Old May 25, 2012, 04:02 PM
DaveSawers is offline
Find More Posts by DaveSawers
Canada, NS, Lunenburg
Joined Oct 1999
New To Waterplanes
I have a lovely piece of water just outside my house, a nice dock to stand on whilst flying and a nice beach for launch and recovery. It's salt water, but sheltered and usually calm.
In a previous life in Alberta (and before that England), I raced pylon and flew other fast machines. But I've never had a waterplane before and figure it's about time to try one.
I don't have much time to build, so an ARF is required. I don't want anything too small, slow or boring to fly. Scale would be nicer than not. Must be electric powered. Any suggestions?
Is there anything special I should do to make sure the salt water doesn't cause any problems?
DaveSawers is offline Find More Posts by DaveSawers
Old May 25, 2012, 07:49 PM
Kyler1 is offline
Find More Posts by Kyler1
United States, SD
Joined Aug 2010
H9 Piper Saratoga electric conversion.
Kyler1 is offline Find More Posts by Kyler1
Old May 25, 2012, 08:05 PM
Cougar429 is offline
Find More Posts by Cougar429
Cougar429's Avatar
Canada, ON, Windsor
Joined Apr 2008
If anyone has a completed one for sale the Polaris electric is a blast to fly from water, snow or grass, (pavement too if you protect the bottom).
http://modelaero.com/Merchant5/merch...tegory_Code=AM
Here's a vid of mine made with a keychain cam:
http://www.youtube.com/watch?v=2cMJV...4&feature=plcp
Cougar429 is offline Find More Posts by Cougar429
Old May 26, 2012, 03:16 AM
Mark 2 is offline
Find More Posts by Mark 2
Joined Aug 2011
Parkzone Icon A5, or Seamaster/Neptune. They both have high mounted motors that are out of the spray.
Treat your ESC and Rx thoroughly with Corrosion X. If you get anything wet, rinse it immediately in fresh water and let it dry out completely before using it again.
Mark 2 is offline Find More Posts by Mark 2
Old May 26, 2012, 07:07 AM
Arkansas Travelr is offline
Find More Posts by Arkansas Travelr
God of Gravity Poisoning
Arkansas Travelr's Avatar
Joined Nov 2010
Flying off saltwater is going to take a higher level of maintenance because of it's highly conductive/corrosive nature.
I second the CorrosionX suggestion especially if you fly off of saltwater don't used WD-40 it leaves behind a sticky residue. I use alcohol to displace any water that gets into my motor and a very small drop of C/X to lube the bearings. I don't dip my motor in C/X because it will attract dirt. As for your servos a very,very light coating of Vaseline along the seams and horn spindle will make water bead up instead of penetrating.
CorrosionX underwater ESC demo
http://www.rejex.com/tv.html
Arkansas Travelr is offline Find More Posts by Arkansas Travelr
Old May 26, 2012, 07:26 AM
Bart83 is offline
Find More Posts by Bart83
71% of the world is runway . .
Bart83's Avatar
Nederland, ZH, Oostvoorne
Joined Jun 2009
Hello ,
The electrifly widgeon might be something for you.
Electrifly G-44 Widgeon (1 min 53 sec)
G-44 Widgeon (electrifly) maiden flight 23-03-2012 (4 min 19 sec)
Greets ,
Bart
Bart83 is offline Find More Posts by Bart83
Old May 26, 2012, 12:37 PM
Joined Oct 1999
Widgeon looks to me to be the best out of that bunch of suggestions. High motors to help keep them dry, wing floats to help keep those tips out of the water. Scalish appearance. Nice size.
Old May 27, 2012, 06:07 AM
Cougar429's Avatar
Canada, ON, Windsor
Joined Apr 2008
I LOVE Grumman amphibs.......at least those with honking big radials.
Old May 27, 2012, 07:53 AM
Bart83 is offline
Bart83's Avatar
Joined Jun 2009
I also own a Robbe Seabee , this also is a fantastic seaplane. Flies real easy and is a good construction. I'm currently flying my second one cause the first one crashed due to servo failure caused bij moisture. All the electronics on my seaplane's are now soaked in corrosionX and now i have no trouble annymore.
On both the widgeon and the Seabee i have made the battery hatch watertight using loctite blue silicone. I put the silicone on the fuselage where the hatch is put on , then i press the hatch firmly into place and wait for about 1 minute. Then when i pull the hatch off there is a small strip of silicone on both the hatch and the fuse and they interlock perfectly. I find this a very useful way to make the hatch waterticht cause there now is no need for tape etc.
Seabee (1 min 54 sec)
Seabee maart 2012.wmv (0 min 19 sec)
Greets,
Bart
Old May 27, 2012, 02:58 PM
Joined Oct 1999
My father did much of his navigator training in a Grumman Goose in 1942 at the wartime training station at Piarco, Trinidad. So I too have some affinity there. He went on to do north Atlantic convoy protection, flying Swordfish, followed by D-Day air cover and then a spell on carriers in the Far East, coping with kamikaze attacks.
Old May 27, 2012, 03:12 PM
lake flyer is offline
Find More Posts by lake flyer
lake flyer's Avatar
Joined Nov 2005
I have a PZ Spit that I put on floats , ROW great , flys great , rolls , loops ( inside and outside ) etc. , etc . , slows down nicely for landings .
see post # 140
http://www.rcgroups.com/forums/showt...441414&page=10
lake flyer is offline Find More Posts by lake flyer
Old May 28, 2012, 05:08 AM
Joined Oct 1999
My first thought was that's not very scale like. Turns out there were several experiments done on this though. Hmm. Interesting...
Old May 28, 2012, 07:34 PM
lake flyer's Avatar
Joined Nov 2005
Yes there were several built , they were supposed to be for Malta , but they used an "aircraft carrier " instead .
Old Jun 07, 2012, 01:44 PM
Grejen is offline
Find More Posts by Grejen
IAMCANADIAN
Grejen's Avatar
Canada, BC, North Vancouver
Joined Jul 2002
Electrifly / Great planes also make a SeaWind ARF. Good first seaplane because it's hard to damage. Flies great and although landing very nicely isn't easy, landing upright in the water is.
Grejen is offline Find More Posts by Grejen
Old Jun 08, 2012, 12:39 PM
Joined Oct 1999
Ordered a Widgeon today... They're showing as out of stock until end June so I guess nothing will happen particularly quickly.
Discussion Waterplanes in Switzerland peso Waterplanes 1 Feb 11, 2012 08:25 AM
Discussion Esc in waterplane peso Waterplanes 9 Jan 15, 2012 09:58 AM
Discussion FPV Waterplane suggestions? baddb1 Waterplanes 6 Jan 10, 2012 06:40 PM
Discussion Using waterplane in ice cold waters jluther Waterplanes 14 Dec 09, 2011 10:20 AM
For Sale Ready To fly MCX2 New tail lights new servo board new motors 2 new lipos 63 shipd blueindian Aircraft - Electric - Helis (FS/W) 3 Oct 31, 2011 06:18 PM
