Old May 22, 2015, 11:41 PM
Stitch1615 is offline
Find More Posts by Stitch1615
Stitch1615's Avatar
United States, FL, Dunedin
Joined Jan 2013
Originally Posted by Geraus View Post
GPS calibration ? I think you mean Compass calibration
Early onset of Alzheimer's . lol
Correct, compass calibration.
Stitch1615 is offline Find More Posts by Stitch1615
Old May 25, 2015, 01:18 PM
vanondemand is offline
Find More Posts by vanondemand
United States, WA, Blaine
Joined Mar 2014
Who has the best prices on authentic DJI batteries right now? I need to get 1 or 2
vanondemand is offline Find More Posts by vanondemand
Old May 25, 2015, 01:21 PM
Mulherns is offline
Find More Posts by Mulherns
United States, ID, Post Falls
Joined Sep 2007
Aren't the Banggood $80 ones with LCD just as good or better?
Mulherns is offline Find More Posts by Mulherns
Old May 26, 2015, 01:26 AM
PaiRaN is offline
Find More Posts by PaiRaN
Germany
Joined Mar 2015
at the moment they are permanently sold out waiting for 3 weeks by now ...
PaiRaN is offline Find More Posts by PaiRaN
Old May 26, 2015, 07:31 AM
Gavinabe is offline
Find More Posts by Gavinabe
Joined May 2014
I trying to figure out what Naza unit the P2 (non vision ) uses ? I a earlier post I said that I bought a Damaged P2 , the local distributor in my country want to charge over 600 USD to fix , He has suggests due the cost for him to get the parts imported , I buy parts off ebay , which I have mostly found for around about $200 . The only cost which makes it expensive to go ahead and buy is the GPS module . I have found a Compatible GPS Compass Module for DJI NAZA-M V2 / LITE Flight Control System . Which i would like to use .
Thanking you
Gavinabe is offline Find More Posts by Gavinabe
Old May 26, 2015, 07:50 AM
GhostMaster is online now
Find More Posts by GhostMaster
GhostMaster's Avatar
Portugal
Joined Feb 2012
Thanking you
Uses naza v2 with custom firmware, I have one of that FCs for sale at 170$ new shipped, normal price is 200$.
Its new from rma.
GhostMaster is online now Find More Posts by GhostMaster
Old May 27, 2015, 06:38 AM
js247 is offline
Find More Posts by js247
Joined Oct 2014
Suffered a bad fly-away and crash last week. still not sure what caused it. I had performed a compass calibration before the flight and waited for a home lock. I also tested all the controls with the rotors spinning before I took off. I took it up to 30 feet then it started to veer sideways and then it dived bombed into the woods behind a neighbors house. Quite scary actually I am glad it did not hit a house or a person.
Not sure how to troubleshoot I think I did everything per instructions and I've had many many problem free flights.
js247 is offline Find More Posts by js247
Old May 27, 2015, 10:37 AM
Tahoe Ed is offline
Find More Posts by Tahoe Ed
DJI Support
Las Vegas/Lake Tahoe
Joined Feb 2010
When was the last time you did an IMU calibration? I would do that periodically.
Tahoe Ed is offline Find More Posts by Tahoe Ed
Site Sponsor
Latest blog entry: Tradecraft Case for the Inspire
Old Yesterday, 10:51 AM
supercarrera is online now
Find More Posts by supercarrera
Joined May 2015
What's the best way to wire a "goodluckbuy" or ebay gimbal for power?
supercarrera is online now Find More Posts by supercarrera
Old Yesterday, 11:51 AM
Mulherns is offline
Joined Sep 2007
I am about to tackle this myself and information is indeed sparse or vastly overshadowed by the Zenmuse information you have to wade past.
Others can correct me if I am wrong but you have 3 main ways for the power.
First and best is to connect directly to power by a cable you solder to the Phantom 2 board directly. Lots of information on this as it is the same method done on the Phantom 1.
Second and maybe tied to best is to use the red and brown cable out of the bottom of the chassis that is really there for FPV but can supply for gimbal too. I am going to dedicate this to FPV so I will go with option 1 for the gimbal.
The third and worst option is to use a separate LIPO for power. It is very inefficient with regards to the weight it will add.
Lastly, for the pitch movement, you connect ONE SINGLE pitch cable from the gimbal to the F2 port on the Naza. This information is also the same as on the Phantom 1.1.1.
You may also run into this in setting the movement of the gimbal in Naza:
http://www.phantompilots.com/threads...olution.39689/
Old Yesterday, 08:03 PM
Joined May 2015
Thanks so much for your reply! Especially the link explaining the hidden menu in the Phantom Assistant! I was having a heck of time trying to figure out how to turn the gimbal control on util I followed the link you provided. I never heard about it anywhere else.
Anyway I ended up soldering the power wires to the board where the battery is connected and it works fine. I guess I need to tweak the settings for the tilt control because it goes up too far and not down far enough. Also it seems like it's either going to be all the way up, or all the way down.
On my first flight with the gimbal setup, the gimbal stopped working after a few minutes. It might have been because I was flying it too roughly. I turned off the battery and turned it on again and got it to start working again. I took it easy with the flying and everything seemed okay.
Old Yesterday, 10:18 PM
Mulherns is offline
Joined Sep 2007
You are very welcome and I'm glad if I could help. That's what makes these forums so great because I'm still a noob at this stuff and have been helped by many posts already.it sounds like you are ahead of me as I just have my gamble mounted but still need to wire everything up. Stick around and help keep this thread alive if you want and please report back any information that might assist others. Cheers!
New Product DJI Propulsion System for Multirotor ***Developer and Owner Thread***** DJI INNOVATIONS Multirotor Talk 5227 Today 02:58 AM
New Product DJI Phantom 2 Vision ***Owners Thread*** blade strike Multirotor Talk 11518 May 27, 2015 03:15 PM
New Product ZERO UAV E1100 RTF system ***Owners Thread*** Zero UAV Multirotor Talk 117 Sep 25, 2014 10:12 PM
Discussion An update thread for us Walkera X350 owners. Navy Jet Mech Multirotor Talk 92 Mar 20, 2014 06:40 PM
Discussion Phantom Owner in the Fayetteville North Carolina Area needed! Or Anywhere 2dogrc Multirotor Power Systems 8 Oct 04, 2013 09:02 PM
