Old Jun 22, 2015, 07:27 AM
mono is offline
Find More Posts by mono
mono's Avatar
Joined Aug 2008
Originally Posted by Suko View Post
I just picked up this little guy for $10 at a swap meet. It binds and works with the regular controller but I cannot get it to bind to my DX6. They're running 2.4 ghz, so I don't know what's the issue here, but my DX6 just keeps saying BIND FAILED.
I had assumed I could bind this to my DX6, but was I wrong and I'm stuck using the included controller?
The Blade Scout CX is not the same as the CX or CX2, unfortunately you put the question in the wrong thread (I saw your post in Electric Heli Talk by the way, so I know which heli you are referring to).
The Scout CX is a 3ch and uses a different protocol to other Blade helis, so your Dx6 is a no-go.
Bonus question: It seems REALLY sluggish going forwards or backwards. Like, I mash the stick all the way forwards or back and it barely moves (sometimes it doesn't even move).
You need to activate the high rate mode by pushing in on the right stick before taking off. Here's a quote from the Scout CX thread...
... "As a beginner heli, it defaults to low rates. Press the right stick into the transmitter, and you'll hear two beeps, and the LED will flash continuously. That's high rates.
If you want even faster, move the ball links on the swashplate to the (slightly) longer balls".
mono is offline Find More Posts by mono
Old Jun 22, 2015, 01:24 PM
Suko is online now
Find More Posts by Suko
Suko's Avatar
United States, WA, Mukilteo
Joined Apr 2013
Yeah, thanks Mono. I guess I was confused on which model I had. And yes, once I activated high rates I got this thing to actually move. Bummer about being stuck with the stock Tx, but at least I only paid $10 for it. =D
Suko is online now Find More Posts by Suko
Old Jun 23, 2015, 10:46 AM
mybad is offline
Find More Posts by mybad
Sure, I can fly after sunset!?
United States, MI, Novi
Joined Jan 2011
I also picked up a couple of those Scouts at swap meets! For more forward speed you can put a little weight in the nose and/or adjust the linkages. Of course, you will reduce or eliminate reverse speed. Depends on how you want to fly it.
Be very careful if you decide to switch the links to the other balls. They are easy to break if you're not careful.
mybad is offline Find More Posts by mybad
Discussion to buy or not to buy the blade cx2 airhead225 Coaxial Helicopters 36 Jul 09, 2009 11:01 PM
Discussion Blade CX2 Tx's - Can they be adapted to fly indoor/park flyers Sirion Electric Plane Talk 11 Apr 19, 2009 07:52 PM
Question How to program my dx7 to fly blade cx2? topforce Coaxial Helicopters 4 Sep 23, 2007 09:13 AM
Discussion How do I use my ICE to charge my batterys for blade CX2??? webejpn01 Electric Heli Talk 2 Jan 26, 2007 01:02 PM
Discussion How to learn to fly inverted with the Blade CP? Crazyrcer Micro Helis 4 Apr 05, 2006 12:59 PM
