Old Apr 25, 2016, 12:26 PM
OutcastZeroOne is offline
Find More Posts by OutcastZeroOne
"Fly, yes... Land, No"
OutcastZeroOne's Avatar
United States, CA, Santa Cruz
Joined May 2005
Need some info
I've been wanting to see about getting some sort of low power laser rig to cut foam board, but I have no idea where to start. Yes, I am ready for the "try the search button" comments sure to follow, and I did look through the 2 pages of threads listed here.
I know the requirements I want for the set up.
1. Must work with Mac OS. I only have Mac, and I refuse to run bootcamp. I lost this first because it is the biggest issue for me.
2. I want to be able to cut a full sized sheet of foamboard, 20" x 30".
Any advice you guys can give in advance would be of great help.
OutcastZeroOne is offline Find More Posts by OutcastZeroOne
Old Apr 25, 2016, 02:55 PM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
MAC is a limiting factor. I run Fusion on mine to run WIN stuff including CAD and it's a beast of a machine. That would be the sticky wicket.
You can do many of the Chinese made tables and select your laser power from there. If it's just for foam, even at sea level you can probably get away with a fairly low power laser. Are you doing production stuff or hobby / intermittent use. If it's the latter and you are mechanically inclined, I would build a CNC type frame, possibly with a manual Z axis for the laser. If you want something more turnkey, then you likely will spend a fair bit of money on a machine big enough for that.
If you go the DIY route, have a look at alucobond panels for the enclosure. I built one for a friend a few years ago using this method (cnc frame, laser cutter, alucobond enclosure) that has been serving him well.
tom43004 is offline Find More Posts by tom43004
Old Apr 26, 2016, 08:38 AM
portablevcb is offline
Find More Posts by portablevcb
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
Read this thread first.
http://www.rcgroups.com/forums/showthread.php?t=2639146
portablevcb is offline Find More Posts by portablevcb
Old Apr 26, 2016, 08:41 AM
Neophyte hacker
Albuquerque, NM USA
Joined Sep 2003
I suspect you may need to spend decent money on a machine. The table size is your problem.
Cheaper lasers have a 12"x24" or similar platform. To get larger usually means a much higher cost.
charlie
Discussion Need some electric motor info from Da Big G or others 308jockey F3A Pattern 1 Apr 04, 2016 01:38 PM
Question I need some background info on this engine please. Turqui Fuel Heli Talk 7 Oct 27, 2015 06:56 AM
Question Need some info please: Turqui Engines 4 May 18, 2014 09:32 PM
Discussion need some info. DSC FPV Equipment 2 Dec 20, 2013 08:09 PM
Found Need some info please Turqui Boats (FS/W) 1 Nov 20, 2013 07:35 PM
