Old Jun 08, 2016, 12:08 PM
sonybug is offline
Find More Posts by sonybug
Taiwan
Joined Dec 2005
115km max distance 232km total
Test my 4s 14p 18650 Li-ion and 433mhz Yagi TX today,
Broke my personal record, 115km LOS,
The 433 Yagi is awesome, 90% rssi at 115km,
Now I got to work on video tx.
115KM Ultra long range FPV XUAV TALON MFD OSD (11 min 38 sec)
sonybug is offline Find More Posts by sonybug
Old Jun 08, 2016, 10:14 PM
sonybug is offline
Taiwan
Joined Dec 2005
Add some battery and ground station pics
Old Jun 09, 2016, 05:13 AM
BadSide84 is offline
Find More Posts by BadSide84
Italy, Piedmont, Turin
Joined Aug 2015
Amazing!
What UHF did you use?
BadSide84 is offline Find More Posts by BadSide84
Old Jun 09, 2016, 11:28 AM
sonybug is offline
Taiwan
Joined Dec 2005
Originally Posted by BadSide84 View Post
Amazing!
Hi BadSide84, I am using Rlink 433 (now called MFD 433)
The best part of this LRS is I can change the fail safe setting when the plane is flying.
It's very useful when changing antennas. Like changing from stock antenna to Yagi, I have to switch off the TX. So I set the fail safe mode to the current flying mode, and switch off the TX, the plane will fly as it was before I switched off the TX. The only difference is the rssi dropped to 0 and regained again. (The youtube video at 41 second)
Old Jun 09, 2016, 02:37 PM
jimbo747 is online now
Find More Posts by jimbo747
Joined Jan 2016
Wow! I get twitchy at 115 metres
jimbo747 is online now Find More Posts by jimbo747
Old Jun 09, 2016, 02:49 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
I also use Rlink (aka MFDLink) as it is a phenomenal UHF system, but to be fair, pretty much
all UHF systems allow you to record the failsafe positions on the fly.
BTW, judging by your virtually unchanging RSSI value, I suspect you have your RSSI output
set for packet loss mode, rather than Rf RSSI. In packet loss mode it will indicate 100% as
long as it's not dropping packets. In Rf RSSI mode you will *definitely* see it dropping
with distance, no matter how much gain you have on the Tx antenna. Rf RSSI
is a logarithmic scale, so it will drop quickly at first and then level out. If you're scaling
0-3V to 0-100%, then you'll likely see it drop into the 65-70% range almost immediately,
and at the very limits of your range, it'll be somewhere around 25-30%.
Can switch modes by tapping the Rx bind button briefly once within
the first 15 seconds after power-up. It will remember that mode
on subsequent powerups.
Daemon is online now Find More Posts by Daemon
Old Jun 11, 2016, 02:49 AM
CumuluSfpv is offline
Find More Posts by CumuluSfpv
Joined Jun 2016
thats some serious range! However, most fun usually happens within 7 miles :P
CumuluSfpv is offline Find More Posts by CumuluSfpv
Idea New Flight Mode - Dron goes ahead of us a certain distance bitusbates Scratchbuilt Multirotors 4 Feb 22, 2016 02:51 PM
Discussion New Flight Mode - Dron goes ahead of us a certain distance bitusbates Multirotor Electronics 0 Feb 18, 2016 05:01 PM
Discussion FPV distance question swamibob FPV Equipment 4 Feb 18, 2016 10:42 AM
Discussion Line-of-sight distance vs normal distance tom66 FPV Talk 5 Oct 19, 2010 03:23 AM
