Old Nov 18, 2014, 02:33 AM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
The SMD Codebook seems to indicate "CJ" is a zener diode.
http://www.marsport.org.uk/smd/mainframe.htm
But I don't seem to see a MMBZ4683 with five pins.
davidmc36 is online now Find More Posts by davidmc36
Old Nov 18, 2014, 04:58 PM
Australia, NSW, Sydney
Joined Sep 2011
I found a circuit diagram that could be of use.
Please see attached pdf
I you are able to source the component please let me know.
Possible part No. LP3985IM5X-3.3
szakacs is offline Find More Posts by szakacs
Old Nov 18, 2014, 08:31 PM
United States, CA, Redondo Beach
Joined Jun 2008
Thanks Dave for providing the SMD Codebook. I perused the content and searched for two terms, CJ for the base and SOT23-5 for the packaging and a number of components fell out. They were all voltage regulators and primarily the Low-Dropout (LDO) variety. Now I need to figure out the voltage since the components range from 1.5V to 5V.
The schematic nailed it. Thanks Szakacs! The operational voltage of 3.3V will help me narrow down which LDO regulator I need to buy. The SMD Codebook will give some cross-references. Hopefully, this component will bring these two GPS modules back to life.
Whirligig is offline Find More Posts by Whirligig
Old Nov 25, 2014, 04:12 PM
Joined Sep 2011
Just an update ....
I searched and found a local supplier for part No. LP3985IM5X-3.3. a low-noise ultra LDO CMOS. AUD$5.00 for five items
Received the item yesterday and replaced the faulty regulator and all is GOOD. What was just a piece of junk due to the magic smoke syndrome is now a functioning GPS unit again....I do enjoy the occassional win ...
Old Nov 26, 2014, 11:53 AM
Joined Jun 2008
Just an update ....
That's great! I' m encouraged.
I ordered 5 similar LDO regulators from Mouser yesterday for under $8 US. I'll post an update on the two modules I'll be fixing.
Old Dec 01, 2014, 02:29 AM
South Korea, Seoul
Joined Jul 2014
Hello everyone, I've run into a bit of a problem trying to change the baud rate for my gps serial connection in the config.h. Thing is I changed it to 57600 and now the gps connection is intermittent, it flashes the blue led on and off in my mw board, and also in the GUI it does the same, red to green, intermittently. Anyone else encountered something like this? If so how did you solve it? I was trying to change the baud rate of the gps itself, later on, but found out that the usb to serial cable I have is not FTDI but PL-2303. One final question does removing the gps battery reset it's settings to default? I will try tonight to unplug the gps battery and if that doesn't work I will buy an FTDI adapter. I just don't wanna buy it if the gps itself is done for.
gioesc is offline Find More Posts by gioesc
Old Dec 02, 2014, 01:04 AM
Joined Jun 2008
I received the LDO regulators from Mouser today. I discovered the biggest challenge is de-soldering the old components from the two GPS modules. I failed at both removing some of the trace from the board and ended up with a crappy job of soldering the new components in their place.
I was able to see an intermittent light from the module's LED when I powered up but this was after I fidget with the new component putting pressure here and there.
The repair might have worked if I was more careful removing the old components. I even tried snipping a leg but the kinetic energy from imparted tore off the trace. Maybe the only way to get these things off is a heat gun with a small outlet and some foil to protect the surrounding components. Either way fixing this stuff is not worth it. Time to order the newer MT3339.
Old Dec 02, 2014, 09:34 AM
Austria
Joined Jan 2004
Where can you get a good MT3339 ?
I'm not sure which is the best source for these GPS .. NEO-u-blox are very populare but MT GPS are not easy to find
e_lm_70 is offline Find More Posts by e_lm_70
Old Dec 02, 2014, 10:17 AM
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
Would rather get those new Ulbox m8n gps. Someone is report very good results in the witespy RTFHawk thread.
TheFernMan is online now Find More Posts by TheFernMan
Old Dec 02, 2014, 04:07 PM
Joined Sep 2011
Whirligig .. I do understand your issue. I too found the problem of replacing the regulator an issue.
Because I do not have a smd hot air gun, What I did was instead of trying to desolder the part I used a very sharp blade to apply pressure on and cut through each of the five legs as close to the chip as possible. Then using a good magnifying glass, a bright light and a clean soldering iron, I then heated and removed the remaining leg bits off the pads.
Then with patience and a very small tipped soldering iron I managed to place and solder in the new part.
Old Dec 03, 2014, 02:53 PM
Joined Jun 2008
A reputable source but not cheap would be Adafruit, Pololu, and Sparkfun. You can try searching for MTK3339 or MT333o on Ebay.
I can dust off my my $16 Ublox neo 6m but I think the best update rate is 1hz.
Old Dec 03, 2014, 03:09 PM
Joined Jun 2008
I may have another chance at salvaging these modules, point to point wiring.....
Discussion Hobbyking KK board VS MultiWii for a simple quad? carl1864 Multirotor Talk 7 Jan 03, 2014 02:47 PM
For Sale X250 MWC Quadcopter new MWC Mega with gps, diy kit terriwang Aircraft - Electric - Multirotor (FS/W) 32 Jan 02, 2013 04:17 PM
Discussion Crius NEO-6M Ublox GPS+Nano Mini Board+ Multiwii Control Board I2C GPS Kit godwisper Multirotor Electronics 5 Aug 25, 2012 05:03 AM
Sold Ardupilot mega with compass, GPS and Disto board!!!! tc3wins Aircraft - Electric - Multirotor (FS/W) 4 Jan 02, 2012 04:22 PM
Mini-HowTo Straight USB Connect to MTK 3329 GPS larry baraniuk UAV - Unmanned Aerial Vehicles 8 Apr 17, 2011 11:29 PM
