Old Apr 22, 2015, 11:05 PM
Red Cat Joe is offline
Find More Posts by Red Cat Joe
United States, CO
Joined Aug 2011
Question
Pixhawk Autolaunch Delays
Hello all,
I'm getting a Skywalker X-8 setup with a Pixhawk.
So far, the X-8 is flying great with the Pixhawk, but now we're trying to get autolaunch working so that a single person can operate aircraft.
I've reviewed data logs from manual launches and found that the delay from the TKOFF_THR_MINACC (15m/s^2) to the aircraft reaching TKOFF_THR_MINSPD (4m/s) takes about 0.33 seconds. Am I correct in thinking that this should be the TKOFF_THR_DELAY value? (As 3.3 in the parameter)
We operate the X-8 up to 3.4kg AUW on 5s 5000mAh packs. Motor is 3548 700kv and a 11x8 Master Airscrew scimitar prop. Launches are with a 5mm bungee stretched 25-35 paces.
I'm nervous to just try it. If it's too short of a delay, it's chop-chop for someone's hand, but if it's too long the plane wont make it off the bungee.
Joe
Red Cat Joe is offline Find More Posts by Red Cat Joe
Old Apr 23, 2015, 03:45 AM
MarioSpeedwagon is offline
Find More Posts by MarioSpeedwagon
Joined Mar 2015
Joe, I'm sorry I can't answer your question, but would you mind answering a quick one for me?
Does a rolling auto launch require any initial setup? I tried once when I first got my pixhawk setup, but haven't tried since. Motors didn't start on the ground.
MarioSpeedwagon is offline Find More Posts by MarioSpeedwagon
Old Apr 23, 2015, 10:51 AM
United States, CO
Joined Aug 2011
MarioSpeedwagon,
I've never tried a rolling takeoff, but I'd think that you have to set the throttle delay, minimum acceleration, and minimum ground speed to zero.
You've probably seen this, but here's the Ardupilot wiki page on takeoffs. Rolling auto takeoffs are about halfway down the page.
Arduplane Autotakeoff
Joe
Old Apr 24, 2015, 01:36 PM
Joined Mar 2015
Thank you. I've read it, but haven't messed with it since I first set up the plane. I'll give it a go
Old Apr 24, 2015, 06:39 PM
United States, CO
Joined Aug 2011
Tried autolaunch today with great success.
Used 12 m/s^2 as the acceleration threshold, 3 as the throttle delay, and 4 m/s as the groundspeed.
Got three launches in; the plane is appropriately far from the thrower's hand by the time the prop spins and the launches are really solid.
The only issue is that it climbs to altitude at a nearly 50 degree deck angle. This is despite the climb pitch being set to 15 in the flight plan, and the max pitch param set to 30 degrees. Does anyone know why this might be? The current thought is that TECS is using the max throttle on takeoff and maintaining airspeed through pitch. Does that sound plausible?
Joe
Discussion Pixhawk from 3D Robotics and PX4 ioan Multirotor Electronics 4889 Today 01:19 PM
New Product 350 QX3 BnF Throttle Delay Problem RT178C Multirotor Talk 2 Dec 31, 2014 05:52 PM
Discussion Delay in Motor? GoProDavidLe Multirotor Electronics 3 Dec 27, 2014 11:01 AM
Discussion PX4 by Pixhawk nyc863 UAV - Unmanned Aerial Vehicles 0 Jul 26, 2012 09:42 PM
Discussion PIXHAWK pxIMU v.2.5 Open-Source IMU now available! pixhawk UAV - Unmanned Aerial Vehicles 4 Apr 30, 2011 03:47 AM
