Old Feb 12, 2013, 05:04 AM
bbz is offline
bbz
Find More Posts by bbz
bbz
bbz's Avatar
Australia, QLD, Aroona
The bbwing - bonsai/tek sumo inspired
This is my 1st wing and 1st time designing plans myself. I got some great help from jackerbes over in the power systems forum.
Some details of specs and gear:Got some video of it and from it on its maiden day.
bbwing Maiden flights scratch built flying wing (4 min 16 sec)
It does require some constant up elevator to maintain altitude but otherwise flies well and has lots of power.
I got some more video today which ill post soon.
After painting, balancing the prop and a few other adjustments it flew much nicer and took much better video from the onboard cam.
I painted using really cheap enamel paints, the key to not eating the foam is to do it from about a foot away and do it in the sun so the paint dries as fast as possible.
bbz is offline Find More Posts by bbz
Old Feb 12, 2013, 07:16 AM
miniprinter96 is offline
Find More Posts by miniprinter96
Psalms 23:4
Goshen, IN, USA
Joined Nov 2010
That looks good. The up elevator is normal. Do some research with reflex, and you'll see it's not only normal, it's required to fly properly.
miniprinter96 is offline Find More Posts by miniprinter96
Old Feb 12, 2013, 07:48 PM
bbz is offline
bbz
bbz
bbz's Avatar
Thanks for the tip, i read up about it here http://en.wikipedia.org/wiki/Tailles...inal_stability.
And from answers.com:
An airfoil in which the mean chord line curves upward toward the trailing edge. This is to provide a download well aft of the center of gravity, increasing with air speed, in a tailless aircraft.
Two cases of reflex chamber.
The wiki page also gave some useful info for my next planned build of a slope soaring wing.
Old Feb 12, 2013, 08:04 PM
bbz is offline
bbz
bbz
bbz's Avatar
this is my slope soarer design but it looks like im going to have to add some sweep to the wings to move the cg back because as it is its a bit too far forward.
Old Feb 14, 2013, 08:54 AM
bbz is offline
bbz
bbz
bbz's Avatar
More flight footage
bbwing scratch built flying wing 2nd day of flights at Meridan Plains, Caloundra (4 min 19 sec)
Old Aug 09, 2015, 08:12 PM
gustavohsouza is online now
Find More Posts by gustavohsouza
gustavohsouza's Avatar
Brazil, MG, Belo Horizonte
Joined Feb 2014
What programm did you use as a CG calculator?
gustavohsouza is online now Find More Posts by gustavohsouza
Old Aug 09, 2015, 08:16 PM
Joined Feb 2014
Found it!
http://fwcg.3dzone.dk/ then click on extended version
Discussion Hobbyking TEK SUMO fpv octane81 FPV Talk 631 May 24, 2015 10:21 PM
Question Tek Sumo / MS Swift / Popwing Crashproofing? colorex Flying Wings 10 Jan 08, 2015 01:15 PM
Help! Glassing Tek Sumo zkilzz FPV Talk 1 Mar 26, 2013 08:48 AM
Wanted Tek Sumo/ Popwing CarbonFlite Aircraft - Electric - Airplanes (FS/W) 11 Feb 16, 2013 06:20 AM
