Old May 10, 2015, 12:04 PM
vptech2 is offline
Find More Posts by vptech2
United States, LA, Lake Charles
Joined Jan 2013
Raptor Glider Pusher Jet Conversion
Just a brief description.... Pics worth a 1000 words. Hobby Lobby $9.99 Raptor Glider. Shorten wings ( cut 7"ea. ), and horizontal stab (cut 2" ea. end) (shaped cut pcs for winglets), shape & sand fuse. Carbon fiber tube in bottom of fuse (optional), flat carbon fiber in wings and horizontal stab (a must). Hot wire hatch cover, install aileron servos, hog out fuse. for battery, esc & servo. Install elevator push rod, drill 1/2" dia hole in fuse for motor wires / cooling exhaust and epoxy 3/8" square stock for motor. (leave long and cut to final length after elevator is installed.) 1/4"x1" tapered balsa ailerons and 5/16" x 1 1/4" w/ metal gear servo for elevator. I used popsicle stick in front with center and rear magnets hatch hold down. Make front cooling inlet holes (not pictured), finish installing radio and paint and have fun. Turnigy D2826/6 2200KV motor w/ 7x5 prop, 60 Amp Esc, 3S 2200mah battery. CG approx. 2 3/4" back from LE root. Plane screams thru the sky like on rails. THIS IS NOT A BEGINNERS AIRPLANE . Use low throw rates "Cause it don't take much at 90+MPH"
vptech2 is offline Find More Posts by vptech2
Old May 11, 2015, 10:40 PM
Tsavah is offline
Find More Posts by Tsavah
Watt Waster
Tsavah's Avatar
Joined Oct 2010
Looking good, to say the least.
Tsavah is offline Find More Posts by Tsavah
Old May 23, 2015, 09:41 PM
Boogie_ is offline
Find More Posts by Boogie_
Da' Cajun
Boogie_'s Avatar
Lake Charles, Louisiana
Joined Jun 2009
Chuck, have you flown this one yet?
Boogie_ is offline Find More Posts by Boogie_
Old May 23, 2015, 09:46 PM
birdofplay is online now
Find More Posts by birdofplay
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
That's a nice clean "no racks" D- model for an avatar !
How'd you get it so big ?
birdofplay is online now Find More Posts by birdofplay
Old May 24, 2015, 09:26 AM
Boogie_ is offline
Da' Cajun
Boogie_'s Avatar
Joined Jun 2009
I pulled a still image from one of my flight videos.
F 105 (3 min 47 sec)
Old May 24, 2015, 11:16 AM
birdofplay's Avatar
Joined Dec 2005
Shades of Tahkli Thailand 1969
pretty darn fast too !
Your buddy needs a Mig for you to shoot down !
what model is it ?
Old May 24, 2015, 01:46 PM
Boogie_ is offline
Da' Cajun
Boogie_'s Avatar
Joined Jun 2009
I scratch built it a few years ago.
More info in my blog.
Old Jun 06, 2015, 12:07 PM
vptech2 is offline
Joined Jan 2013
Flys pretty good but some wag at high speeds. Going to remove winglets to see if that is the problem.
Old Jul 19, 2015, 03:15 PM
Bentucky1984 is offline
Find More Posts by Bentucky1984
Joined Sep 2014
Vptech...
Man you did a amazing job on that plane! I haven't built a raptor yet "only 5-6 titans". Do you by chance have a flight video?
Bentucky1984 is offline Find More Posts by Bentucky1984
Old Jul 19, 2015, 08:35 PM
kcolraw is offline
Find More Posts by kcolraw
Kcolraw
United States, NC, Asheville
Joined Feb 2015
Bentucky, I thought they were the same just rebranded?
kcolraw is offline Find More Posts by kcolraw
Old Jul 22, 2015, 06:47 PM
vptech2 is offline
Joined Jan 2013
Thanks Bentucky for the kind words. I have about a dozen flights on it but no video. I must admit that I am a "fair weather flyer" and it's just been too hot to go fly. I have done a couple Titans also and both style fly like they are on rails. Couple guys I fly with also made pusher conversions and it's a blast with three of them screaming thru the air. When it cools off I'll try to get some video.
Old Jul 23, 2015, 09:52 PM
basicguy is offline
Find More Posts by basicguy
Ayn Rand Sez.............
basicguy's Avatar
United States, MO, La Plata
Joined Dec 2014
I built one with stock wings RET. A mad thrust 50mm mounted on the top. Didn't bother to shorten the wing. To mount the motor I wrapped it with a single layer of sheet rock tape and then wrapped with layer of black plastic plumbers tape. Previously I had pylon mounted prop.
The mad thrust motor draws 20 amps on a 3 cell lipo. Very smooth and quiet.
My intent is build up a f117 with the motor. I have two prop driven models and like how they fly.
basicguy is offline Find More Posts by basicguy
Build Log F-22 Raptor (EDF or pusher) with build video Lockey Foamies (Scratchbuilt) 101 Jun 21, 2015 03:16 AM
Discussion Vasamodel Fusion Jet Pusher Application Composite JET XtremeWingRC Flying Wings 0 Mar 18, 2015 04:20 PM
Cool Airhogs "Titan" glider into pusher jet billwhit Pusher Prop Jet Models 32 Jul 28, 2011 03:24 PM
Sold Watt-Age "Spirit of America" F-22 Raptor-EP Pusher Jet Bombay Aircraft - Electric - Airplanes (FS/W) 0 Nov 27, 2009 08:13 AM
Raptor Pusher Jet Video guapoman2000 Parkflyers 0 Aug 11, 2003 12:40 AM
