Old Dec 20, 2014, 03:16 PM
United Kingdom, Wales
Joined Jul 2009
motor/watts question
Hi all, newbie electric question. When e.g. a 300w motor is classed to be used by a 2cell or a 3cell lipo, as the volts are different, does the current change up/down to maintain the 300watts stated. Hope I have put this question correctly. I realize the rpm of prop will change as the kv changes. Thanks
Fly Boy3 is offline Find More Posts by Fly Boy3
Old Dec 20, 2014, 03:26 PM
STOP! I can't take any more.
Rhea's Avatar
United States, MN, Eden Prairie
Joined Oct 2008
The watts will only be realized by the load put on the motor. Don’t expect to see 300 watts just because the motor is labeled such. The 300 watts spec. is a maximum limit you should allow with the voltage and prop size you select.
Is there something more behind this question; do you have a concern that you may be running a motor too hard?
David
Rhea is offline Find More Posts by Rhea
Old Dec 20, 2014, 03:32 PM
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Assuming the prop is not changed the current will go up when the battery is changed from a 2 cell to a 3 cell.
The watts will also go up when the battery voltage is increased. BTW motor watts is not a fixed value. It is a value that should not be exceeded. Watts will vary depending on the battery voltage and the prop size.
In order to keep from exceeding the wattage limit of a motor when the battery voltage is increased the prop size must be reduced.
The kv will not change. The kv is a fixed value. It is set when the motor is built.
Glen
ggcrandall1 is online now Find More Posts by ggcrandall1
Old Dec 20, 2014, 03:38 PM
yank and bank!!
Joined May 2013
I'll try to answer your question based on what I think you're asking.... if you find props that result in 300 watts input in 2 and 3 cell operation for the same motor, the 2 cell CURRENT will be significantly higher.... in fact, if the setup were perfectly efficient, the 2 cell setup would draw 50% more current.
failboat is offline Find More Posts by failboat
Old Dec 20, 2014, 03:57 PM
Joined Jul 2009
Thanks all, every answer gave me a better insight to the meaning of the word Watts.
Rhea, one of my concerns was the size of my ESC. Bit worried if I may cook it by using 2s instead of 3s. Thanks to all again.
Old Dec 20, 2014, 03:58 PM
USA, GA, Marietta
Joined Aug 2005
For a given motor and prop you cannot realize 300 watts from both a 2S and a 3S battery.
Glen
Old Dec 20, 2014, 04:07 PM
Joensuu, Finland
Joined Mar 2002
Glen
Obviously, the prop for 2s would be different than the prop for 3s.
Sorry for nit-picking.
jkettu is online now Find More Posts by jkettu
Old Dec 20, 2014, 04:30 PM
yank and bank!!
Joined May 2013
Old Dec 20, 2014, 04:32 PM
yank and bank!!
Joined May 2013
Glen
With the right gearbox it could be done
Old Dec 20, 2014, 04:48 PM
Joined Jul 2009
just one more from a newbie if you don't mind. If I change from a 3s to a 2s without changeing the prop size, will I have less revs. ? Thanks
Old Dec 20, 2014, 05:28 PM
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
Yes
Pete
pilotpete2 is online now Find More Posts by pilotpete2
Old Dec 20, 2014, 05:30 PM
yank and bank!!
Joined May 2013
Significantly.... study thrust charts for motors at headsuprc.com and for the cobra rc motors....
Old Dec 20, 2014, 07:49 PM
homo ludens modellisticus
Ron van Sommeren's Avatar
The Netherlands, GE, Nijmegen
Joined Feb 2001
... newbie electric ...
... from a newbie
Do yourself, your equipment and your wallet a big favour ...
For a rainy day(s) ...
E-flight 101 by RCG member Ken Myers, will at least save you a ruined LiPo (or worse!), a burnt motor and a fried ESC:
The Ampeer
-> Electric Power Basics
followed by
The Ampeer
-> Everything youw wanted to know about e-flight (Ed Anderson)
Table of Contents
  • What You Need To Know About Receivers
  • What function goes on which stick?
  • Battery Basics
  • Amps Versus Volts Versus C
  • Lithium Battery Chargers
  • Balance chargers versus external balancers
  • Extending Flight Times While Maintaining Balance (proper CG)
  • Understanding the Electronic Speed Control (ESC)
  • the Low Voltage Cutoff Feature (LVC) Of Your ESC
  • The Role of the Battery Eliminator Circuit in Your ESC (BEC)
  • Sizing Power Systems for Electric Airplanes
  • Prop Versus Amps
  • What Do the Kv Numbers On Motors Mean?
  • Who Needs a Wattmeter/Power Meter? (everyone!, RvS)
www.scriptasylum.com
-> RC calculations
-> electrical
-> system wiring
respectively ...
-> LiPo pack wiring
respectively
-> chargers (2 menu items)
The other menu items and demos are also veeeeery handy/instructive for e-folk, add site to your favourites?
www.ezonemag.com
-> FAQ
Vriendelijke groeten Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Dec 21, 2014, 01:11 AM
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
With the same motor: Just a little bit more than 2/3 the revs, and only 30% of the power. Power required to turn a prop varies with the cube of rpm. rpm varies proportionally to voltage, although losses mean it's not quite linear
scirocco is online now Find More Posts by scirocco
Old Dec 24, 2014, 04:10 PM
Joined Jul 2009
Thanks all, looks if I have some reading to do. LoL. Never mind, the weather is terrible. Cheers
Discussion motot/watts question Fly Boy3 Power Systems 3 Dec 20, 2014 05:31 PM
Discussion 600 Watt ATX Power Supply Mod Question Deeman67 Batteries and Chargers 2 Nov 21, 2014 06:36 PM
Discussion Watt Question jakebfpv Power Systems 5 Oct 17, 2014 02:03 PM
For Sale Neu Motors 2220/1.5Y 6,400 Watt Motor - New in the Box jgalexander Aircraft - Electric - Power Systems (FS/W) 0 Oct 05, 2014 03:26 AM
Discussion watts up! amp and watt draw questions. jbrracer Power Systems 5 Jun 27, 2014 11:20 PM
