Old Sep 22, 2015, 08:48 PM
xnoobx is offline
Find More Posts by xnoobx
Joined Sep 2015
Question
Multirotor following a Line
Hey at all!
Im looking for a way, that my multi rotor follows a black line. The same way like a RC car.
The cars often use an infrared sensor to to do this. But the most sensors are limited to short distance.
At first i thought about a camera. But the video processing is quite heavy for the MCU. So I remembered for the freescale cup and looked for another solution.
So my questions is: Is there a Infrared Sensor, Infrared Laser which is capable to do this in a height of one meter?
If not, anybody knows another solution?
Greetings phanter
xnoobx is offline Find More Posts by xnoobx
Old Sep 23, 2015, 01:04 PM
brakar is offline
Find More Posts by brakar
brakar's Avatar
Asker, Oslo, Norway
Joined Feb 2009
You could have a look at the new Dji module; "Guidance": https://developer.dji.com/guidance/
brakar is offline Find More Posts by brakar
Old Sep 24, 2015, 09:11 AM
bmw330i is offline
Find More Posts by bmw330i
David1
bmw330i's Avatar
USA
Joined Mar 2007
A quick search on Google returned a Parrot ARDrone following a line in a YouTube video. Probably the BeBop with its dual core CPU and Quad Core GPU can do it easily.
bmw330i is offline Find More Posts by bmw330i
Old Sep 24, 2015, 09:24 AM
bmw330i is offline
David1
bmw330i's Avatar
USA
Joined Mar 2007
sorry repost/duplicate. Deleting
Old Sep 27, 2015, 08:10 PM
xnoobx is offline
Joined Sep 2015
The Guidance is a real hammer. It looks perfect. But also the price is
My aim is to built something myself. I saw a solution with a camera and a second MCU. But picture processing is quite heavy, so Im looking for another way to realize it.
I also have a parrot here. With a Parrot and selfwirtten script with ROS it is no problem.
Old Sep 28, 2015, 06:52 AM
Krylon is offline
Find More Posts by Krylon
What goes up...
Krylon's Avatar
England
Joined Apr 2010
might be worth using a camera and offloading the image processing to something like a pi.
Use a regular flight board to balance and stabilise then code output from the Pi as either PWM or PPM to input direction.
thinking the same logic to a camera gimbal, stab board with user input to direct.
This is a ground bot using a pi with camera, sounds like you have the expertise to apply this to a quad.
Raspberry PI : Line follower Robot with CAMERA and OpenCv (1 min 50 sec)
Krylon is offline Find More Posts by Krylon
Old Oct 24, 2015, 02:13 AM
DKNguyen is offline
Find More Posts by DKNguyen
Edmonton, Alberta, Canada
Joined Oct 2008
Take a look at the CMU Cam and POB Cam. THey have onboard processing that should let you do the job and keep your flight MCU free from vision processing loads:
http://www.cmucam.org/
There is also another similar product from POB Technologies called the POB-Eye
DKNguyen is offline Find More Posts by DKNguyen
Discussion "Follow Me" options for existing multirotors Sugoi Multirotor Talk 1 May 12, 2015 05:03 PM
Mini-HowTo Build a line-following robot using the ActoBitty + Arduino ServoCity Robotics 0 Feb 20, 2015 10:22 AM
Discussion help building Line Follower Hovercraft msj003 RC Hovercraft 7 Nov 30, 2013 09:45 PM
Discussion help building Line Follower Hovercraft msj003 Scratchbuilt Indoor and Micro Models 2 Nov 01, 2013 12:47 PM
Video When a Multirotors follow a KFM4 flying wing Bledi Foamies (Scratchbuilt) 2 Jul 08, 2013 06:11 AM
