Old Jul 08, 2015, 02:38 PM
Gordosoar is online now
Find More Posts by Gordosoar
Sabre holic
Gordosoar's Avatar
Beverly Hills, Florida
Joined Nov 2006
SABRE X 51" motor/ prop combo question?
My X 51" weighs 4.5 lbs and I have a GT 2826 850kv and a 12x6 APC prop on it ,
It flys ok but will not go vertical unless I have FT on.
Question, what would be the best motor/prop combo that would not cost $100.00. I've heard the Motolfly is the best for it but there must be something else that wouldn't cost $150.00 and would preform as well.
TIA,
G.
Gordosoar is online now Find More Posts by Gordosoar
Old Jul 08, 2015, 03:15 PM
Gregertman is offline
Find More Posts by Gregertman
United States, IL, Glenwood
Joined Nov 2013
The leopard G-32 800kv from value hobby use the 60 amp hobby wing esc and a castle 10 amp bec. You can spin a 13X6.5 or a 13X8 or 14X7 prop just don't use the 14X7 if you like to hold full throttle for a long time.
Gregertman is offline Find More Posts by Gregertman
Old Jul 08, 2015, 05:07 PM
spastic is offline
Find More Posts by spastic
ProBro Spaz
spastic's Avatar
Buffalo, NY
Joined Aug 2004
i agree and use a xoar, falcon or jxf, 14x6E wood prop
spastic is offline Find More Posts by spastic
Old Jul 08, 2015, 05:32 PM
mattnat is online now
Find More Posts by mattnat
United States, NC, Asheville
Joined Sep 2012
please add turnagy light elictic props to the list. they are lighter than the rest of the a list wood props and in this size range they pull my planes around better. i second 14 /7 as a good place to start. the extra prop wash will help the 3d performance to no end and make the plane far more forgiving.
my fave is 190g 750kv on 14 8 turnagy prop.
the down side of the cheaper motors is that you usually buy more than one. first i buy the 20 bux speshel. then i want a prop that will get me out of trouble. then i get a 45 buc low kv moter (sunny sky). then the motor cant take the gyroscopic load of the 14 inch prop and gets hot... so i go to subsonic planes and get the right motor for 114.
or the tork 2812 720 for 84bux. both these motors will hold up to a 14 inch prop
so how munch did the cheep motor cost me? 175 plus shipping... so lets say 200.
on the esc question i have had good life out of the ztw spider mutirotor escs you want (80amp burst rating) and they give ya top shelf throttle response. then its a 20g 2cell or a 10g cascle bec to run the servos
buy once!
matt
mattnat is online now Find More Posts by mattnat
Old Jul 08, 2015, 06:23 PM
Sabre holic
Gordosoar's Avatar
Joined Nov 2006
Is this the G-32 you are talking about?
Description:
Old Jul 09, 2015, 09:49 AM
Sabre holic
Gordosoar's Avatar
Joined Nov 2006
Flew it today and opened the motor up to FT and I realize the motor that's in it will be fine for now. As I get better at flying it I may go up to the bigger motors you guys posted about. Thank you to all that answered my question.
G
Old Jul 12, 2015, 10:10 AM
Sabre holic
Gordosoar's Avatar
Joined Nov 2006
I'm now using the Emax 2826 860 with a 14x6 prop and have plenty of vertical and the motor doesn't get hot.
I do have another motor coming , a 3526 710 I will be using a 14x7 carbon prop.
Old Jul 12, 2015, 12:04 PM
Joined Nov 2013
I would stick with the 14X7 APC I have yet to find a carbon prop in these sizes that work as good. The 14X7 carbon acts more like a 14X6 at best. If you are set on going carbon I would look for a 14X8.
Old Jul 12, 2015, 12:12 PM
Sabre holic
Gordosoar's Avatar
Joined Nov 2006
Thanks for the info.
I'm using a 14x 6 wood right now,, so would the 14x7 carbon act like the 14x 6 wood? I do have a 14x7 APC but have not tried it yet. I've heard the APC is not as good as the wood or carbon prop.
But I wonder at this point in my 3D flying, if I would notice the difference between any of them.
Old Jul 12, 2015, 12:19 PM
Joined Nov 2013
Try the APC 14X7for sure. The wood props are better then APC in the bigger sizes like 15 and16 inch props that I run on my 60 inch Extreme Flight planes. But on anything smaller like the sabre and my 48 inch Extreme Flight planes. APC are the prop of choice. Yes the 14x7 carbon would be very close to the same as the 14x6 wood.
Old Jul 12, 2015, 12:35 PM
Sabre holic
Gordosoar's Avatar
Joined Nov 2006
Thank you. I'll give the 14x7 APC a try tomorrow. And let you know how it goes.
I also have a 35" SABRE I'm learning on, and I have an SK3 2836 10x4.5 carbon on and it's a rocket.
Discussion X8 Motor & Prop Combo Questions caswal Multirotor Power Systems 16 Mar 25, 2015 01:47 AM
Question Motor/Prop Combo Question.. for a BL-2826/4 Motor Bookstar75 Power Systems 1 Mar 23, 2015 11:36 AM
Question Motor/Prop Combo Question.. for a Parkzone Mustang P-51 Bookstar75 Electric Plane Talk 1 Mar 23, 2015 11:06 AM
Discussion Question re: motor kv, prop, battery combos nstiesi Power Systems 7 Sep 25, 2013 10:19 PM
Question question about the Sabre x 51 valuehobby tupeloflyer 3D Flying 4 Dec 31, 2012 08:08 PM
