Old Dec 15, 2014, 04:51 PM
Australia, VIC, Seaford
Joined Dec 2014
Help!
A959 overheating
My wl toys A959 speed controller is really hot to touch after 40 seconds of running and the batteries are expanding more than ever now,
can you help
cogcruncher is offline Find More Posts by cogcruncher
Old Dec 15, 2014, 11:58 PM
If it flies - I want one!
Petem's Avatar
Werribee, Victoria, Australia
Joined Jul 2008
Load and cooling
I am not familiar with that particular ESC, and advice will depend on your setup.
However, the basic fixes for overheating of ESC/batteries, and much battery puffing, are less load (smaller prop or fewer cells) and better ventilation.
You don't say whether your 40 seconds run is static on the ground (not a good idea for extended test runs) or in flight.
Cheers,
PeteM
Then again, looking at your username, you may be talking about a surface vehicle, in which case ignore references to flight and props, insert running and gearing. The basic principles remain.
Petem is offline Find More Posts by Petem
Old Dec 17, 2014, 05:08 AM
Joined Dec 2014
yes it is a 1/18th buggy,
found out there was an issue with one of my diff's and it was putting too much load on the car
thank you
Help! NTM PropDrive 28-36 overheating GLC_Flyer Sailplane Talk 12 Nov 15, 2014 04:11 PM
Discussion HK 3w LED strip overheating? rodher12 Multirotor Electronics 0 Oct 30, 2014 07:29 PM
Mini-Review WL Toys A959 4WD buggy cofl10011 Off-road Cars 8 Oct 08, 2014 01:18 PM
Discussion Wltoys 1:18 scale A959, A969, and A979 RC trucks KWH Off-road Cars 10 Sep 21, 2014 08:39 PM
Discussion How To Solve Motors Overheating Problems - new pictures ! jamichx Micro Helis 10 Oct 19, 2013 02:24 AM
