Old Dec 03, 2012, 01:59 PM
twoplanekid is offline
Find More Posts by twoplanekid
twoplanekid's Avatar
Urbana, Ohio
Joined Feb 2008
Mini Vapor Mods
In order to achieve that best of flight experience and to have fun, I am trying various wing and propeller combinations. My goal is to achieve a more stable flight at slower speeds. A few things were discussed on the regular Min Vapor thread that I thought should be the start of a separate discussion.
One of my old threads on slow/stable flight can be found here ->
http://www.rcgroups.com/forums/showthread.php?t=865438
And here are some pictures of various test designs in progress.
Note- I make changes that can easily be undone
As I broke the prop shaft, I replaced with PKZ3328 (Vapor Prop Shaft w/Gear) and Cessna 210 prop -PkZ3002
twoplanekid is offline Find More Posts by twoplanekid
Old Dec 03, 2012, 08:20 PM
Urbana, Ohio
Joined Feb 2008
So far, the Mini bi is the most fun to fly. The battery keeps the second wing in place if positioned as show in the picture. Now using a Cessna 210 (not Ember) prop which seems to have lots of power!
Old Dec 03, 2012, 08:21 PM
MyPonyRocks is offline
Find More Posts by MyPonyRocks
MyPonyRocks's Avatar
United States, NC, Goldsboro
Joined Mar 2011
HAve you flown any of those yet? I'm interested in how the vaopr stab is working
MyPonyRocks is offline Find More Posts by MyPonyRocks
Old Dec 03, 2012, 09:02 PM
Urbana, Ohio
Joined Feb 2008
Yes! I have flown all of the mods in the above pictures plus some others!
Here is a quick shot of the min bi in flight->
Mini Vapor Biplane mod (1 min 25 sec)
Old Dec 04, 2012, 06:55 PM
boingk is offline
Find More Posts by boingk
boingk's Avatar
NSW, Australia
Joined Feb 2011
Looks good mate!
I've just ordered mine and haven't been able to get any Hyperion cells so will be trialing mine with some 130mAh NanoTech cells and a 40mAh NiMh pack, see here:
http://www.ebay.com.au/itm/271013748...84.m1497.l2649
Cheers - boingk
boingk is offline Find More Posts by boingk
Old Dec 04, 2012, 08:07 PM
Urbana, Ohio
Joined Feb 2008
At least I have not killed anyone. So far I have only broken one prop shaft and a landing gear leg. Don't try this at home unless you are a professional!
Things that don't help the flight qualities of the Mini - will kind of fly ->
Old Dec 07, 2012, 07:02 PM
Urbana, Ohio
Joined Feb 2008
My latest test bed is one using an Ember horizontal stabilizer (PKZ3224) as in the pictures. I use dental floss to secure it to the frame and upper wing. The elevator portion makes an adjustable flap for that real slow flight. The battery wires hold the flap (elevator) in place.
Old Dec 07, 2012, 11:47 PM
boingk is offline
boingk's Avatar
NSW, Australia
Joined Feb 2011
Looks interesting, but weighty.
Personally I'd be experimenting with larger batteries (70~140mAh) and seeing how you can set up the trims and CG for sustained high-alpha.
Had a quick fly around the pub last night after close (I'm a night manager) and found it a hoot! Able to go really slow, as well as speed things up, and spot right down for landings on tables etc.
Cheers - boingk
Old Dec 08, 2012, 08:52 AM
Urbana, Ohio
Joined Feb 2008
Everything is a trade off when working with flight. The Ember horizontal adds about 1.05 grams to the weight. I believe that this is offset by an amount of extra lift and greater stability at high alpha. In fact, you don’t need to fly at as high of angle of attack to achieve the same slow forward speed. The mini bi stalls straight ahead instead of tip stalling or rolling making the recovery easier.
The Night Vapor prop doesn’t work well on the mini. The weight of it is around .9 grams compared to an Ember or Cessna 210 at .45 grams with the mini Vapor prop about .15 grams more. Plus, it sends some air that misses the smaller tail control surfaces on the mini which results in less control. The thrust is not as concentrated.
The weight of the Vapor horizontal is around .62 grams. It doesn't have flaps.
Old Dec 08, 2012, 08:35 PM
Urbana, Ohio
Joined Feb 2008
A video of one test flight ->
Mini Bi Vapor with flaps down (1 min 18 sec)
Old Dec 10, 2012, 12:26 AM
boingk is offline
boingk's Avatar
NSW, Australia
Joined Feb 2011
Used the Mini today with a NanoTech 25C 1s 130mAh battery.
Flew fine, fair bit of extra punch as well. Huge flight times of 20+ minutes.
Cheers - boingk
Old Apr 17, 2013, 07:06 PM
Aileronski is offline
Find More Posts by Aileronski
Joined Mar 2013
Flew the MV outside with the 150maH battery for the champ, it flew for 1/2 hour! Handled the wind very well with that extra bit of weight.
Aileronski is offline Find More Posts by Aileronski
Old Jun 19, 2015, 11:02 PM
felixx is online now
Find More Posts by felixx
crash expert
New Zealand, Canterbury, Christchurch
Joined Apr 2014
I am running 130's in mine (I just got it 2nd hand with some 130's)
It needs 3/4 trottle to stay level, do I move the bigger battery back a bit?
felixx is online now Find More Posts by felixx
Discussion Parkzone Mini-Vapor! Mustang Racer 9 Micro Ready-to-Fly 167 Jun 20, 2015 02:00 AM
New Product Parkzone Mini Vapor Flyboy70 Micro Ready-to-Fly 1736 May 15, 2015 05:53 AM
New Product The New Mini-Vapor minimicrorc Micro Ready-to-Fly 1 Oct 28, 2012 01:26 PM
Discussion New ParkZone Vapor Mini- 8 inch ws HaventFlownSince2014 Atlanta Area RC 4 Oct 25, 2012 08:19 PM
Sold mini LST2 - Brushless Mod + Servo Mod mattgm Cars - Trucks and Parts (FS/W) 1 Jul 22, 2012 06:34 PM
