Old Jan 24, 2016, 02:20 PM
Apollomark is offline
Find More Posts by Apollomark
United Kingdom, Lincs
Joined Nov 2015
Dag 60 covering material
Hello
I will soon be ready to start covering the airframe of my Dag 60. In the past I have used solar film as a covering material. Does anyone know wether or not solar span would be a better choice as I understand it is a bit tougher and longer lasting.
I appreciate any thoughts, thanks
Mark.
Apollomark is offline Find More Posts by Apollomark
Old Jan 24, 2016, 04:13 PM
106flyer is offline
Find More Posts by 106flyer
106flyer's Avatar
Joined Jan 2013
If I want a bit more strength yes I use span .. Also it's my covering of choice for blades
Steve
106flyer is offline Find More Posts by 106flyer
Old Jan 25, 2016, 01:15 AM
Joined Nov 2015
Thanks for that Steve, I'll give it a try. Hope I can get all of the colours I want in solar span.
Mark.
Old Jan 25, 2016, 06:40 AM
106flyer is offline
106flyer's Avatar
Joined Jan 2013
The other thing is Hobby King covering... it looked cheap but i decided to give a roll of white a go to compare with others ... At 11 for a 5m roll (+p&P) I was not sure..
I have to say it was great, quite thick needing more heat but goes on fine and does not seem to suffer relaxation .. might be worth considering - with Oracover for example at 15 to 20 for a 2m roll the HK stuff seems worthy of consideration...
Old Jan 25, 2016, 11:25 AM
SafeLandings is offline
Find More Posts by SafeLandings
It was a GLITCH! Honestly!
SafeLandings's Avatar
Stourport on Severn ,Worcestershire, United Kingdom
Joined Dec 2007
Mark,
Mine is covered in solartex which I think is more in character with its 30's look. A little more expensive I know but it is 8 years old now and still looks half decent.
Rich
SafeLandings is offline Find More Posts by SafeLandings
Old Jan 25, 2016, 03:54 PM
Joined Nov 2015
Thanks both for the advice I do appreciate it, I'll check out the Hobby King covering. Do you have to fuel proof Solartex with a clear varnish of some sort?
Mark.
Old Jan 25, 2016, 05:05 PM
Graham L is offline
Find More Posts by Graham L
Joined Jul 2014
Hi Appollomark.
The DAG looks great in Solartex and it is completely fuelproof although some swear by a coat of fuel proofer which makes it easier to clean. - just make sure you seal down the edges well. If you want a more transparent look use the Solartex antique.
Graham
Graham L is offline Find More Posts by Graham L
Old Jan 25, 2016, 09:08 PM
bdoxey is offline
Find More Posts by bdoxey
United States, AL, Birmingham
Joined Nov 2013
I used Solartex for the first time on my now nearly finished DAG 60. As everyone above says, it looks great and should be quite durable.
Another big plus is how it shrinks. There are considerable compound curves on the DAG which results in a lot of "extra" fabric when you are trying to lay it on the fuselage to tack it down. I was amazed at how all of the extra fabric shrunk totally tight on all the curves of the DAG. I found it incredibly easy to work with. Also, it takes paint very well for trim. I used spray can Rustoleum and it came out great.
I am planning on a clear coat to help keep it clean. Not required but it makes cleanup much easier as the weave tends to pick up some dirt and oil.
Bryan
bdoxey is offline Find More Posts by bdoxey
Old Jan 26, 2016, 01:16 AM
Joined Nov 2015
I do like the look of the antique Solartex, I've seen pictures of a Dag covered in Red and antique Solartex and it looks great. My only reservation is how well it shows up in the sky?
Thankyou for your help
Mark.
Old Jan 30, 2016, 10:23 PM
Sofaman NJ is offline
Find More Posts by Sofaman NJ
The 1st Sofaman
Sofaman NJ's Avatar
United States, NJ, Hawthorne
Joined Mar 2012
You have done such an amazing, clean, crisp build.
If there is anything you need, just ask.
Dave
Sofaman NJ is offline Find More Posts by Sofaman NJ
Old Feb 01, 2016, 01:06 AM
Joined Nov 2015
Thanks Dave
Been making steady progress on the build, I've looked at the build threads here on RC Groups for help but I'm sure I'll need to be in touch about something soon
Cheers
Mark.
Old Feb 01, 2016, 03:14 AM
Gyrocopter is offline
Find More Posts by Gyrocopter
What could possibly go wrong!!
In Bedfordshire, UK.
Joined Oct 2008
Hi Mark,
I covered my DAG and enlarged DAG in Solartex, it worked well and is still in good condition. Good luck with your build
Chas
Gyrocopter is offline Find More Posts by Gyrocopter
Old Feb 02, 2016, 01:05 AM
Joined Nov 2015
Hello Chas
Two great looking models, how easy does the antique colour show up in the sky? Did you clearcoat on top of the covering or leave it untreated?
Mark.
Old Feb 02, 2016, 04:50 AM
Joined Oct 2008
Mark
The antique shows up pretty well in the sky but as orientation tends to be an issue with AGs you do need to keep them fairly close in. I used clear cote on the bulkhead and partly along the bottom but providing the exhaust is directed away from the fuselage sides it's ok
Chas
Discussion Dag 60 advice Apollomark Auto Gyros 22 Feb 22, 2016 11:52 AM
Question DAG 60 Question bdoxey Auto Gyros 7 Feb 17, 2016 07:23 PM
Help! Dag 60 Blade profile Apollomark Auto Gyros 4 Jan 30, 2016 10:31 PM
Sold Dag 60 autogyro amilcar Aircraft - Fuel - Airplanes (FS/W) 3 Jun 12, 2014 01:12 PM
Discussion covering material he called dope in the 60's tradeprog Vintage & Old-Timer Designs 31 Nov 27, 2012 06:01 AM
