Old Dec 29, 2013, 12:07 AM
Tassie Electric, Heli, Glider
ChrisJ800's Avatar
Hobart, Australia
Joined Oct 2002
New Product
EZUHF JR Module Transmitter
Looks like this will be available in a few weeks and is good for those of us with a Taranis, 9XR or other tx with a JR module bay. Seems like good value and I presume you can use the existing EZUHF receivers including their low cost 4 channel.
From http://www.getfpv.com/ezuhf-jr-module-transmitter.html
Details
A long-awaited module, compatible with most radios which use the 'JR' module standard, including the 9XR, and the new Taranis. Same features as its big brother, but without the cabling, nor external batteries.
Features
500mW of EzUHF Power
JR Module, compatible with the Hobby King 9xR, and the FrSky Taranis
Headtracker port, capable of powering a headset
Highlow power switch
100% compatible with all EzUHF Receivers
Reliable FHSS Link (Frequency Hopping, Spread Spectrum)
433MHz/70cm Ham band operation
GFSK modulation
Standard SMA antenna connector, compatibility with 70cm antennas
Standard USB port for firmware upgrades, and system configuration
Single pushbutton learning of failsafe positions
Binding function, which allows binding Single Tx>Rx, Multi Tx>Rx, and Single Tx>Multi Rx
Mates with all EzUHF receivers
But there’s more, as all EzUHF products feature a USB connector which, in combination with our application software, will allow you to set up your receivers in just the way you like. Mikrokopter mode, the cloning of channels, diagnostics, firmware updates, etc. etc. all available with the click of your mouse or a press of a button, no soldering required, nor any fancy nonstandard cable. Convenient, simple and intuitive, leaving you with more time to enjoy your flying, rather than spending hours or days setting up your equipment.
All of that and many, many more upcoming features which further allow integration of our products and turn the electronics powering your FPV plane into a reliable, rock solid, but above all a plug ‘n fly solution that you get to enjoy every time you fly.
ChrisJ800 is offline Find More Posts by ChrisJ800
Old Dec 30, 2013, 03:39 PM
DJO
Custom FPV Setups
DJO's Avatar
United States, CT, Stafford
Joined Oct 2011
Link you have wasn't working for me, try this:
That's AWESOME though, I literally just ordered a 9X and this could definitely be an option for my in the future if I want to do some longer FPV flying.
Dan
DJO is online now Find More Posts by DJO
Latest blog entry: Home Run Derby & Aerial Shots
Old Dec 30, 2013, 04:16 PM
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
Already on the Email notification list for this baby will go real good with my 9xr :-)
hotdog1 is offline Find More Posts by hotdog1
Old Dec 30, 2013, 04:45 PM
ChrisJ800's Avatar
Hobart, Australia
Joined Oct 2002
Thanks had a stray colon on end of the url, now fixed! It looks like a sweet new module with a good reputation for the other EZUHF gear.
Old Dec 30, 2013, 05:38 PM
United States, TX, Southlake
Joined May 2011
antenna
I placed my order for one at RMRC, does anyone know if they ship with an antenna, or do you need to buy one separately?
sushiman1841 is offline Find More Posts by sushiman1841
Old Dec 30, 2013, 05:40 PM
DJO
Custom FPV Setups
DJO's Avatar
Joined Oct 2011
My guess would be that they will provide, if anything, a small whip antenna, but for any performance you'll want to upgrade to a larger one like a regular UHF system.
Old Dec 30, 2013, 05:58 PM
Joined May 2011
OK! Ill probably order a diamond SRH771 after I receive the unit.
Old Dec 30, 2013, 07:05 PM
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
my regular EZUHF TX did not come with any antenna so i would say not
Sander and Trappy recomend the diamond SRH771 so thats what i use. Ready made rc sells them too
Old Dec 30, 2013, 09:58 PM
satgod's Avatar
United States, KY, Hardin
Joined Jun 2011
100.00 module
123.00 receiver
17.00 antenna
its right about the same price as the dragon link in this config
wow, they are probably about to start making ALOT of sales
satgod is online now Find More Posts by satgod
Old Dec 30, 2013, 11:45 PM
ChrisJ800's Avatar
Hobart, Australia
Joined Oct 2002
Originally Posted by satgod View Post
100.00 module
123.00 receiver
17.00 antenna
Yep and the 4 channel rx is only $70 eg at http://www.readymaderc.com/store/ind...roducts_id=180
And EZUHF won the LRS shoot out done by Flite test/ibcrazy earlier this year.
http://www.youtube.com/watch?feature...&v=dNJzDeYqCSM
Old Dec 31, 2013, 06:41 AM
satgod's Avatar
Joined Jun 2011
yep, watched the video
ez-uhf was just (easy to use)
Dragon-Link had the most rang but 900mhz and 1.3ghz where affect, they recommended 5.8ghz or 2.4ghz for it
They did plug the open-LRS and said it was a good system and worth looking at
this was before the 1watt version I believe, I would love to see them do it again with the 1watt version
Old Dec 31, 2013, 07:03 AM
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
the 2 watt EZUHF is coming soon :-)
Old Jan 01, 2014, 01:35 AM
Joined May 2011
differences
Are there any advantages to getting the module over the regular ezuhf tx? Besides the price? There must be something different if it is 2x the price... Just wanted to know.
Old Jan 02, 2014, 03:26 AM
Slovenia, Ljubljana
Joined Sep 2011
Yes. ezuhf JR module is 500mW.
er9xuser is offline Find More Posts by er9xuser
Old Jan 02, 2014, 01:16 PM
Principal Member
compuatic's Avatar
San Francisco, CA
Joined Jun 2002
The std module is 600mW. Range difference should be negligible.
compuatic is offline Find More Posts by compuatic
Off Site JR 10X ACRO 10 channel transmitter without module crosby Aircraft - General - Radio Equipment (FS/W) 0 Dec 24, 2013 08:59 AM
Wanted [Free] Any JR style transmitter module or just case cmavr8 Aircraft - General - Radio Equipment (FS/W) 2 Dec 15, 2013 06:16 PM
Wanted OrangeRX DSMX/DSM2 Transmitter Module JR TonyTheAsian Aircraft - General - Radio Equipment (FS/W) 0 Dec 15, 2013 01:58 AM
Sold JR 10x PCM S Series transmitter with upgraded battery. Three different modules on fre stick Aircraft - General - Radio Equipment (FS/W) 3 Nov 26, 2013 09:41 PM
Sold JR XP8103 8-ch transmitter w/ DM9 2.4ghz module, 2300mah nimh battery/charger/manual bobzilla Aircraft - General - Radio Equipment (FS/W) 1 Nov 23, 2013 03:32 PM
