Old Yesterday, 09:48 AM
davidmc36 is online now
Find More Posts by davidmc36
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
One thing to be aware of is if sometimes you don't get all the data showing on your Tx, power cycle the Rx while Tx is on so it can pick up the addresses fresh.
davidmc36 is online now Find More Posts by davidmc36
Old Yesterday, 09:52 AM
Squinton is offline
Find More Posts by Squinton
Joined Mar 2014
Originally Posted by davidmc36 View Post
OK. Here is what I found out about my setup.
Both batteries connected in parallel to -ve and +ve and balance connectors hooked up to L and H: all per cell readings are correct.
Disconnect -ve and +ve of "H" it makes the per cell readings for "H" only, incorrect.
Re-connect either -ve or +ve and readings for both are back to normal.
Disconnect either or both -ve +ve from the "L" battery and both per-cell readings are incorrect.
So my conclusion is that: Put your flight battery through the main -ve leads for current monitoring, hook the +ve to the positive of both main and BEC batteries, and you will get per cell monitoring of both batteries.
Ok, sweet, thanks heaps! cycle the RX, as in turn the bec off and on? :P
Squinton is offline Find More Posts by Squinton
Old Yesterday, 09:54 AM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
But wat! I'm still not sure about this. I was working with two 3 cell batteries, not a 6 and 3. And if you connected as I described, it would not be a series connection like they are referring to in the manual.
Old Yesterday, 09:55 AM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Yup
Old Yesterday, 09:56 AM
Squinton is offline
Joined Mar 2014
I will probably survive with a regular 4s voltage sensor plugged into one of the extra telemetry ports? Or just y-cabled to the telemetry slot on receiver with the EAM rather than risking it!
Old Yesterday, 10:01 AM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Actually, that is probably the best solution. Slipped my mind while we were talking about this. You will totally be able to do the 2-4S sensor for your BEC battery as it will show up in telemetry as General Module and the big one will show up as Electric Module. The key is you can only have one General, one Electric, and one ESC at a time.
The additional sensors are daisy chained into the telemetry port on your Rx.
I bought a few of these:
http://www.ebay.ca/itm/EZC-RC-2-4S-V...item27f07c508b
Work just fine.
Old Yesterday, 10:07 AM
Squinton is offline
Joined Mar 2014
Work just fine.
So the two additional sensor plugs on the EAM are only for temp/rpm? Won't work with voltage sensors?
Sensor 5 and 6 that is.
Old Yesterday, 10:24 AM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Voltage and Temp.
Old Yesterday, 11:03 AM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
CS port can be set as RMP port.
For Sale AirField 2.4GHz DSSS N4 Radio System MTDV Aircraft - General - Radio Equipment (FS/W) 1 Nov 20, 2014 01:47 AM
Discussion E-FLY 6BII 2.4GHz R/C System flashing light fuggire Radios 1 Oct 25, 2010 02:24 PM
Wanted Tactic 2.4ghz radio and receiver system trade for micro microflitedude Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Oct 10, 2010 09:12 PM
Sold Tactic 2.4ghz Radio and Receiver System Trade for Micro EVEN LOWER!! microflitedude Aircraft - General - Radio Equipment (FS/W) 0 Oct 09, 2010 04:38 PM
For Sale NEW - 2.4GHZ 2 channel Pistol R/C system SRM Cars - Cars and Parts (FS/W) 0 Oct 22, 2008 09:39 AM
