Old May 08, 2015, 08:07 AM
Alienmenacet54 is offline
Find More Posts by Alienmenacet54
Alienmenacet54's Avatar
United States, NE, La Vista
Joined Oct 2014
Desination of sailplanes?
Hello;
I have been seeing the size as 2 meter, 3 meter and 4 meter's. Now back in the 70's, they went as this 2 meter, standard class and open/unlimited class. So, is 3 meter considered standard class, and 4 meter considered open/unlimited class.
Thank you
Alienmenacet54 is offline Find More Posts by Alienmenacet54
Old May 08, 2015, 08:52 AM
jrs_123 is online now
Find More Posts by jrs_123
jrs_123's Avatar
irvine, ca
Joined Apr 2002
No. For competition, AMA still lists standard class (100" or less) though its not flown anymore and 2m has limited participation as well. The three classes (really four with HL at 60") now are really dominated by unlimited which is ANYTHING over 100" and any number of controls.
RC SOARING
441 Thermal Soaring–HL
442 Thermal Soaring— Two –Meter
443 Thermal Soaring— Standard
444 Thermal Soaring— Unlimited
460 RES Sailplane
RES (Rudder Elevator Spoiler) class can be separated into RES and WOODY (which is what Nostalgia has sort of morphed into)
The real classes are the FAI classes which generally separate and describe the tasks to be flown . Currently, these include
445* F3B Thermal Soaring (multitask) (which btw tend to be ~3m gliders)
446* F3H Cross Country
455* F3F Slope Soaring (generally very similar to F3B airframes)
456* F3J Thermal Duration Gliders (hand towing) (tend to be the 3.5m to 4.5m airframes)
462*F3K HL Glider
jrs_123 is online now Find More Posts by jrs_123
Old May 08, 2015, 09:05 AM
hallo is offline
Find More Posts by hallo
incorrigible model maker
hallo's Avatar
Joined Feb 2014
And the FAI classes seems to be basically limited by the wing area, wing load and maximum weight, not by wing span. This gives some interesting development and results.
hallo is offline Find More Posts by hallo
Old May 08, 2015, 09:22 AM
jrs_123's Avatar
irvine, ca
Joined Apr 2002
absolutely
Old May 08, 2015, 09:54 AM
Joined Oct 2014
Thank you for your quick replies.
Old May 09, 2015, 02:13 AM
tkallev is offline
Find More Posts by tkallev
LSF303 / AMA Life Member
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
Strictly speaking, Unlimited is ANY wingspan, any number of controls.
tkallev is offline Find More Posts by tkallev
Old May 09, 2015, 04:12 AM
Thermaler is offline
Find More Posts by Thermaler
Balsa breaks better
Thermaler's Avatar
Buchanan Mi
Joined Apr 2005
RC Soaring
441 HL Thermal Soaring
442 Thermal Soaring Two Meter
444 Thermal Soaring Unlimited
456 F3J
460 RES Function (RES)
461 Nostalgia (NOS)
631 Altitude Limited Electric Soar (ALES)
These are the classes being flown at the Nationals this year.
I believe Cross Country is missing as an registered event but still being flown.
Joe
Thermaler is offline Find More Posts by Thermaler
Old May 09, 2015, 11:31 AM
aeajr is online now
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
So, to sum up.
2M, Standard and Unlimited are competition designations. And as TK pointed out, unlimited means no limit. You can fly whatever size you want.
2M, 100", 2.5M, 3M, 4M, etc are dimensions, having nothing to do with competition. Designates the wing span.
aeajr is online now Find More Posts by aeajr
Old May 09, 2015, 09:44 PM
Joined Oct 2014
Thank you all for your input.
Discussion Slightly out of left filed desin for CNC rouer for RC gliderbuilduing emufingers CAD/CAM 2 Jul 06, 2012 09:39 AM
Discussion How do you judge/desine Air Intake. mikes68charger Electric Ducted Fan Jet Talk 9 Feb 28, 2011 12:45 AM
Help! needed: landing gear desine up there Foamies (Scratchbuilt) 1 Jul 13, 2010 06:42 PM
Desine & Build your own R/C Aircraft Gunny Aircraft - Sailplanes (FS/W) 0 Mar 17, 2004 12:01 PM
