Old Sep 17, 2014, 11:15 AM
wingmanbunty's Avatar
Joined Jan 2014
elevator design
hi everyone
i was searching aerofoil design on net i found zenith microlight airplane
701 model inverted curved wing surface on the down side
i just want to know whay it is done so....
wingmanbunty is offline Find More Posts by wingmanbunty
Old Sep 17, 2014, 11:29 AM
Because when this plane is landing, at a very slow speed and high AOA, the downwash from the wing is so high that the stab is flying at a large negative AOA, and it has to generate a lot of negative lift to counteract the wing pitching moment, so it is designed to delay any possible tail surface stall. This however is at the expense of degraded cruise performance.
It's a common feature on STOL designs
[edit] however, how beneficial that upside-down elevator is, is a bit disputed, as I found after a little search: http://www.stolspeed.com/tail-feathers
Brandano is offline Find More Posts by Brandano
Old Sep 17, 2014, 11:32 AM
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
Originally Posted by wingmanbunty View Post
hi everyone
Frankly, looks like guesswork to me - Hopefully the tailplane would be efficient at high AOA.
In actual practice the loading is 1-2-3 in order of importance.
richard hanson is offline Find More Posts by richard hanson
Old Sep 17, 2014, 12:30 PM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Here's another thread on the subject from a while ago --
inverted Stab airfoil
eflightray is offline Find More Posts by eflightray
Old Sep 17, 2014, 01:36 PM
Grad student in aeronautics
United States, GA, Atlanta
Joined Oct 2010
Also, something to keep in mind: the design may or may not have been a good idea.
DPATE is offline Find More Posts by DPATE
Old Sep 17, 2014, 06:53 PM
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
The C-130 and L-1011 have the inverted airfoil on the horizontal.
Possibly because the enhanced down-load permits a shorter tail moment arm.
The L-1011 with its full-span boost tab (which looks an elevator but isn't) has very good control qualities.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Sep 17, 2014, 10:06 PM
Joined Jan 2014
thanks all
what i think is increasing the size of elevator can be a solution on landing at very slow speed
Old Sep 17, 2014, 10:34 PM
Joined Jan 2009
As always, it is more to one design than what you see at first glance. Below two links to understand Chris Heintz design philosophy for his line of light STOL aircrafts:
http://www.zenithair.com/stolch801/design/design.html
http://www.zenithair.com/stolch701/7-design-tail.html
As a side note I have flown the original CH 701 and the angle of attack, climb rate and decent rate this aircraft is capable of are mind boggling: very similar to a well designed over powered model airplane. Just have a look at the photos and videos.
fnev is offline Find More Posts by fnev
Old Sep 17, 2014, 10:42 PM
Joined Jan 2009
Here is one of the video from Zenair:
http://www.zenithair.com/stolch701/videos.html
Old Sep 18, 2014, 10:24 AM
Joined Jan 2014
@fnev
thanks i gone through the link , very useful information
Old Yesterday, 02:20 PM
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
One has to keep in mind that full size aircraft are typically set up with a radically forward CG location compared to model setups. Other than aerobatic planes full size designs typically balance at or forward of roughly 20% of the MAC. This makes for a high negative lift load on the stabilizer. This makes the use of an inverted lifting airfoil more appropriate. It also makes the generation of lift during the slow speed takeoff and landing phases more reliable.
The tail would need to generate this lift anyway. The use of the inverted camber airfoil simply makes the job of the tail easier. It also delays any stall and possible loss of lift at the tail during the take off and landing. And as a side benefit it would lower the drag at the tail during this same mode.
During cruise the tail would likely generate slightly more drag than you'd get with a symmetrical airfoil. But on a plane which is this draggy that's a fair trade to achieve the exceptional short field landing and takeoff abilities.
Looking at model examples we can see the use of lifting airfoils in free flight models which typically trim out with radically REARward CG locations. The high positive lift values needed to trim these models work out better with a lifting section instead of a flat section.
BMatthews is offline Find More Posts by BMatthews
Old Yesterday, 06:40 PM
Joined Oct 2007
Airfoils ---the shapes which will work are infinite.
The shapes which work well only a few million. The best shape at a finite speed and load is---wait for it
- one.
better yet if we change he size -the shape which is best changes.
or
change the loading
the best one is again, different.
What is the best compromise ?
Is a puzzlement
Discussion Does horizontal tail provide + or - lift? Effect on elevator hinge design... Davee1 Modeling Science 13 Jan 27, 2010 05:46 PM
Discussion Pusher design - distance between wing and elevator ikorman Foamies (Scratchbuilt) 2 Oct 20, 2009 01:56 PM
Discussion Ornithopter Elevator designs? Discussion airDemon64 Ornithopters 13 Feb 01, 2009 07:04 AM
Discussion X400 Homemade Elevated Tail design skysoljah Mini Helis 13 Sep 09, 2006 02:36 AM
DLG Elevator/Stab Design tsheehy Hand Launch 10 Dec 11, 2003 10:34 PM
