Old Apr 09, 2015, 10:07 PM
EdgarPereira is offline
Find More Posts by EdgarPereira
Joined Apr 2015
Help!
Hx 713
Hello
Suddenly my rc hx713 started to get weird. Does anyone know what is happening ?
I recorded a video to see .
27032015 (0 min 8 sec)
thank you
Edgar
EdgarPereira is offline Find More Posts by EdgarPereira
Old Apr 10, 2015, 12:47 AM
Ribble is online now
Find More Posts by Ribble
Crash and learn
United States, PA
Joined Dec 2011
Coaxial - a shaft inside another shaft.
On the bottom are two large gears that are screwed into each shaft. Check for a missing screw.
Two motors. Each has a small pinion gear that turns the large gear. Check that each motor still has a pinion gear.
Check the floor for tiny screws and little gears.
Hold the helicopter in your hand and add throttle. Both blade sets should turn in opposite directions. If one does not turn it could be a bad motor.
Ribble is online now Find More Posts by Ribble
Old Apr 19, 2015, 03:46 AM
Joined Apr 2015
Sorry for the delay. Only now have I seen the message. I'll check. Thanks for the answer
Old Apr 27, 2015, 08:39 PM
Joined Apr 2015
f you happen to have missing screw, where will I find such a small screw? Since this mini-helicopter bought in a Chinese shop.
If you are not finding bolt, is to make a workaround?
thank you
Old Apr 27, 2015, 09:54 PM
Crash and learn
United States, PA
Joined Dec 2011
Transmitter may have small screw.
Old May 31, 2015, 02:34 PM
Joined Apr 2015
There is no screw loose
The gears rotate in opposite direction
I checked calling in my hand
I do not know what to do
Discussion Converting 7S JST-HX twin connectors to single 7S JST-HX connector gmilo Batteries and Chargers 0 Mar 03, 2014 02:39 PM
For Sale Brand New Redcat Racing/Hexfly Servos - HX-9CS, HX-3CP, HX-6CP Goanna Cars - Cars and Parts (FS/W) 2 Aug 03, 2013 04:55 PM
Astro 713 BIG BOX Sluf7 Electric Plane Talk 0 May 27, 2002 10:40 PM
Wanted: Astro 713 Superbox for Cobalt 25/40 Daveairway Aircraft - Electric - Airplanes (FS/W) 0 Feb 04, 2002 09:25 PM
