Old Aug 11, 2015, 05:17 PM
Martin Turner is offline
Find More Posts by Martin Turner
Joined Feb 2013
3.5m EDF Wing Project
Hey chaps.
Been working hard on an EDF wing design. Spent a long time designing it in sketch-up, and now I am starting to try build this bird.
Might of bitten off more than I can chew, but we will see.
I have been thinking about building a big wing for ages, and I was inspired by this thread.
http://www.rcgroups.com/forums/showthread.php?t=1050008
Thought I would start a little thread of my own, mainly as a log of the build for myself. Hoping someone who understands the aerodynamics of flying wings will be able to comment on my design. I need to know how much reflex (e.g. Aileron up) would be a good starting point for this.
Span is 3.5 meters
Powered by 70mm EDF.
4s2p 2650mah.
Aiming for an all up weight of 2Kg.
Cheers
Martin
Martin Turner is offline Find More Posts by Martin Turner
Old Aug 11, 2015, 05:25 PM
Joined Feb 2013
First wing has come out at 400grams. (A bit more than i was hoping for).
Old Aug 11, 2015, 05:40 PM
Joined Feb 2013
Started to assemble the fuse tonight and i quickly realised that wing tube sockets in the central fuse section were not going to be strong enough.
I knocked up a socket bracket in sketch-up which I printed out on my basic 3d printer which goes right around the EDF unit. This effectively ties the wing tube sockets together which seems to be much better.
I am having to guess where the fan and batteries go to get near to where the C of G should be.
There is not a lot of room for moving the batteries around, so I hope it's not miles off, might have to redesign the central fuse section it if its way off, but i wont know until I put the whole lot together.
Old Aug 11, 2015, 05:57 PM
jumo004 is online now
Find More Posts by jumo004
jumo004's Avatar
Joined Apr 2010
Just wondering if that EDF shroud will distort any with all the wing flex being directed to it by way of the printed part. Just thinking about fan tip clearance. I see it's aluminum but just wondering .....
Beautiful build.
jumo004 is online now Find More Posts by jumo004
Old Aug 11, 2015, 06:01 PM
Joined Feb 2013
Thanks Jumo. Fair point, but having wrestled to get the bracket over the fan, It seems as though the bracket would probably break before distorting the fan unit.
Old Aug 11, 2015, 07:43 PM
PilotPin is offline
Find More Posts by PilotPin
Joined May 2015
Interesting project. Looks very good what you have done. I'll be watch this. Do you have a project finish date.
PilotPin is offline Find More Posts by PilotPin
Old Aug 12, 2015, 05:13 PM
mthomas is offline
Find More Posts by mthomas
Hi I am Mark & I am an addict
mthomas's Avatar
USA, KY, Louisville
Joined May 2007
Great build and beautiful work.
Off topic question... in the 7th picture, there are akro-bins in the background. Did you use the akro-bin metal channel to secure those or did you use something else?
Mark
mthomas is offline Find More Posts by mthomas
Old Aug 13, 2015, 03:06 AM
Joined Feb 2013
Hi Mark. My bins are made by a company called Dexion. The metal wall plates are made by the same company and are just screwed to the wall.
Old Aug 13, 2015, 08:07 AM
mthomas is offline
mthomas's Avatar
USA, KY, Louisville
Joined May 2007
Thanks for the info.. will look into them.
Old Aug 13, 2015, 03:19 PM
Joined Feb 2013
Thrust tube in made from 180 Micron Overhead Projector sheet e.g. Acetate. I am questioning whether I will get enough power from this motor / fan combo. It's a hobbyking special i'm afraid - doctor Mad thrust.
Eclac suggest that i will have a 0.57 to 1 thrust to weight ratio. It does seem to think it will fly. We will see.
Now the fuse is all glued up, the structure feels nice and rigid.
Old Aug 21, 2015, 04:05 PM
Joined Feb 2013
Few more pics of progress.
Was chatting to someone about Winglets this week, he suggested i really should have them. He thinks it will make it fly like its on rails. Do you agree ?
What you see in picture 2 is 1.4 kg so far. Might be able to get in a little less that 2.2kg.
Old Aug 22, 2015, 07:31 AM
HerkS is offline
Find More Posts by HerkS
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
Span is 3.5 meters
4s2p 2650mah.
Aiming for an all up weight of 2Kg. Cheers
Martin
Hello Martin. It's going to be very hard to answer your question without more info on the wing design. It appears that you have used a cambered airfoil all the way from root to tip. It also appears that you have built no twist into the wing.
Just guessing of course from your photos.
If this impression is correct your design will be problematic. More useful help can be offered, but the plan layout of the wing dimensions, airfoil(s) used and twist angle would all be necessary.
HerkS is offline Find More Posts by HerkS
Old Aug 22, 2015, 06:38 PM
salcheichas is offline
Find More Posts by salcheichas
Andorra, Encamp
Joined Feb 2014
Amazing. Taking place to learn!!!
salcheichas is offline Find More Posts by salcheichas
Old Aug 23, 2015, 12:51 AM
Joined Feb 2013
Hi HerkS.
Ok. So here is the wing data.
I've used a TL54 Aerofoil which is very flat on the bottom.
I choose it from the flying wing database which is here.
http://www.aerodesign.de/english/profile/profile_s.htm
The wing has 3.5 degrees washout or twist built in along its length.
Root chord : 373mm
Tip Chord : 100mm
Span: 3.4m (including Fuse section). Each wing half is 1.5m and fuse is 400mm.
Sweep : 18 Degrees
Plan view from Cad shown above.
Designing some wing lets now, which i plan to 3d print, which will slip over the tips of the wings.
I would love to hear your feedback.
Martin
Old Aug 24, 2015, 09:43 AM
HerkS is offline
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
It's good that you have some twist. The nose down pitching moment of the cambered airfoil would take nose up elevon to counter it. With your high aspect ratio and sweep, the twist will provide some nose up moment.
With a wing of this type, the outer part of the wing is providing negative lift most of the time. Optimizing for that takes an appropriate airfoil out there and washout. If it's not optimized that way, then nose up elevon (which creates crude reflex over that part of the wing) has to provide the trimming force needed.
You will also need to determine an appropriate CG location, and consider launching methods before you try to fly it. Just throwing a large wing like this can be risky.
Build Log A-3 (Was B-66) Foam EDF Build Project BSquared18 Scratchbuilt EDFs 38 Aug 23, 2015 05:12 PM
Question Colour and pattern for 3.5m wing for best recognition/orientation Smiler Electric Sailplanes 7 Jul 15, 2015 09:20 PM
Build Log Red 5 X-Wing (1.5M quad EDF) build Kurt Electric Ducted Fan Jet Talk 21 Nov 20, 2014 11:45 AM
Wanted I am looking for a woody 3m up to 3.5m wood built-up wing with spoilers or flaps only WallsRoofing71 Aircraft - Sailplanes (FS/W) 2 Sep 01, 2014 11:12 AM
Wanted Any Polyhedral Thermal Wing 3.1-3.5m jrbackus Aircraft - Sailplanes (FS/W) 3 May 17, 2010 10:28 AM
