Old Feb 10, 2008, 02:28 PM
Scarey is offline
Find More Posts by Scarey
Registered EDF abuser
Scarey's Avatar
Michigan
Joined Jan 2006
Yellow Aircraft Stingray 90 or 120 mm EDF
Well just bought stingray from RC jets unlimited. Now its time to consider which power system I want to install. Ran some numbers thru fancalc for both
90 mm and 120 mm EDF. Also, verified some of the figures from a search in rc groups (Whisting Watts) had posted alot of good info thanks. Well here are some figures.
TF 4000 BAT Static PWR SYS WT
Neu 1912 1Y 10S = 10.84 Lbs wt = 4.26 Lbs amps = 70 Speed = 259Km/h
1521 1.5 Y 8S = 10.56 Lbs wt = 3.96 Lbs amps = 86.6 Speed = 257Km/h = 160 mph
1527 1.5 Y 10S = 11.27 Lbs wt = 4.84 Lbs amps = 75 Speed = 265Km/h = 165mph
AP 120mm
Mega Ac 22/50/2E 10S = 11.4 Lbs wt = 4.37 Lbs amps = 75 speed = 265 km/h = 165 mph
DS51
1515 2Y 90mm EDF 12S = 8.9 Lbs wt = 4.84 Lbs amps = 59 speed = 311Km/h
1515 1.5Y 90 mm EDF 9S = 8.8 Lbs wt = 3.96 Lbs amps = 80 speed = 310Km/h = 192 mph
1515 3D 10S = 9.9 lbs Wt = 4.18 Lbs amps = 75 speed = 315Km/h
I fly from a grass field with a pretty short run. Any thoughts on which one may be optimal?
Scarey is offline Find More Posts by Scarey
Old Feb 10, 2008, 02:46 PM
Gordon is offline
Find More Posts by Gordon
Gordon's Avatar
Joined Aug 2000
Why stop at 90 and 120mm?
There are now a couple of 110mm fans available, Stumax and DS75, either of which could be a better match for this size of the model.
Gordon
Gordon is offline Find More Posts by Gordon
Old Feb 10, 2008, 03:05 PM
Whistling Watts is offline
Find More Posts by Whistling Watts
Braintree, Essex
Joined Mar 2006
Deleted post
Whistling Watts is offline Find More Posts by Whistling Watts
Old Feb 10, 2008, 06:01 PM
monkamarm2000 is offline
Find More Posts by monkamarm2000
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
just to help you in your quest for data, having done 2 of these now I can say for sure that min AUW in any 90mm format will be 10.5 pounds minimum, and 120 will be 12.5 pounds minimum.
Barry
monkamarm2000 is offline Find More Posts by monkamarm2000
Old Feb 10, 2008, 06:30 PM
Scarey is offline
Scarey's Avatar
Michigan
Joined Jan 2006
Well I would have bought tams version but wanted to ponder different power systems. At the moment its 5 degrees obove zero and lots of snow on the ground, so lots of time to build and spend money. Since it is our duty to stimulate the US economy was thinking of buying USA made stuff. Got to spend that tax rebate. The only exception being the fan and maybe bats.
AP 120mm
DS51
Its seems to me this may end up lighter than the 90mm version and a little slower? Mega made in USA I think.
Old Feb 10, 2008, 07:48 PM
Joined Aug 2002
well thats the great thing about this airframe, its pretty wide open as a test bed. on mine im setup for 10s no rudder's and AUW is just under 11, the jolly rogers one is also no rudders 12s and is just over 11 pounds. and both have very lightweight landing gear, so thats about as light as one is probably gonna get. And check out the vid, 90mm or not it takes off! I still think its the epitome of the 90mm plane, but again its also a perfect test bed and you should, above all, have fun with it and do what you like. But in my book with cost not being the factor and weight not being a factor, I have found both installed 90mm highpower, and 120mm 10s setups, a washout. And thats on good quality fans, the others it starts to tilt even more. we really need a fan right between both, so I fully understand why Stu went the direction he did.
Old Feb 10, 2008, 09:13 PM
Scarey is offline
Scarey's Avatar
Michigan
Joined Jan 2006
Yes, I think it would work out well with either 90 or 120mm fans. This would be my first 120mm EDF if go that route. I have a few 90mm builds and twin 70mm EDF`s but This may be my first 120mm. The video of Tam`s version was great and figured out this plane was best suited for my flying conditions.
Light wing loading needed for quick take off. Just wish the flying clubs up here would pave a runway. The closest club with a paved field is 90 minutes freeway away. Thats a long drive for a 7 min flight. In a few weeks things should start coming together. I think this will be a popular EDF conversion and lots of guys here will prob. due it differently. Thanks to you guys who had the wisdom to resurect this model.
Sean
Old Feb 10, 2008, 10:54 PM
Synwpn is offline
Find More Posts by Synwpn
go fly! no crashes!
Synwpn's Avatar
Honolulu, HI
Joined Jun 2003
actually, Mega is from Europe.
Synwpn is offline Find More Posts by Synwpn
Old Feb 10, 2008, 11:03 PM
Joined Aug 2002
thats right! there chek I think. And i love mega's, but from what i've seen the 120 motor isnt really up to snuff for actual 120 use.
Barry
Old Feb 10, 2008, 11:17 PM
FL62 is offline
Find More Posts by FL62
Average Joe 2 Semi-Pro n Back!
FL62's Avatar
United States, AZ, Queen Creek
Joined Feb 2004
Barry
Oh, and I thought that the Mega was called that for being good for 120mph, not 120mm fans
FL62 is offline Find More Posts by FL62
Old Feb 10, 2008, 11:38 PM
Joined Aug 2002
hehe both! lol
Barry
Old Feb 11, 2008, 06:09 AM
Ken Lapointe is online now
Find More Posts by Ken Lapointe
Build'em and Crash'em
Ken Lapointe's Avatar
Narragansett, RI
Joined Oct 2000
sounds like the old HW730 fan would be a nice match
Ken Lapointe is online now Find More Posts by Ken Lapointe
Old Feb 11, 2008, 09:46 AM
tIANcI is offline
Find More Posts by tIANcI
Xtreme Nut
Kuala Lumpur, Malaysia
Joined Oct 2005
I noticed the TamJet version of the Stingray and then stumbled upon this thread. Just wondering if the Tam version is as shown on their site ... meaning it comes finished with the Jolly Roger scheme.
I am really keen on perhaps a blank unit so I can do my own colour scheme, is the Yellow one a lot of work to build? Thanks!
tIANcI is offline Find More Posts by tIANcI
Old Feb 11, 2008, 11:25 AM
Scarey is offline
Scarey's Avatar
Michigan
Joined Jan 2006
No, I believe it comes as a kit but with a Tams nacelle for 90mm EDF. You will have to put it together and paint.
Old Feb 11, 2008, 11:27 AM
Joined Aug 2002
no its a kit as it comes from yellow. and its not too bad as far as yellow kits go, but there is some work yes. And yeah Ken, 730 would fly it, its an ideal test bed. But 90mm is the perfect match for this thing. keeps weight low and has gobs of thrust. bascially shows a 10s-12s ds 90mm is really the swap out for typical IC 5 inch counter part. Most just go 120, but for me in my book, 120 is for much bigger heavier planes than this. 90mm is light and you get all that velocity to haul. and besides naccelle is already setup for 90mm drop in and already has proper thrust angle and everything built into it.
Barry
Discussion yellow aircraft stingray edf conversion? demetrius Electric Ducted Fan Jet Talk 15 Sep 05, 2014 08:03 PM
Video Tamjets/Yellow Aircraft Stingray EDF Tamjets Electric Plane Talk 13 Dec 26, 2008 10:28 AM
Discussion Yellow Aircraft Stingray EDF version ? Martin B Electric Ducted Fan Jet Talk 2 Aug 31, 2006 11:24 AM
i wonder if this would work-yellow aircraft stingray electrified. birdseed High Performance 0 Mar 02, 2003 04:51 PM
Logo-10 (90) or (120) Swashplate setup? Lv2Fly Electric Heli Talk 5 Jul 15, 2002 11:20 PM
