NOT used in the 6s version of the Yak, I guess because of the weight and room aft of the fan unit needed for the long motor, all behind the shroud due to standoff
http://www.rc-castle.com/index.php?r...roduct_id=5812
EDIT: Just got my 4s PNP Freewing Yak-130 - sports exactly that combo (2850kV motor, 12-blade fan). Balancing wasn't great, so I took it apart - motor weighs 107g (112g with the 4mm connectors), kV measured: 2805, motor has 8 poles (magnets in the bell)m motor ran pretty quiet, so I did not bother to get a better balance.
mopetista is offline Find More Posts by mopetista
Old Jan 29, 2016, 11:20 AM
ex-racr is offline
Find More Posts by ex-racr
AKA Terry Till
ex-racr's Avatar
Alexandria, VA
Joined Apr 2002
I just ordered a couple, along with some other stuff. Really hoping the motor tube is 30mm I.D.
ex-racr is offline Find More Posts by ex-racr
Old Jan 30, 2016, 01:38 AM
AntDX316 is offline
Find More Posts by AntDX316
AntDX316's Avatar
Joined Sep 2014
I went 14.
http://www.hobby-paradise.com/en/pro...ct_detail.html
http://x-flight.com.hk/index.php?p=6&id=167
http://www.hobbyking.com/hobbyking/s...arehouse_.html
http://www.hobbyking.com/hobbyking/s...=5000%20a-spec
8mm Castle for 300A
http://www.ebay.com/itm/Castle-Creat...QAAOxye2lSXxJz
For my A10 EDF.
Had to bbq stick the wings. How I fly they break in mid air. The spar it came with broke easy on not even a high speed vertical.
AntDX316 is offline Find More Posts by AntDX316
Old Feb 05, 2016, 02:02 PM
flylow2011 is offline
Find More Posts by flylow2011
Joined Nov 2011
do you have experience with Freewing 12 blade 64mm fan ?
like Freewing 64mm 12 Blade EDF 3300Kv For 4S
Is the fan factory balanced ? Thanks
http://www.rc-castle.com/index.php?r...roduct_id=4829
flylow2011 is offline Find More Posts by flylow2011
Old Feb 05, 2016, 02:36 PM
Vienna, Austria
Joined Apr 2007
no, I don't (usually buy motors and fans separately) - but why not post your question in the appropriate thread
http://www.rcgroups.com/forums/showthread.php?t=2373839
Old Mar 17, 2016, 01:59 PM
Vienna, Austria
Joined Apr 2007
back to topic: FREEWING 12-blade plastic fan
combos available at RC Castle, and it is not even claimed that they would be dynamically balanced
The 4s version comes with the 4s Freewing Yak, 56A at 4s claimed, that's a nice amp draw for lipos from 2700mA to 3300mA IMO
the 6s version uses a bigger, heavier motor with a standoff, 59A at 6s, that is some power!
(first post of the thread updated with this info)
Old Mar 18, 2016, 04:03 PM
Vienna, Austria
Joined Apr 2007
data on the 4s version
Just got my 4s PNP Freewing Yak-130 - sports exactly that combo (2850kV motor, 12-blade fan). Balancing wasn't great, so I took it apart - motor weighs 107g (112g with the 4mm connectors), kV measured: 2805Kv, motor has 8 poles (i.e., magnets in the bell). Motor bell of hte outrunner is pretty nicely balanced so I didn't bother to get a better balance.
Old Mar 19, 2016, 08:46 PM
Hugo Flynow is online now
Find More Posts by Hugo Flynow
Fond of Foam
Hugo Flynow's Avatar
United States, MD, Ridge
Joined Oct 2015
I talked for a while with a rep at MotionRC and asked about the 12 blade fan. He said it makes a quiter whoosh sound but doesn't have as much thrust as the stock fan. also draws more amps he said.
Hugo Flynow is online now Find More Posts by Hugo Flynow
Old Mar 20, 2016, 01:43 AM
Vienna, Austria
Joined Apr 2007
which versions did he compare? probably the 6s versions, as there is no "official" 4s 6-blade in the new models as stock, only the low amp 6s version.
I guess the 4s 12-blade version is not bad for what it is, some 60A on 4s, of course that is not as powerful as the 6s 6-blader (>45A on 6s I think).
The motors of the two setups are about the same size. Since the 12-blader is a higher load, you cannot have the same power with the same efficiency - you would need a bigger, heavier, torquier motor. That is why the really powerful 6s 12-blade version has such a honking motor.
That being said, the 4s setup seems pretty good for what it is, but not as powerful as the 6s 6-blade setup, at the same weight.
In the 70mm Yak-130 thread you will find videos of "lordmureth" flying the 4s stock version with the 12-blade fan, e.g.
Freewaing Yak 130 versus tree and lamppost = WINS! (2 min 26 sec)
Old Mar 20, 2016, 12:21 PM
Fond of Foam
Joined Oct 2015
He was comparing the 4S version 12 blade vs stock 6 blade....( or was it 5) crap I forget...
Old Mar 21, 2016, 02:17 PM
Vienna, Austria
Joined Apr 2007
not enthusiastic about the fans...
balanced two Freewing 12-bladers:
- the unit with the 107g 2849 2850kV motor (my kV meter says 2805kV), with the 8-stator housing
- a 90g 2550kV motor (from the EPS T-50 Unique models), using only the 12-blade rotor, and the standard 4-stator Freewing shroud, even the adapter from the standard Freewing 6-blader, it fits
The front bearing of the Freewing 2849 motor is loose, but when I got some really good balancing, it did not seem an issue anymore. However the sound is no way near as wooshy as with the Change Sun fans (balanced a 12-blader and a 10-blader just now, too) in both the 8-stator and the 4-stator housings, especially in lower rpm when doing the balancing. It remains to be seen (I mean, heard) how the Freewing fans sound in the model, with good balancing, in the one Yak video I linked above you cannot tell what is vibrational noise and w
what is fan noise per se.
FWIW, I would not recommend them - I got the one with my Freewing Yak, and I just bought three rotors because they are so cheap and let me use both the Freewing shrouds I would otherwise throw away (since I do not like the sound of the Freewing 6-bladers).
Another reason is that I can use motors with a kV which is a bit too high (for my taste) for using with Change Sun fans (the Freewing fan is a bit of a lighter load, probably due to the low pitch a the blade tips, which might be more effective in the boundary layer, according to Stuart Maxwell (the air in the boundary layer is moving more slowly, so lower pitch is better - or bigger blade clearance, sic)
For Sale Freewing Fan Units 12 Blade ALL NEW MAMBA2200 Aircraft - Electric - Jets (FS/W) 0 Dec 22, 2015 03:19 PM
Wanted Freewing 70mm 12 Blade Metal EDF Complete Set Mephalis2009 Aircraft - Electric - Jets (FS/W) 0 Oct 17, 2015 01:43 AM
Sold Windrider 70mm Ducted Fan F-35 Kit Motor/12 blade fan / scale landing gear kclements Aircraft - Electric - Jets (FS/W) 15 Nov 17, 2014 11:20 AM
Sold Brand New Never Used Freewing 12 Blade 80mm Metal Fan, ESC and BEC Combo ****$100**** leemkl06 Aircraft - Electric - Jets (FS/W) 3 Mar 16, 2014 02:21 AM
Sold Brand New Never Used Freewing 12 Blade 90mm Metal Fan, ESC and BEC Combo ****$130**** leemkl06 Aircraft - Electric - Jets (FS/W) 2 Jan 24, 2014 08:23 PM
