Old Jul 02, 2014, 05:11 PM
Australia, QLD, Burua
Joined Jul 2012
Originally Posted by ae freak View Post
Thanks Chris...already have fitted 4000 Mah packs,gyro wires extended,removed the lightest gyro weight,Traxxas Summit BB rear shock,front fork mod done,stator reduced to remove wheel slop,Mamba Max esc,4250 kv 4 pole motor,upgraded servo...will upgrade to sr4 tyres after i smoke the stock tread...Bring on a dry weekend !! Will get some 3 way action happening soon !
Cool mate, sounds like you've been busy. Look forward to seeing some action. I have had my shafts snap on the shocks fitted to the front forks, just something to watch, ideally they need a little more support I think. Fitting a steering damper makes the steering more reactive and feels nicer to me.
chktm is offline Find More Posts by chktm
Old Jul 03, 2014, 02:10 AM
Australia, SA, Fairview Park
Joined Apr 2014
Originally Posted by Throttlejunkie View Post
I think Chris had a problem with the chain tensioners in the plastic swing arm & had a mod for it as well, i am using an ARX alloy swing arm which have grub screws for the tensioners as you would know, Hobbyking have cheap QRF alloy swing arms for the Phantom with the same set up as well.
Cool sounds like you have it ready to go that set up should run great, have your mates done the mods to theirs as well,? i fitted a 4000kv motor to mine & it was a nice improvement from the 3500kv, the Phantom tyres throw a mean roost i did like that about the stock tyres.
Look forward to seeing the 3 way action lol.
One mate's is finished...he is running a 6.5 turn ...hope it won't run too hot,and the other one is well on the way/nearly complete as well. Bloody weather over here is sunny when i'm at work/raining on the weekends...at least we can use all your advice to improve our bikes whilst the rain falls.
ae freak is offline Find More Posts by ae freak
Old Jul 03, 2014, 02:23 AM
Joined Apr 2014
There's always something to do "in the shed"lol. I'll keep an eye on the shock shafts...thanks. Probably won't be jumping as extreeeeme as you for a while !! As long as she handles the "flat track" and a few smaller jumps i'll be happy. (for a while). I might get a steering damper ordered...I see 2 wheeled hobbies still has the mm450 steering damper in stock...is that one the way to go ? Cheers,Troy.
Old Jul 03, 2014, 05:18 AM
Joined Jul 2012
Yea there's always something to do for sure. I think mine broke in a cartwheel, jumping they worked well. Both TJ and I are using the MM damper and it seems quite good and easy to fit with very little modification. Just make sure to order the complete damper from Bruce. Also use plenty of loctite on all metal thread screws on the bike.
Old Jul 25, 2014, 01:42 PM
RC Dirt Bike Action
JohnnyMc's Avatar
California central coast
Joined Feb 2010
@CH - Hey I was going to just post a tip to for the sr4 tire and insert on the site. Would you mind I use a photo you posted a few pgs back where you made inserts (green color)?
@TJ - Does the sr4 tire/insert work better on the arx wheel like it does for this bike? Curious if tried it. I would include the arx bike in the tip I mentioned right above.
JohnnyMc is offline Find More Posts by JohnnyMc
Old Jul 25, 2014, 05:47 PM
If u aint 1st your last
Throttlejunkie's Avatar
Sydney, Australia
Joined Mar 2010
Yes mate, the ARX has the same wheel shell as the Phantom & the SR4 tyre with buggy insert is the way to go for both bikes.
Throttlejunkie is offline Find More Posts by Throttlejunkie
Old Jul 25, 2014, 06:32 PM
RC Dirt Bike Action
JohnnyMc's Avatar
Joined Feb 2010
Cool. So the sr4 tire has more space inside for insert then, or is it just a better tire, both?
Old Jul 25, 2014, 06:50 PM
Sydney, Australia
Joined Mar 2010
I would say both, i have only ever used the 1 ARX tyre that was on the bike & it didn't seem to last long, the ARX tyre is a softer compound but it did lose it's knobs pretty quick from memory & you can't run an insert with them.
Old Jul 26, 2014, 10:48 PM
Joined Jul 2012
No worries John, use whatever pics you want.
Old Jul 27, 2014, 10:07 PM
Joined Jul 2012
Some drift fun with the bikes.
Ken Roczen replica and Phantom 400 RC MX drifting mix (3 min 29 sec)
Old Today, 10:02 AM
Sydney, Australia
Joined Mar 2010
Phantom 400 RC Dirt Bike (7 min 4 sec)
Old Today, 04:51 PM
Joined Jul 2012
Cool vid mate , nearly pulled off that backflip on the flat lol.
Discussion New 1/4 dirt bike ? - CSF 411S - Nuova Faor King of the hill Motorcycles 4 Oct 17, 2013 12:23 AM
Sold NEW Psycho Cycle Dirt Bike Max Tech Motorcycle lmpbpd Cars - Motorcycles (FS/W) 0 Mar 12, 2013 09:16 PM
Sold Vmx dirt bike ruthee Cars - Motorcycles (FS/W) 2 Jan 31, 2013 06:46 PM
For Sale 125cc Dirt Bike - Trades? fordp Non R/C Items (FS/W) 0 Jan 25, 2013 03:43 PM
For Sale Vintage Kyosho Yamaha 250 Dirt bike ruthee Cars - Motorcycles (FS/W) 0 Jan 09, 2013 08:13 PM
