Old Oct 19, 2014, 09:44 PM
easycrash
United States, NC, Knightdale
Joined Mar 2011
Rodo,
Good point!
Will do.
I'll re-do all soldering on this controller
I swapped ESC from sev2 to this heli, both YEP 45a.
Will do the test tomorrow
Not ready to spend money at this time.
salrica is offline Find More Posts by salrica
Old Oct 19, 2014, 10:12 PM
Jessthegreat
jessdigs's Avatar
United States, CA, Concord
Joined May 2013
I had the same problem. Ended up being the ground wire from the BEC was almost frayed through. It was hanging on by 3 strands of wire. I put a new plug end on, added a cap, and wire mesh to protect the wiring. It worked great. I would check all the connections from battery to bec to esc to rx to servos.
jessdigs is online now Find More Posts by jessdigs
Old Oct 19, 2014, 10:47 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
I'm using both the YEP 40A and the YEP 45A on 6S with KST DS215MG's and the Tarot 450MX. I'm not using the BEC on the 45A, as I'm running that heli HV. Both are working well, but being 6S, the motor amps are probably well down.
beenflying is offline Find More Posts by beenflying
Old Oct 20, 2014, 02:02 PM
Dave
dcb103's Avatar
The Netherlands, NB, Breda
Joined Aug 2013
it strongly depends if the YEP is a v1 or v2 version the old one doesn't have problems at all while the v2 version seems a problematic ESC for a lot of people. I have several YEP's v1 versions on my heli's and they never failed. 3x40A, 2x45A, 1x80A all using the internal BEC
dcb103 is offline Find More Posts by dcb103
For Sale Vintage Techi Models Mini Bar Fli pattern kit nero1156 Aircraft - Fuel - Airplanes (FS/W) 0 Feb 15, 2013 07:40 PM
For Sale Vintage Techi Models Mini Bar Fli pattern kit nero1156 Aircraft - Fuel - Airplanes (FS/W) 1 Jan 28, 2013 02:27 PM
Sold Mikado Mini V-Bar Pro with 2 DSMX satts. e-heliflyer Aircraft - Electric - Helis (FS/W) 0 Jan 16, 2013 04:11 PM
Sold Mini V-Bar "Blueline" 5.3 Pro xxrando Aircraft - Electric - Helis (FS/W) 0 Jan 02, 2013 09:36 AM
Sold Vintage Free Flight Midwest FU-BAR '36' 1/2A Kit NIB $45.00 FREE SHIPPING!! stevster Aircraft - Fuel - Airplanes (FS/W) 2 Jan 14, 2012 08:07 PM
