Old Oct 14, 2015, 04:02 AM
bat22 is offline
Find More Posts by bat22
bat22's Avatar
Fort Worth,Tx
Joined Jul 2005
Build Log
Fiat g-55 aircore foambash build
Ok, well I've had some people ask how I goo aboot do-n this so here we goo . First I find a 3 view of the airplane I want to do and is some what a close match with an Fly Zone aircore airframe and scale it up or down to get a 22 inch wingspan. Then I print it and cut and tape the pages to get this......... Then I cut out the top and side view and tape them on the body and wing to get an idea of what needs to have foam added or taken away.
bat22 is offline Find More Posts by bat22
Old Oct 14, 2015, 04:05 AM
bat22 is offline
bat22's Avatar
Fort Worth,Tx
Joined Jul 2005
Note. I have an aircore me109 in the mail and should be here today.
Old Oct 14, 2015, 05:44 AM
speedy01 is online now
Find More Posts by speedy01
Gulf Breeze, FL
Joined Jul 2006
Great - thanks.
Gene K
speedy01 is online now Find More Posts by speedy01
Old Oct 16, 2015, 06:39 AM
bat22 is offline
bat22's Avatar
Fort Worth,Tx
Joined Jul 2005
Ok ready to start on the fuselage, here I have removed the rudder and stab. I then lay the paper side view over the fuse and mark the location of the rudder and stab.
Old Oct 16, 2015, 06:45 AM
bat22 is offline
bat22's Avatar
Fort Worth,Tx
Joined Jul 2005
Here I have removed the rudder and stab from the paper to trace the outline on the foam. Btw I am using the foam that the airframe came in. I have also cut out the rudder and pinned it to the fuselage.
Old Oct 16, 2015, 06:53 AM
bat22 is offline
bat22's Avatar
Fort Worth,Tx
Joined Jul 2005
Here I have used the me109 stab. I overlay the paper outline on the stab and trace the paper outline on it. I have cut off the bits that are not needed. then I put the me109 stab on the white foam and trace the outline and cut and glue the part that is needed to the front of the me109 stab.
Old Oct 16, 2015, 06:58 AM
bat22 is offline
bat22's Avatar
Fort Worth,Tx
Joined Jul 2005
Working on the cockpit area now. Again using the paper outline to locate it and removing and adding foam where needed.
Old Oct 16, 2015, 07:02 AM
Gulf Breeze, FL
Joined Jul 2006
This is great!!! I love it.
Gene K
Old Oct 16, 2015, 07:16 AM
bat22 is offline
bat22's Avatar
Fort Worth,Tx
Joined Jul 2005
Thanks, yeah it is fun and cheep to do too ! If ya make a booboo well ya just fix it with a bit of foam and sand it down......Lol. Now I have to remember where I got the canopy from on the Macchi 202 I did ! I think it came from a "Diels Engineering" 202 kit. It makes for a good match. Back to work !
Old Oct 16, 2015, 09:22 AM
bat22 is offline
bat22's Avatar
Fort Worth,Tx
Joined Jul 2005
I have cut out the space for the stab and test fit. Also removed the rudder and stab pushrods. You can remove them by gently turning the magnet end back and forth while pulling away from the pushrods.
Old Oct 16, 2015, 10:42 AM
K5083 is offline
Find More Posts by K5083
Flying casual
United States, NY, Scarsdale
Joined Oct 2013
Excellent work! With your skills, you probably could even make the Aircore 109 look like a 109!
August
K5083 is offline Find More Posts by K5083
Old Oct 16, 2015, 10:56 AM
bat22 is offline
bat22's Avatar
Fort Worth,Tx
Joined Jul 2005
Thanks !! lol hows this ? Me109k
Old Oct 16, 2015, 09:56 PM
K5083 is offline
Flying casual
Joined Oct 2013
Very nice bat22. You are turning these toys into real scale models.
August
Old Oct 17, 2015, 06:45 AM
bat22 is offline
bat22's Avatar
Fort Worth,Tx
Joined Jul 2005
Thanks K5085 ! Ok, here I've added the rudder and the ridge to the top rear part of the fuse and the tail cone.
Old Oct 17, 2015, 07:53 AM
bat22 is offline
bat22's Avatar
Fort Worth,Tx
Joined Jul 2005
Done with the air intake and have hinged the rudder. I use "floppy disk", the stuff works great with foam and ca.
Build Log Fiat G.55 Centauro, Scratch built from RCM plans ajaxcrypto Fuel Warbirds 11 Dec 14, 2015 12:16 PM
Discussion Topp-Rippin Models Fiat G-55 Joespeeder Fuel Warbirds 109 Nov 09, 2015 07:18 AM
Sold Fiat G-55 FREEEEEEE Sessholvlaru Aircraft - Fuel - Airplanes (FS/W) 3 Dec 04, 2014 04:23 PM
Fiat G.55 slopeiron Slope 12 Jan 17, 2005 12:56 PM
