Old Aug 21, 2015, 10:29 AM
nickden is offline
Find More Posts by nickden
Joined Oct 2012
New Product
Eachine h83d mini 2,4 g 4ch 6- axis inverted flight one mey return rc quadcopter
Banggood introducing the new 3D mini quad can fly inverted and more attractive pirouettes only for 21,99$ FREESHIPING of course .
To get it on the following link
http://www.banggood.com/Eachine-H8-3...147940201303FC
nickden is offline Find More Posts by nickden
Old Aug 22, 2015, 07:26 AM
Jim_W is offline
Find More Posts by Jim_W
Jim
North Alabama
Joined Mar 2004
I wonder if it is the same protocol as the original H8?
Jim_W is offline Find More Posts by Jim_W
Old Aug 22, 2015, 08:48 AM
SoloProFan is online now
Find More Posts by SoloProFan
Did you check the FAQ already?
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
I read in the H8 Mini thread that it wasn't, but soon I should be able to verify.
Transmitter looks a lot like the JJRC H20 Hexacopter one, at least for style and color.
SoloProFan is online now Find More Posts by SoloProFan
Latest blog entry: Pictures of various boats
Old Aug 22, 2015, 09:14 PM
Jim_W is offline
Jim
North Alabama
Joined Mar 2004
Keep us posted. If it is the same and will work with the X9 transmitter, I'm ordering one!
Old Aug 23, 2015, 12:13 PM
nickden is offline
Joined Oct 2012
I'm expecting this soon I post a review although it's so cheap and very interesting item you can order one to check it your self
Old Aug 23, 2015, 01:35 PM
czajunia is offline
Find More Posts by czajunia
czajunia's Avatar
United Kingdom, London
Joined Sep 2014
A little bit out of topic but is anyone getting this Fayee FY801? http://www.rcgroups.com/forums/showthread.php?t=2474334
czajunia is offline Find More Posts by czajunia
Old Aug 28, 2015, 10:32 AM
kaznad is online now
Find More Posts by kaznad
Joined May 2015
No, it is not the same protocol. But the battery is similar. I found that Hubsan X4 battery works great too.
Yes, the H20 transmitter is exactly the same as the H8 mini 3D. You can use it.
This quad is really cool. The quad auto detects if you are right side up or upside down, you can push the throttle and it starts flying. Just had a couple of flights, but so far loving it. It is awesome just like the H8 mini, maybe even better.
kaznad is online now Find More Posts by kaznad
Old Aug 29, 2015, 03:16 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
What is the range you are getting with yours? I got mine earlier today, and range is very limited, just like on the JJRC H20. About 20 to 25 metres at most, which is even less than my range-challenged most recently bought regular H8, that got only 30 metres. For quads that are that fast and agile, and this size, it's unacceptable.
Old Aug 29, 2015, 03:28 PM
ogrope1 is online now
Find More Posts by ogrope1
France, IdF, Paris
Joined Oct 2011
Hey solo are you getting the devo? At least you won't have to worry about range for those that are compatible, the h8 went from never flown to my favorite indoor quad since its been deviated.
ogrope1 is online now Find More Posts by ogrope1
Old Aug 29, 2015, 03:38 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
I have to modify my Devo 7E still, but for the H8 3D that won't help for now, as it uses a different protocol.
Btw, the problem with my regular "range-challenged" H8 was solved by making the antenna stick through the top half of the frame, often called "the antenna mod" simply.
Old Aug 29, 2015, 04:01 PM
France, IdF, Paris
Joined Oct 2011
Yeah a classic, it will soon become a second nature lol. Also checking all antennas are 31mm precisely will help getting optimal range.
Old Aug 29, 2015, 04:09 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Why do quads like the JJ1000 and first H8 Mini, and even a nano like the Bayang Toys X6 manage to get insane range, mostly far beyond the pilot's capability to still see the heading, and recent ones get crashed time after time, unless modded? I've never crashed a quad so many times as the H8 3D, it's size and speed make it get out of range on just a few seconds of straight flight, do they expect me to fly figure 8s within a 10 metres diameter all the time?
Old Aug 29, 2015, 04:16 PM
S.Giles is offline
Find More Posts by S.Giles
United Kingdom, Scunthorpe
Joined Jun 2015
I don't believe it's as simple as that.
31.25mm is the 1/4 wavelength of a 2.4GHz signal in a vacuum.
S.Giles is offline Find More Posts by S.Giles
Old Aug 29, 2015, 05:23 PM
France, IdF, Paris
Joined Oct 2011
I understand, this is just a quick and easy method. If your antena is say 25mm or 35mm it will certainly help to replace or shorten to a 31mm, agreed?
Old Aug 29, 2015, 09:41 PM
Jim_W is offline
Jim
North Alabama
Joined Mar 2004
So, is the yaw rate on this one the same (uselessly fast) as the H8? I wouldn't fly my H8 if it weren't for my X9 xmitter.
New Product Eachine H8 Mini Headless Mode 2.4G 4CH 6 Axis RC Quadcopter Whitehouse Multirotor Talk 157 Today 03:38 AM
Discussion Heli Pad Review Series: Eachine 3D X4 6-Axis Quadcopter capable of "inverted" flight Heli Pad Mini Multirotors 10 Aug 03, 2015 02:40 PM
New Product Auto Return Mini Aircraft Camera 2.4Ghz 6 Axis 4CH Drone HOT-47$+Free Shipping! EachBuyer EachBuyer.com 0 Jun 05, 2015 03:56 AM
Discussion UDI U27 2.4G 4CH 6 Axis Looping Flight RC Quadcopter RTF IKKI Mini Multirotors 1 May 24, 2015 11:01 AM
