Old Jul 11, 2015, 06:00 PM
logair8452 is offline
Find More Posts by logair8452
Joined Jan 2009
Old Fox 19
I am trying to resurrect an old Fox 19 that has good compression but is missing parts. Missing is the prop shaft drive washer (Thrust washer) and needle valve. It has an RC carb but I'm thinking of making it a control line engine so could sub a different needle valve assy. The thrust washer is the needed item. It is the star type drive. Tried Fox some time back but they no longer support that old engine. I could make one I guess. Logair8452
logair8452 is offline Find More Posts by logair8452
Old Jul 13, 2015, 07:39 PM
John Buffum is offline
Find More Posts by John Buffum
Joined Jul 2013
Got a spare drive washer. Fox .35 Stunt. Want to give it a try? Glad to send.
If you want to use it as a UC engine, I STRONGLY recommend the OS needle valve and spray bar from Tower Hobbies.
http://www3.towerhobbies.com/cgi-bin...?&I=LXCR49&P=7
The Fox factory is not supplying ANYTHING right now. I worry. Fox is my favorite brand!
If you want to go back to RC, and the carb is UNSAT for you, try a carb from another brand, but a similar size.
John Buffum is offline Find More Posts by John Buffum
Old Jul 14, 2015, 07:24 PM
Joined Jul 2013
Perry carbs can be had for this size.
http://www.perrypumps.com/prod01.htm
Old Jul 14, 2015, 09:24 PM
Joined Jan 2009
old Fox 19
Thanks for your reply. Sent you a private message, not sure the 35 thrust washer would fit. It appears to have a 1/4 inch shaft.Logair8452
Old Jul 17, 2015, 09:48 PM
rcflyer-rick is offline
Find More Posts by rcflyer-rick
I'm going flying!
rcflyer-rick's Avatar
Colchester IL
Joined Oct 2009
That got me wondering so I went to the garage pulled out one of my 19s and a 35 stunt and tried it. They are the same. I knew they both had a 1/4-20 shaft but didn't know if the drive washer was the same. Now we know. unfortunately I do not have any extras
rcflyer-rick is offline Find More Posts by rcflyer-rick
For Sale NIB Fox .19 R/C eduk8r Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jul 07, 2015 02:47 AM
Discussion 19 year old HPI Nitro RS4 ozoneone Nitro and Glow Power Cars 7 Jun 02, 2015 09:24 PM
For Sale Fox .19 with mark X carb no muffler sagomon Aircraft - Fuel - Engines and Accessories (FS/W) 0 Apr 26, 2015 10:12 AM
Discussion need parts for old Fox 19 rc logair8452 Engines 3 Nov 12, 2012 04:43 PM
For Sale Vintage / Nostalgia Engines: Two Veco 19’s, Fox 15 U control, Fox 25 non-op Daveairway Aircraft - Fuel - Engines and Accessories (FS/W) 1 Feb 28, 2009 08:14 AM
