Old Apr 30, 2015, 03:08 AM
GeekBuying is offline
Find More Posts by GeekBuying
Joined Jan 2015
Xiaomi yi Action Camera $69.99
Xiaomi Yi Action Camera WiFi 16MP 1080P 60FPS Ambarella A7LS 155 Degree Wide Lens Bluetooth AV Out Sports DV
Tear Yi Down - First Xiaomi Yi Action Camera Tear Down Video (12 min 57 sec)
About Xiao yi sth........
25 IMPORTANT FAQ ABOUT XIAOMI YI ACTION CAMERA YOU MUST KNOW
Q1. What system environment does the smart phone needed to install Apps?
A1: Android 4.1 or above (Android phones); iOS 7 or above (iPhone). Other operating systems are not available. The iOS App will be available in April.
Q2. How can I get Xiao Yi and Apps paired?
A2: Firstly, install the app and open it, then open your camera and open the WIFI, the blue indicator light wi
ll be flashing. You can click the camera icon at the bottom of the interface, find “YDXJ_xxxxxxx”(xxxxxxx is the later seven number of your camera battery serial number), the initial password is 1234567890.
Q3. How to change WIFI name and password?
A3: After the camera and smartphone connected, click the setting icon on the top right corner, find “WIFI settings” to set your new name and password.Then waiting for the restart of your camera, they will be connected automatically.
Q4. How to restore factory settings?
A4: After connected to the smartphone, you can find the “factory data reset”.Or you can press the power button and WIFI button for a while, after a “DI” sound, it will be reset to factory data.
Q5. Why the camera can’t be connected to phone?
A5: Please check:
1. The apps on your phone is the newest edition
2. The camera wifi function has been opened, the blue indicator light is flashing.
3. The smartphone has been connected the other camera wifi.
4. The password is right.
5. Ensure the distance between the two devices is within 100 meters.
6. If there is many wireless hotspot jamming.
If the above operations are of no use, you can restore your camera to factory settings. Do remember to save your data before you do this.
7. The app might now work properly on some android phones, please try another phone.
Q6. The indicator light is on, but I can’t find the WIFI?
A6: The light is flashing, you can find the WIFI hotspot, if the light doesn’t flashing, it for bluetooth pairi
ng.
Q7. Why I can’t view photos or videos on apps?
A7: All the photos and videos recording by Yi are saved on SD card, you can download the files to your phone, then you can view them on your phone.
Q8. Why I can’t take a snapshot while recording?
A8: The following resolution does not support capture function:
1. 1080P 60FPS/48FPS
2. 960P 60FPS
3. 720P 120FPS
4. 480P 240 FPS
Q9. How to take a quick shot?
A9: Switch Photo and Video mode by short press the power button, press the shutter when indicator light is dark (photo mode).
Q10. What video standard is supported?
A10: NTSC and PAL.
Q11. Why it become slow when taking photos in dark?
A11: Because the camera need more time to exposure.
Q12. Why the photos and videos edges have deformation?
A12: It’s the wide-angle lens, if you don’t like this deformation, you can open the correct function in Settings.
Q13. Why the files have been deleted?
A13: If you opened the cycle recording function, the earlier file maybe deleted to save storage.
Q14. How to download photos and videos?
A14: Download them in the File management on your phone through App.
Q15. Why the camera become very hot when charging?
A15: Please charge your camera in the power off state.
Q16. How long it takes to charge the battery?
A16: About 90 minutes in the power off state. The indicator light will be automatically out when the battery is full charged.
Q17. Micro SD card supported?
A17: Yes, without micro SD card, the camera can’t take photos or video. Support maximum capacity to 64GB, FAT32 format. We suggest you to restore factory settings when you insert a SD card for the first time through app.
Q18. How long the battery can be used?
A18: It’s depend on the mode you choose, it can be used for 85 minutes on 1080P 30fps mode.
Q19. How to view photos and videos?
A19:
1.Download the photos and videos into your phone through app, you can find them in your file management.
2.Using a card reader to copy your files in SD card to your PC, then you can view them on computer.
3.Conneting your camera with computer through USB cable to view.
Q20. How to update new edition?
A20: If there is a new edition available, the app will reminder you to update, please make sure the power is sufficient. We suggest you to update when the electric quantity is above 35%.
Q21. How to clean the camera surface?
A21: Using flannelette or glasses cloth to wipe the lens, clean the body with clear water, wipe to dry. Do not use alcohol.
Q22. How to connect the camera to 2 or more phones?
A22: The camera does not support that yet.
Q23. Where can I get the accessories?
A23: The Xiaomi official will release the waterproof case, HDMI cable, av out cable, belt mount and other accessories soon. We will list them on GeekBuying.com at the first moment.
Q24. When will you ship my order?
A24: We have plenty of stock now and new batches still are coming everyday, order now and we will send it right away!
Q25. Can GoPro accessories compatible with the Xiaomi Yi camera?
A25: Most GoPro accessories are compatible with Xiaomi Yi Action Camera except the waterproof/protective housing case or batteries.
HOW TO SET UP AV OUT IN THE XIAOMI YI ACTION CAMERA FOR FPV
1 – Use the Xiaomi Yi app for Android to update the camera firmware to 1.0.7 (avout only works in 1.0.7 or later)
Android app here: http://sports.xiaoyi.com/app/sports_camera.apk
2- After updating the firmware activate avout in camera options in the app.
3- Use this avout cable: SJ4000 USB-AV out cable
4- Have fun
PS: Be careful using the 5V on the cable to charging, i dont have the confirmation if it works, dont use it until you know it works or you may burn your camera.
iOS App download here:
https://itunes.apple.com/app/xiao-yi...963065779?mt=8
Android App download here:
GeekBuying is offline Find More Posts by GeekBuying
Site Sponsor
Latest blog entry: Geekbuying Offers Free samples
Old Apr 30, 2015, 03:11 AM
Joined Jan 2015
You can buy it from geekbuying,the presale deal price is $69.99
http://bit.ly/1bXkd45
Site Sponsor
Old Apr 30, 2015, 04:26 AM
robschii is offline
Find More Posts by robschii
Joined Apr 2015
you are funny i bought one an it was after 5 days not shipped
robschii is offline Find More Posts by robschii
Old May 01, 2015, 01:43 PM
artlovesart is offline
Find More Posts by artlovesart
Enigma
artlovesart's Avatar
Joined Jan 2015
can you confirm if the camera lens out of focus issue will be resolved or its resolved?
the stock that you currently have, have been tested for lens out of focus problem?
http://en.miui.com/thread-105520-1-1.html
artlovesart is offline Find More Posts by artlovesart
Old May 06, 2015, 04:29 AM
Joined Jan 2015
Oh,Give me your order number,maybe I can help you.
Site Sponsor
Old May 06, 2015, 04:41 AM
Joined Jan 2015
This camera in stock.About camera lens out of focus issue,we are testing.
Site Sponsor
Old Aug 18, 2015, 12:18 PM
wyllsurf is offline
Find More Posts by wyllsurf
Drone X Labs Team Pilot
wyllsurf's Avatar
United States, CA, Humboldt County
Joined Dec 2012
New racing video shot with the Xiaomi. It has it all. Midair collisions, smashing gates and of course high adrenaline racing action.
Psycho Drone Racing with DXL Racing Quad VS QAV250 VS Blackout (5 min 18 sec)
wyllsurf is offline Find More Posts by wyllsurf
Old Apr 17, 2016, 04:09 PM
HarleyAM is offline
Find More Posts by HarleyAM
Joined Oct 2013
Compilation of flying with my Yi camera
FPV - Looking back past month (3 min 29 sec)
HarleyAM is offline Find More Posts by HarleyAM
Discussion The Xiaomi (YI) Sport/Action camera Herr FlicK Aerial Photography 122 Yesterday 07:04 PM
Discussion [Presale Deal] Xiaomi Yi Action Camera only $69.99 GeekBuying Geekbuying.com 0 Apr 24, 2015 11:21 PM
Discussion The first live video from xiaomi yi ambarella sport action camera nickden Aerial Photography 4 Mar 20, 2015 01:49 PM
Discussion Unboxing the original xiaomi yi ambarella wifi sport action camera nickden Aerial Photography 0 Mar 19, 2015 04:59 PM
New Product Unboxing the original xiaomi yi ambarella a7ls wifi sport action camera nickden Aerial Photography 0 Mar 19, 2015 04:52 PM
