Old Mar 27, 2015, 06:53 PM
durone is offline
Find More Posts by durone
Italy
Joined Jan 2003
Cool
Very interesting project
See http://www.theremino.com/en/
and
http://www.theremino.com/en/hardware/outputs/motors/
A new italian low cost and open source project, also for CNC machines
durone is offline Find More Posts by durone
Old Oct 09, 2015, 10:11 AM
durone is offline
Italy
Joined Jan 2003
Now you can use the new application devCnc Foam to drive a CNC foam cutting machine, within a Theremino controller.
See http://www.foamcuttingsoftware.com/eng/devcncfoam.asp
Old Nov 18, 2015, 02:47 PM
portablevcb is offline
Find More Posts by portablevcb
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
Are you using one of these yet?
Am not interested in a CNC device but for some other hardware I have.
It looks too good to be true, but, would solve a lot of issues I have been looking at.
charlie
portablevcb is offline Find More Posts by portablevcb
Old Nov 18, 2015, 05:15 PM
durone is offline
Italy
Joined Jan 2003
charlie
Yes, I'm actually using both Theremino V3 (10 pin) and V4 (12 pin)
Old Nov 19, 2015, 11:42 AM
Neophyte hacker
Albuquerque, NM USA
Joined Sep 2003
Thanks, I think I will have to get one or two to play with.
Old Nov 19, 2015, 12:00 PM
durone is offline
Italy
Joined Jan 2003
You can get version V4 here: http://thereminostore.com/product/th...ed-and-tested/
Old Nov 28, 2015, 02:33 PM
Datman is offline
Find More Posts by Datman
New Zealand
Joined Sep 2006
Hi, does this setup allow for wire heat control?
Datman is offline Find More Posts by Datman
Old Nov 29, 2015, 04:45 AM
durone is offline
Italy
Joined Jan 2003
Yes, both as a switch or a PWM controller.
Old Dec 09, 2015, 09:35 PM
Datman is offline
New Zealand
Joined Sep 2006
Thanks, have bought a unit, will test over Christmas.
Old Dec 18, 2015, 04:53 AM
pieri70 is offline
Find More Posts by pieri70
Italy, Friuli-Venezia Giulia, Trieste
Joined Aug 2013
Hello
here my setup for a Foam cutter using Theremino
http://www.rcgroups.com/forums/showthread.php?t=2563600
Bye!
pieri70 is offline Find More Posts by pieri70
Old Dec 27, 2015, 05:02 PM
Datman is offline
New Zealand
Joined Sep 2006
Hi Durone, thanks for the heads up on the Theremino. Love it for its simplicity and the approach they took. I will be able to use it on other projects and make my own software using the Theremino for IO.
Now starting to use it on my foam cutter. I would recommend it for others.
Old Dec 27, 2015, 05:24 PM
durone is offline
Italy
Joined Jan 2003
Actually Theremino is a solution looking for problems...
I liked the idea to use it for hot wire foam cutting, and I spent about 12 months writing software for it. I hope the simple, cheap and high performance Theremino master Usb will be more and more used by aeromodellers. It can be used of course also for Cnc milling, and a good, free and open source application (Theremino Cnc) is already available and well tested.
Theremino runs internally a compiled application (not interpreted application like Arduino), and can get advantage of the power of the Pc CPU for the most time consuming tasks (look-ahead, for example). In this way you can also have a powerful Cnc application running on the computers, so you can better control the cnc machine. But all the real time code is inside the Theremino master, so we have here a TRUE REAL time processing, without having to manage low levels system interrupt (like Mach3 does, trying to emulate a real time process in a NOT real time OS like Windows).
Old Jan 02, 2016, 08:33 PM
Datman is offline
New Zealand
Joined Sep 2006
Hi Durone, what auto heat control circuit are you using? The same you posted a couple of years ago using an Arduino mega?
Old Jan 03, 2016, 05:45 AM
durone is offline
Italy
Joined Jan 2003
I didn't posted anything about Arduino.
You can use a OnOff electronic switch or a PWM controller, both of them are managed by devCnc Foam, as explained in the Help file
Old Jan 03, 2016, 04:24 PM
Datman is offline
New Zealand
Joined Sep 2006
Thanks, I got confused between you and another person.
Discussion Any interest in a 180cfx heli open source project? Centurian Multirotor Electronics 2 Feb 01, 2016 11:18 AM
Discussion Obama "Very Interested" In Raising Taxes Through Executive Action Acer Life, The Universe, and Politics 26 Mar 03, 2015 05:04 PM
Link "The Third Ship", a very interesting SF online novel! molenjin Life, The Universe, and Politics 9 Jan 07, 2015 05:47 PM
Discussion Non - RC but very interesting children toys [videos included] samiluo EachBuyer.com 0 Dec 05, 2014 02:53 AM
