Old Feb 19, 2015, 11:41 AM
Joined Feb 2013
Question
How can I reverse the pan direction of Attitude Headtracking?
Hello everyone. As you can see from the video the tilt can control it correctly but the command of the pan is reversed.
Dys Gimbal + Spektrum DX8 + Headtracking test 2 (0 min 27 sec)
How can I reverse the command of the pan? I already tried to reverse the GEAR in the servo's submenu of the radio but does not work.
How can I do?
zippomaker is offline Find More Posts by zippomaker
Old Feb 19, 2015, 03:54 PM
Bombs away! Err...landing
Ira NZ's Avatar
Upper Hutt, New Zealand
Joined Apr 2006
If you can't do it with programming in your TX, you could probably use a servo reverser on the signal line to the gimbal.
http://hobbyking.com/hobbyking/store..._Reverser.html
Ira NZ is offline Find More Posts by Ira NZ
Old Feb 20, 2015, 03:03 AM
www.facebook.com/schumixmd
schumixmd's Avatar
Moldova
Joined Jun 2010
https://www.youtube.com/watch?v=crg5...ature=youtu.be
How can I do?
what tracker module are you using in Attitude?
Trinity could be reversed according manual.
http://www.fatshark.com/uploads/pdf/1748-1.pdf
schumixmd is online now Find More Posts by schumixmd
Sold Fatshark attitude 5.8ghz sd V1 with built in headtracker jpturbotalon FPV Equipment (FS/W) 0 Oct 28, 2014 01:22 PM
Sold Fatshark attitude 5.8ghz sd v1 with headtracker jpturbotalon FPV Equipment (FS/W) 2 Oct 21, 2014 05:24 PM
Discussion 9xr+fatshark attitude...headtracking ?? help pugs2300 FPV Talk 8 Jan 24, 2014 05:19 PM
Discussion Fatshark Attitude Headtracking with Turnigy 9x Reely FPV Talk 3 Sep 13, 2013 11:56 PM
Discussion UPS / FMA Direct - How Will This Pan Out? me_ted2000 Vendor Talk 7 Mar 12, 2009 03:34 AM
