Old Jul 23, 2015, 10:22 AM
T.A.Z is offline
Find More Posts by T.A.Z
Obsession, not a hobby
T.A.Z's Avatar
United States, AZ, Phoenix
Joined Sep 2013
Originally Posted by wbritho View Post
Hello my friend
I have a power supply dps-1200fb
could you tell me
how best to change that source
I need 13.8V or 13.6v
PS: I would need to make a change in fan
Tks
http://www.rcgroups.com/forums/showp...postcount=2238
T.A.Z is offline Find More Posts by T.A.Z
Old Jul 26, 2015, 07:36 AM
bars_san is online now
Find More Posts by bars_san
Joined May 2013
voltage raised to 13.62 with a resistor 580Om, if you reduce the protection trips.
dps-1200GB A
bars_san is online now Find More Posts by bars_san
Old Jul 26, 2015, 07:42 AM
Joined May 2013
Here is a test
Old Jul 26, 2015, 08:15 PM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
Have you tried charging with it? Many charger pause occasionally in the charge to measure battery voltage. The OVP can trip at that point.
feathermerchant is offline Find More Posts by feathermerchant
Old Jul 27, 2015, 12:01 AM
Joined May 2013
not yet charge the battery at idle a minute off.
With load 55vatt long runs.
Today discharged battery and then put to the charging of the test will tell.
Old Jul 27, 2015, 11:53 AM
Joined May 2013
connected discharged battery, the beginning of the charge current of 6A at 19-00, after 1hour current 4,6A.
The current 1,4A 22-30 and the battery voltage 13,47volt.
OVP is not work, still waiting for charging.
I like to work.
Old Jul 28, 2015, 11:09 PM
Joined May 2013
Yesterday battery charging current over 0.1A, the voltage to the terminal when it was 13,58volt.
OVP has not worked.
All is well, I am satisfied.
Old Jul 29, 2015, 08:57 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
Great to hear!
But if you plan to charge with higher currents, be careful about your creative paperclip connection at the PS output...
Julez is offline Find More Posts by Julez
Old Jul 29, 2015, 09:58 AM
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
And also those bare wires wrapped around the mains. And please connect the ground wire.
Old Jul 29, 2015, 11:45 AM
Joined May 2013
Yes, everything is put in order, it whipped up test.
in a hurry to share the results of the work.
Old Yesterday, 02:58 AM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
At least I can spot a safety shoe on the ground...
Old Yesterday, 07:50 AM
wbritho is offline
Find More Posts by wbritho
Joined Jul 2015
Originally Posted by tjinguy View Post
I believe you have the server model number wrong for this PS. The PS in PowerEdge 2650 is a 500W unit. Those units are very common on eBay and such. The unit you describe here sounds like a PowerEdge 2850 PS, which is indeed rated at 700W, or 12V 57A. The model number is NPS-700AB. Your pin-out works great on this unit. I have put together a how-to on my site.
https://sites.google.com/site/tjingu...-tos/server-ps
Hello my friends
I need to make a change
to get 13.8V
this power supply
is may need to make a change
the OVP system
Can someone help me
model power edge 2850 or NPS-700ab
Tks
wbritho is offline Find More Posts by wbritho
Old Yesterday, 08:01 AM
oliver1071 is offline
Find More Posts by oliver1071
Joined Jul 2011
Hello Maybe someone can help. I'm working on connecting two Dell 2950 750W dm/n z750P power supplies together in series.
It's strange I've removed all of the screws. lifted the boards and secured to Plexiglas inside the case and removed the AC ground wire off of the board and secured it to the case instead. When testing the dc ground to the case on this unit I do not have any continuity.
Also when I connect the + from the unmodified unit to the - of the other I do not get any continuity between the modified unit and the case.
But as soon as the two units touch I get continuity on the modified psu between dc ground and the case.
They appear to function fine and output 24v but it worries me that I possibly missed something. I was wondering if this is the expected behavior when the two cases come in contact with each other?
Thanks for any tips.
Oliver
oliver1071 is offline Find More Posts by oliver1071
Old Yesterday, 10:55 AM
Joined May 2013
oh yeah, the other foot was on the bench ... not to hit
Old Yesterday, 11:03 AM
Joined May 2013
I found the remains of the electric bus, just coming to 12volt rails.
If they are mounted on the bolts drilled through holes, normally it would be?
Alert Need advice on high grade power supply for ISL-8 Byron Betterly Batteries and Chargers 7 Dec 07, 2003 08:31 PM
12volt, 9amp power supply for sale Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 1 Dec 03, 2003 12:44 PM
12volt wallwart power supply reading 14.6 ? (help) power Batteries and Chargers 4 Sep 09, 2003 04:21 PM
Where to Get A Quality Power Supply? Joe Elston Batteries and Chargers 4 Apr 29, 2003 02:09 PM
High end charger and power supply for sale! Very new. ted616 Aircraft - Electric - Airplanes (FS/W) 6 Dec 02, 2002 11:31 PM
