Old Dec 22, 2015, 10:34 PM
camoy is offline
Find More Posts by camoy
I can't fly
camoy's Avatar
United States, CO, Parker
Joined Dec 2006
Lets see that is about 15-25 seconds more than i can do so I think you are pretty good.
camoy is offline Find More Posts by camoy
Old Dec 22, 2015, 10:35 PM
msgnfg is offline
Find More Posts by msgnfg
msgnfg's Avatar
United States, CA, Elk Grove
Joined Jun 2014
I think that's good hover time. Mine are shorter now, but mostly because I'm working on torque rolls. Still working on the muscule memory when the canopy is facing away.
msgnfg is offline Find More Posts by msgnfg
Old Dec 24, 2015, 05:13 AM
mathursharad is offline
Find More Posts by mathursharad
United States, MA, Framingham
Joined Sep 2010
Those who have been replacing the landing gear with 1/8 inch piano wire. How did you cut the wire? Looks really thick.
mathursharad is offline Find More Posts by mathursharad
Old Dec 24, 2015, 09:00 AM
Eagle2Nitro is offline
Find More Posts by Eagle2Nitro
Extremely Twisted
Eagle2Nitro's Avatar
United States, LA
Joined Apr 2014
I've found the easiest way to cut piano wire is to use a Dremel with a cutting disk.
Eagle2Nitro is offline Find More Posts by Eagle2Nitro
Old Dec 24, 2015, 09:01 AM
CC268 is offline
Find More Posts by CC268
United States, AZ, Cave Creek
Joined Aug 2011
Just curious...how do you replace the landing gear when it is epoxied in pretty good...?
CC268 is offline Find More Posts by CC268
Old Dec 24, 2015, 10:05 AM
bhoov128 is online now
Find More Posts by bhoov128
Genesis 50:20
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
some big side cutters and a lot of pressure difficult
probably should use dremel with cutoff wheel like E2N suggests
bhoov128 is online now Find More Posts by bhoov128
Latest blog entry: Snice Slick
Old Dec 24, 2015, 11:53 AM
FM is online now
FM
Find More Posts by FM
FM
No Static
FM's Avatar
United States, AZ, Gilbert
Joined Mar 2012
Steve t told me a great way to do that. Use a drill and take your time drilling multiple holes. Easy peasy. ..took about 15 minutes.
FM is online now Find More Posts by FM
Old Dec 24, 2015, 02:10 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
And...as has been posted many times in this forum...Don't epoxy the darn gear in in the first place. Install gear, install wedge, install two screws through formers/wedge holding gear in... Voila!! Gear installed...
SteveT.
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Dec 24, 2015, 04:05 PM
CC268 is offline
Joined Aug 2011
SteveT.
Mine was bought used. I didn't build the plane. But yes if I built this myself I would not have glued it either.
Old Dec 24, 2015, 04:23 PM
FM is online now
FM
FM
No Static
FM's Avatar
Joined Mar 2012
I did epoxy mine....no big deal to drill it out and do it the better way. Now I know to check the forums before assembly. Just another lesson with this hobby!
Old Dec 29, 2015, 01:55 PM
msgnfg is offline
msgnfg's Avatar
Joined Jun 2014
Do any of you fly the KnifeEdge version of this plane on RealFlight? I'm struggling with part of the setup. Specifically she constantly rolls out of KE as if the wing had a dihedral. Too much to try and mix out without creating other problems.
New Product 3DHS 41" Edge "$99 Buck Huck" Ducati Mechanic 3D Flying 17299 Mar 27, 2012 04:37 PM
Sold 3dhs 41' edge buck huck bnf JBuck Aircraft - Electric - Airplanes (FS/W) 7 Jul 02, 2011 07:58 AM
Sold 3DHS 41" EDGE - ORANGE - 99 Buck Huck 6L6Amp Aircraft - Electric - Airplanes (FS/W) 14 Aug 22, 2010 08:45 PM
