Old Oct 17, 2013, 05:15 PM
I don't like your altitude
Stupot46's Avatar
Joined Sep 2011
Build Log
HoXVIIIb
https://skydrive.live.com/?cid=6d242...EZNii2w2mdoxjU
A link to some of Brian's cad and a pic of a box full of goodies!
I won't be starting building for awhile,still waiting bits and pieces and I'm going to get the plank flyable before I start this.
Stuart
Stupot46 is offline Find More Posts by Stupot46
Old Oct 17, 2013, 06:10 PM
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
subscribed
HerkS is offline Find More Posts by HerkS
Old Oct 17, 2013, 10:13 PM
Canada
Joined Nov 2000
Great! Get to work.
Nice to see some substantial 'feet' on those ribs.
Erm.. why do those bigger (centre?) ribs have their Feet on their topsides seems as an anomaly or perhaps an upside down centre build sequence ?
As an intended to be helpful suggestion?
Build and fly the Stingray model (download plans and build sequence available) in the SMEFF Combat thread of Scratchbuilt foamies.
It's a V quick and Cheap build, instantly repaired and It Flies Very well.
Lotsa airtime/practice/experience possible with that wing thing. It doesn't even need a Gasp!.. airfoil (size/version dependant)
The Horten can only aspire to fly as well ( it's a Much prettier model though :-)
Point being; it's a quick /easy/suitable Trainer...it could save significant heartache.. later on.
Good luck.
Bare is online now Find More Posts by Bare
Old Oct 18, 2013, 01:48 AM
Designing something...
United States, CA, Cameron Park
Joined Jan 2004
Originally Posted by Bare View Post
Great! Get to work.
Yes, big feet just like the designer!
The bigger ribs are the center ribs. And yes, the center section builds upside down. Why? Because the stuff (landing gear and nacelles) gets in the way if you build it upright.
Regards,
Brian
cpdude is offline Find More Posts by cpdude
Old Oct 18, 2013, 04:23 PM
United States, CA, Lancaster
Joined May 2013
Cool Stu. Can't wait to see how this one goes.
Cable is offline Find More Posts by Cable
Old Oct 22, 2013, 02:24 PM
Hallo von Dresden
Joined Sep 2012
this ought to be interesting .... you go Stuart and nice work Brian.
Jens
Segelflieger is offline Find More Posts by Segelflieger
Old Oct 22, 2013, 02:53 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
Get the plank up, so you can start with this one !
vincent123 is offline Find More Posts by vincent123
Latest blog entry: FZ5: prototype time
Old Oct 24, 2013, 01:13 AM
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
Subscribed
nmasters is online now Find More Posts by nmasters
Old Oct 25, 2013, 03:46 PM
Dirty Dee's Avatar
United States, IL, Northbrook
Joined Sep 2011
subbed.
How do you plan on steering while on the ground with the fixed gears?
Dirty Dee is offline Find More Posts by Dirty Dee
Old Oct 25, 2013, 04:26 PM
Joined Jan 2004
Originally Posted by Dirty Dee View Post
subbed.
That's a darn good question. Stuart and I were thinking about using differential braking. Stuart may be going this way or another. I'm not sure!
Regards,
Brian
Old Oct 25, 2013, 06:47 PM
Stupot46's Avatar
Joined Sep 2011
Regards,
Brian
I've been giving this quite a bit of thought.Trying to brake one wheel out of four-I'm not sure how well it would work.Im veering(pun!) toward an idea I had early on,which is air brakes behind the outer exhaust ducts on each pylon.Pair of light servos should do.Pushing out,light spring or rubber band to reseat the vane.
Stuart
Old Oct 26, 2013, 05:09 PM
Stupot46's Avatar
Joined Sep 2011
Old Oct 28, 2013, 06:46 AM
Peter V's Avatar
Joined Nov 2008
Horten XVIII b
way to go Brian,
about the steering, aren't these landinggears intended for just their name, only used as gear in landing(s)?
Because: can there be enough speed gained to reach Vro?
btw: subscribed
Peter
Peter V is offline Find More Posts by Peter V
Old Oct 28, 2013, 07:16 AM
Stupot46's Avatar
Joined Sep 2011
Originally Posted by Peter V View Post
way to go Brian,
btw: subscribed
Peter
I must admit this has crossed my mind.Only answer at this stage can be we small see
Old Oct 28, 2013, 01:10 PM
Canada
Joined Nov 2000
Quick answer: She's a Bungee launcher :-)
Differential thrust.. might work ? Seriously tricky (not much fine control though)
At best it's a TX mix issue.
Or making the wheels steer a few degrees inside their doors? Fiddly mechanicals involved though.
One of several reasons why the 'A' version was unquestionably the superior aircraft design, despite R Hortens' Ego attack.
