Old Aug 21, 2015, 01:28 AM
HGhost is offline
Find More Posts by HGhost
Eye in the Sky
HGhost's Avatar
United States, WV
Joined Sep 2013
Originally Posted by 4FunRC View Post
Hey HGhost! I was looking at your post #450 all google-eyed... (see my post above). I don't know how to do much as far as posting here on RCGroups, like embed post #'s, pages, and such. But anyway, I hope you'll reply concerning your wheel mod and decals.
Thanks in advance,
LP
I am sorry I missed your post......
The decals came on the plane ,bought here :
http://www.amain.com/rc-airplanes/ea...y-2011/p393353
The wheel mod was done with a set of 2 inch Dubro Super Lite tires.
They fit right on the axle with no issue or changes.
The little plastic piece on the stock wheel in the center pulls straight off.....that piece connects to an inner piece that fits on the backside of the wheel......just pull real easy and it comes off
Hope that helps, once again Sorry i missed your first post
HGhost is offline Find More Posts by HGhost
Old Aug 22, 2015, 09:08 AM
4FunRC is offline
Find More Posts by 4FunRC
United States, ID, Post Falls
Joined Feb 2013
HGhost - Thanks for sharing your wheel mod, etc.
LP
4FunRC is offline Find More Posts by 4FunRC
Old Aug 23, 2015, 04:40 AM
the_bunker is offline
Find More Posts by the_bunker
more glue required
the_bunker's Avatar
United Kingdom, England
Joined Sep 2012
Re the wheel mod, I used one of the original front wheels as the tail wheel - just switch as the ghost describes. My front wheels are from hobbyking & were also a straight swap.
The bigger wheels do slow it down a bit in the air, but I can pretty much land it anywhere I like now.
the_bunker is offline Find More Posts by the_bunker
Old Aug 23, 2015, 10:32 AM
4FunRC is offline
Joined Feb 2013
the_bunker - Thanks! That's a great way to mod the tail wheel.
LP
Old Aug 23, 2015, 02:53 PM
HGhost is offline
Eye in the Sky
HGhost's Avatar
United States, WV
Joined Sep 2013
Yes I did the same thing...the original front wheel is now the tail wheel.....
It lands very well and rolls really fast across grass .
I did not notice a difference in the speed in the air, but a lot of difference on ground speed .
Old Aug 26, 2015, 05:41 PM
4FunRC is offline
Joined Feb 2013
Howdy,
I'm a bit confused, or more likely I'm a bit empty-headed %, about the axle size of the stock landing gear being 1.9 - 2.0 mm and the size of the mounting hole diameter of the 'Dubro Super Lite' tires being so much larger. If I'm correct, that's quite a difference and perhaps really not that important. )
I was looking at GWS (LFW-508/21) 2" foam wheels with a 2.1 mm mounting hole, but finding a vendor with 'em In Stock has been fruitless.
Regards,
LP
Old Aug 26, 2015, 08:52 PM
HGhost is offline
Eye in the Sky
HGhost's Avatar
United States, WV
Joined Sep 2013
The 2 inch Dubro wheels I used fit perfectly and are not larger.....
the ( what i will call the "insert" ) that the wheel rides on is a 2 piece plastic spacer type thing.....IT is what slides on the metal axle per say...and what the Wheels ride on...one end is flared/flat ( outer ) to keep wheel from coming off...that 2 piece "insert " fits the Dubro 2" inch wheel with no space to spare
On the Yak -blue /white version it is white, on the Gray and Yellow version it is black.
these are the wheels I used
Du-Bro 200SL 2" Super Lite Wheel ( 2 pack )
http://www.amazon.com/Du-Bro-200SL-S...C8Y1NQQRTASSTM
I hope that makes sense ?
Old Aug 30, 2015, 08:13 PM
HGhost is offline
Eye in the Sky
HGhost's Avatar
United States, WV
Joined Sep 2013
Have had a few days of Great flying.
Put a key cam on my Yak to see if i could get some video of my rather small unique flying field
here are the results...
Even tho it is close to a Highway, I am NOT flying over it.
Enjoy
Yak-12 Flight (6 min 19 sec)
Yak-12 Flight 2 (6 min 3 sec)
Old Yesterday, 11:33 PM
HGhost is offline
Eye in the Sky
HGhost's Avatar
United States, WV
Joined Sep 2013
have been enjoying the Yak very much....have been going up high and than spiraling down and then back up and do it all over again
Love how this plane floats and flies so smooth.
landings have been great ( occasional nose over at the end ) but softly. [ rough runway } do not hit the carpet at all.
The Gray/Yellow does not have flaps and honestly it really does not need them .
Been flying the Yak and Archer a lot.
Old Today, 01:49 AM
more glue required
the_bunker's Avatar
Joined Sep 2012
Enjoy
Maybe you should try FPV !
Old Today, 09:51 AM
HGhost is offline
Eye in the Sky
HGhost's Avatar
United States, WV
Joined Sep 2013
I have considered FPV.....but...have strayed from it so far.....But I have been thinking about it
May in the near future give it a go.
New Product EasySky 5Ch Yak-12 tymodel Scale ARF/RTF 2 Apr 29, 2014 11:23 PM
Build Log Rc-Drones Kong8 XL 950mm X8 build w/AG550-NX gimbal Z06 Tony Multirotor Talk 23 Jul 21, 2012 11:15 AM
Discussion 12" WS Yak Torque Issue super_dork 3D Foamies 3 Apr 16, 2012 02:29 AM
For Sale Great Planes 51" Yak-55M Wheel Pants + Wheels NIB $12 Shipped CONUS parkflyer215 Aircraft - General - Miscellaneous (FS/W) 3 Feb 27, 2012 11:49 AM
