Old Mar 27, 2013, 10:53 PM
Joined Feb 2013
Hacking 808 #9 Firmware and/or removing timestamp?
I recently received an 808 #9 (which was unfortunately advertised as a #3 ). I opened it up and it matches the pictures of the #9 and also acts like other #9s. I have the variant with the default date of 2012-05-01 23:59:59
So far I've figured out how to set the default time by modifying the TAG.TXT file, and have also successfully used it as a webcam by pressing the power button after plugging it into the PC.
I was hoping to access the firmware to remove the time stamp or at least edit the font like is done with the #3. I tried the ISP_1528.exe program after installing the web cam drivers (even though it seems this 808 does not use those drivers), but when I run a version check, it says "AP version failed", and when I try to read the firmware it says "USB connection error". I'm assuming the ISP_1528 tool is not used with the camera.
Has anyone messed with the #9? Seems like the image is pretty low quality; from what I gather it's being scaled up? I'm glad I've already got a real 808 #16v2 on the way as well
frantik is offline Find More Posts by frantik
Old Mar 29, 2013, 11:49 AM
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
You might try the #16 GUI to change the time stamp on the #9.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Mar 29, 2013, 07:53 PM
Joined Feb 2013
^ thanks, I will give it a shot, but i'm not hopeful since the #9 seems way different than the #16. I was able to change the time stamp to the correct time but that seems to be the extent of what you can do with it.
I have a #16 now as well.. this #9 is pretty much junk
Old Mar 31, 2013, 10:44 PM
Michigan, USA
Joined Nov 2009
I received this link to #9 firmware (bin file). I can't translate the txt file so I don't know how to use it. Let me know if you decode it. Good luck.
http://yadi.sk/d/pB65b2X62bsmF
-- Chuck at www.chucklohr.com/808
Normandy5 is offline Find More Posts by Normandy5
Old Apr 03, 2013, 10:59 AM
Joined Apr 2013
hi, i also have a 808 #9, i've tried to search any guide to remove time-stamp,but without success. Anyway i have been able to translate the document in the file which you've posted. The txt don't explain how to flash a firmware, but only how to use the keychain. There is the traduction made by Google Translate:
1.Chtoby include.
We press the ON / OFF and hold.
Indicator lights up (and stays)
2. To make the photo.
Briefly press the button REC.
LED goes out for a few seconds and comes back.
The photo was taken.
3. To make a video.
HOLD the REC about 5sec.
The indicator will blink 3 times and go out - there is a record.
4. To stop recording.
Briefly press on REC and wait until the indicator lights up.
5. To turn off the device.
LED goes out.
When you connect the device to the computer should be turned off.
It is advised to keep the charge up to 1 hour.
Best card to put 2 or 4 GB (no problem, you can use 8Gb ~ 1,5 hours of recording)
How to turn on the camera mode Web Cameras
Connecting the camera to a computer. The camera is defined as a card reader. Briefly press the ON / OFF button and wait for the camera as a determination WEB CAMERA.
If not opredelyaetyas avtoaticheski, then download the SPCA1528_V2237_WebCam_Eng.exe and set it
Then run the file whose name ends Amcap.exe (must be at the C: \ Program Files \ SPCA1528 and also on the desktop), and if you do not see the image, then click options
and put a check on Preview. Well and accordingly can be shared Skype or other progami.K Unfortunately, not all chips support mode webcam
so when buying specify if you plan to use the device in the mode of the webcam.
There are times when a device freezes and does not respond to the button after charging, in this
If helping the Reset. After a reset must re set date and time.
. If there are update, tell me.
P.S. sorry for my bad english :/
ax13 is offline Find More Posts by ax13
Old Apr 04, 2013, 01:14 PM
Joined Apr 2013
still nothing guys?
Old Dec 05, 2013, 01:52 PM
Redacted per NSA "suggestion"
dedStik's Avatar
United States, VA, Virginia Beach
Joined Feb 2012
I've got one of these #9's and they are horrible.
I'm very computer savvy and am going to see if I can find out anything, will update results even if I manage to brick it.
dedStik is offline Find More Posts by dedStik
Latest blog entry: Confessions of a smoker...
Old Feb 02, 2014, 02:18 PM
Joined Mar 2010
Were you able to update it successfully?
m4rvin is offline Find More Posts by m4rvin
Old Mar 19, 2014, 10:18 PM
Joined Mar 2014
! Do at your own risk - I don't know if the Firmware is correct/newer for your camera !
Flashing Firmware have to be the same procedure as setting the date/time:
- Copy the .bin file to the root directory of MicroSD
- Rename the file if needed (see bellow*)
- Switch the camera ON with this MicroSD in it
(I don't know how long the Flashing will take or how LED will blink)
* The problem is the filename - camera looks for exact name.
If you look inside this .bin file you will see (near the beginning) a string "GPCODE.ROM"
So try to Rename the file to:
GPCODE.ROM
! Also read all the text under:
Optional Manual Firmware Update Procedure
http://www.rcgroups.com/forums/showp...19&postcount=4
(written for #16 camera but have to be valid for most cameras)
BilBg is offline Find More Posts by BilBg
Help! I forgot how to type Sir Bodgealot FPV Talk 0 Mar 10, 2013 09:36 PM
Discussion Anyone know how to fix 808 #16 that died while updating firmware? OBwan Aerial Photography 1 Feb 16, 2013 11:12 AM
Discussion master cp firmware hacks? Dleach1407 Electric Heli Talk 0 Jan 02, 2013 06:52 PM
Sold #8 Keychain Cam, date/timestamp removed 4gb micro sd card $20 shipped jlcamp7 Aircraft - Electric - Airplanes (FS/W) 5 Dec 13, 2011 01:43 PM
Discussion Removing Timestamp matthewh Aerial Photography 0 Sep 11, 2011 05:43 PM
