Old Apr 28, 2016, 02:06 PM
sashat720 is offline
Find More Posts by sashat720
Joined Feb 2016
Help!
Boscam FT958 vTX fried?
Dear all,
I have received a Boscam FT958 600mw 5,8 Ghz transmitter that I ordered online.
The transmitter doesn't work on power up, there are no LEDs showing any activity.
It also smells like "burned plastic". After looking at it carefully I noticed there is a small microchip that looks "fried".
It's a 6 pin chip in SOT23-6 format with the inscription X9C.
I've made a photo and marked the chip.
Anyone has any idea what that chip is and what it does?
sashat720 is offline Find More Posts by sashat720
Old Apr 29, 2016, 08:12 AM
fightingflight is offline
Find More Posts by fightingflight
Australia, QLD, Brisbane
Joined Jul 2015
Hi,
That would be the DC-DC buck converter to convert your 12-16V 3-4S battery to 3.3V or 5V.
fightingflight is offline Find More Posts by fightingflight
Old Apr 30, 2016, 11:21 AM
Joined Feb 2016
A friend told me that it might have been damaged by powering on with reverse polarity, which adds up to the DC-DC converter being fried.
Any idea which DC-DC converter I could buy to replace the fried one?
Old Apr 30, 2016, 07:55 PM
Joined Jul 2015
Doesn't look like there are any low cost ones on Ebay when searching for sot23 dc buck. What I would do is find the output pin and what the output voltage should be (possibly from someone else who has it, likely going to be 3.3V) and buy a dc-dc buck for ~$1 off Ebay and hook that up to it, not the best solution vs a direct chip replacement but something that will get you up and running.
Old Apr 30, 2016, 10:11 PM
Martin Y is offline
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
That will be the 5 volt supply. There are easy to get from digikey but it's the configuration that is the pain to match.
Martin Y is offline Find More Posts by Martin Y
Old Jun 21, 2016, 03:28 PM
ABLomas is offline
Find More Posts by ABLomas
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
INN9259.
Available, for example on ali but still, probably just wiring 5V here should be enough...
ABLomas is offline Find More Posts by ABLomas
Wanted FT958 600mw vtx Harvdog42 FPV Equipment (FS/W) 0 Feb 29, 2016 07:20 PM
Wanted FT958 600mw vtx Harvdog42 Aircraft - Electric - Multirotor (FS/W) 0 Feb 29, 2016 07:17 PM
Wanted FT958 600mw vtx Harvcopter FPV Equipment (FS/W) 0 Feb 25, 2016 02:28 AM
Discussion Boscam Ts832 vtx - i think i fried it! DYORD FPV Equipment 3 Jan 15, 2015 10:50 PM
Help! Brand New Boscam Vtx Fried? BrandonDrums FPV Equipment 0 Oct 12, 2014 12:05 PM
