Old Jan 23, 2015, 10:33 AM
nr1
Joined Feb 2012
Can anyone tell me if the V977 blades also fit the V922?
nr1 is offline Find More Posts by nr1
Old Jan 27, 2015, 01:39 PM
erdnuckel2's Avatar
Joined Mar 2009
you just need to drill out the holes for the blade holder mounting screw a bit (the V922 uses slightly larger diameter screws in the blade holders)
erdnuckel2 is online now Find More Posts by erdnuckel2
Latest blog entry: and again ...
Old Jan 28, 2015, 07:50 AM
Heli Newb
kill000r's Avatar
Germany, BW, Achern
Joined Jan 2015
Hey there, as some of you maybe already know i have problems with my hcp100 and a faulty main motor mosfet. I have already aranged with banggood that they send me a new one for free. In the meantime i thought i might maybe try to switch the Mosfet´s myself, and wanted to ask if those are the right ones. ( I think they are normally used for the mcpx but i cant find the ones on my receiverboard (64BL)
http://www.reichelt.de/IRL-IRFZ-Tran...b4&LANGUAGE=EN
I just dont like waiting and if i order them here in germany they´ll be here by next week :P and i can solder them to pcb and hope those are the only things that dont work anymore on my rx board
kill000r is offline Find More Posts by kill000r
Old Jan 28, 2015, 10:35 AM
joeclone's Avatar
Joined Jan 2013
http://www.rcgroups.com/forums/showthread.php?t=1871237 maybe this can help you
joeclone is offline Find More Posts by joeclone
Old Jan 28, 2015, 08:05 PM
Joined Oct 2014
Hi all was wondering if anybody has come up with a solution for removing all the play in the swash pate?
552 pages is a lot to go thru so i will share my thought on it.
First of all you wil need a spring from a ball point pen then you will need to cut it in half.
Remove the head and swash plate fom the main shaft and place one half of the spring on th shaft, next replace the swash plate and then place the other half of the spring on the shaft above the swash, then replace the head and test your swash for positive and negative movement, both in normal and idle-up modes.
adjust the springs as necesary to avoid strain on your servos.
Have just done this to mine and it has removed at least 90% of the slop/play in my swash as it keeps the inner plate pressed to the bearing at positive and negative pitch.
However i have not flight tested yet as im awaiting parts for my heli
Below are picture at 0 pitch , full positive pitch and fineally full negative itch.
Mrlee03 is online now Find More Posts by Mrlee03
Old Yesterday, 11:33 AM
Sir Crashalot
stonecutter's Avatar
Joined Oct 2011
I don't recall sloppy swash being a common problem with the v922, but a nice solution nevertheless.
stonecutter is online now Find More Posts by stonecutter
Old Yesterday, 02:10 PM
Joined Oct 2014
Well I did get mine second hand, the bearing is probably fudged on mine, might get a new one if my mod doesn't work. It seems to fly very erratically but Tha might just be a micro heli thing.
Old Yesterday, 09:37 PM
Too Old To Die:
OldSpool's Avatar
United States, TX, Call
Joined Mar 2012
Looks like a great idea. I don't know about any slop in the swash plate. But I would like to try the mod to see if it will stop the bearing from coming out. I have had at least three or four swash come apart in flight. Looks like the spring will stop that problem. great idea. : )
OldSpool is offline Find More Posts by OldSpool
Old Today, 07:56 AM
nr1
Joined Feb 2012
thx a lot, i will give it a try
Mini-Review WLtoys V929 Beetle Ladybird Quad Mini-Review FyreSG Mini Multirotors 3762 Today 12:05 PM
Mini-Review The Walkera SUPER FP review (4 Channel Flybarless fixed pitch helicopter) jameschen072 Micro Helis 471 Mar 14, 2014 11:28 AM
Discussion HiSKY FBL100/ WLToys V922 Preliminary findings thread jameschen072 Micro Helis 175 May 20, 2013 08:26 AM
Discussion Walkera Mini CP 3D Flybarless RC Helicopter glybytony Mini Helis 3 Oct 13, 2012 12:01 AM
